| Welcome to Honda-Tech! | ||
#1 |
if ne one can give me a pretty detailed description on how to height adjust d2 coilovers id highly appreciate it
#2 |
#3 |
If you own them, there should be instructions...
Basically, you should adjust the height using the bottom mounts of the coilovers, NEVER by using the bottom spring perch. That should be tightened just enough to hold the spring in there and not allow any movement. There will be a locking collar that's screwed against the bottom mount, so loosen that and turn the mount one way or the other to raise or lower it. Also make sure that only the bottom mount is turning when you're adjusting it. I'd recommend counting how many turns you adjust each one so you can change everything evenly left/right and front/rear (if the car is level as it is). |
#4 |
i have them...loosen the bottom lock ring and just twist the body.
| Tags |
| adjust, adjusting, adjustment, coil, coilover, coilovers, d2, forum, height, honda, instructions, integra, loosen, sports, springs, suspension |
