Supplemental Restraint System Indicator stays on.
Old 09-14-2008, 04:55 AM
BLKFLSH's Avatar
Default Supplemental Restraint System Indicator stays on.
This light has refused to go out after the engine is started a couple of times. Anyone have experience with this? (03 EX V6 Sedan)
Old 09-14-2008, 05:14 PM
MustangLX6.0's Avatar
Default Re: Supplemental Restraint System Indicator stays on. (BLKFLSH)
if your srs light stays on, then you need to goto a dealer and have it looked at. Please know that if you get in an accident with that light on your airbags will NOT deploy. If you want to clear the light yourself and you have your radio code then simply disconnect your battery for a min or 2 and see if it stays out, If there is indeed a fault than the light will stay on and will need to be checked at a dealer
Old 09-14-2008, 08:11 PM
BLKFLSH's Avatar
Default Re: Supplemental Restraint System Indicator stays on. (MustangLX6.0)
What I was hoping for was a common cause for this problem, so I would not have to go through the self diagnostic procedures. I have been able to get codes displayed in the gage (odometer) display before, for another problem, but it took me a while, and I would rather not have to go through all that again.
Old 09-14-2008, 08:43 PM
In a Junkyard near you.
Ross 2.0's Avatar
How's the battery doing? Anything odd happen before the light came on?
Old 09-15-2008, 01:41 PM
dramsey@vtaig.com's Avatar
My opinon, have it checked out soon. Safety is not something that should be left unchecked.
Old 09-15-2008, 02:19 PM
BLKFLSH's Avatar
Default Re: (Ross 2.0)
The battery should be fine. It's less than 2 years old. I know a weak battery can cause this type of thing, so I might have it checked out. If the light comes on again during the week, I will do some checking over the coming weekend. Trust me, I hate things that don't work like they're supposed to, and I will fix it. I was only hoping that there was a common cause, that would quickly narrow the possibilities. Guess not. Thanks guys.
Old 09-15-2008, 02:27 PM
Ross 2.0's Avatar
it could be the usual seatbelt buckle. but it's hard to tell. If it were me i'd do the self diagnostic. At least short the MES and get the code for me.
Old 09-15-2008, 02:35 PM
BLKFLSH's Avatar
I did some checking, and found the buckle was a common cause for the 6th gen cars, but didn't know if it was a continuing problem for 7th gens. Would a small dog being on the front passenger seat cause the light to come on? My Mini-Dachshund was in the passenger seat, the first time the light came on.
Old 09-15-2008, 04:02 PM
Default Re: (BLKFLSH)
yes that is possible, there is a sensor in the pass seat. Also seat belt buckles are uncommon at least from my experience at the dealership from going bad like the 6th gen
Old 09-15-2008, 04:36 PM
BLKFLSH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 2.0 &raquo;</TD></TR><TR><TD CLASS="quote">it could be the usual seatbelt buckle. but it's hard to tell. If it were me i'd do the self diagnostic. At least short the MES and get the code for me.</TD></TR></TABLE>
So you are talking about the thingy at the top of the under-dash fuse-box? And the codes will come up on the Odo display? I didn't know if it worked for SRS or not. I'm not a tech, so I'm not a professional at this stuff (I caught hell just getting the kick panel off to get to the fuse-box last time). But me and my Helm manual can usually figure a problem out, given time.
Old 09-15-2008, 05:59 PM
Ross 2.0's Avatar
Just like the older hondas with the SCS connector. Take the two pin yellow connector out of the fuse box and short the connector. The SRS light will blink out the code.
Old 09-15-2008, 07:07 PM
BLKFLSH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 2.0 &raquo;</TD></TR><TR><TD CLASS="quote">Just like the older hondas with the SCS connector. Take the two pin yellow connector out of the fuse box and short the connector. The SRS light will blink out the code.</TD></TR></TABLE>
If the light ever comes on again, I will do just that. Thanks for the help. I wish that little panel was as easy to remove as the one on my 92 Accord was. That thing is really in there, and the 92 Accord passenger side kick panel was a simple tug. Oh well, I love a challenge.
Old 09-29-2008, 05:04 PM
Power of Dreams's Avatar
Most common cause (if your vehicle has no history of previous accidents and airbag deployments) is a faulty seat belt buckle switch. Those are warrantied for life, so take it to the dealer and they'll replace it for free.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">I did some checking, and found the buckle was a common cause for the 6th gen cars, but didn't know if it was a continuing problem for 7th gens. Would a small dog being on the front passenger seat cause the light to come on? My Mini-Dachshund was in the passenger seat, the first time the light came on.</TD></TR></TABLE>Absolutely.
Old 09-29-2008, 06:51 PM
BLKFLSH's Avatar
Default Re: Supplemental Restraint System Indicator stays on. (Power of Dreams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power of Dreams &raquo;</TD></TR><TR><TD CLASS="quote">Most common cause (if your vehicle has no history of previous accidents and airbag deployments) is a faulty seat belt buckle switch. Those are warrantied for life, so take it to the dealer and they'll replace it for free.</TD></TR></TABLE>
Will do, thanks.
mimog3
10-06-2014 09:29 AM
Phil Boucher
01-03-2014 12:51 PM
97BB6Type-SH
08-03-2006 10:11 AM
97RSTEG
Honda Civic (2001 - 2005)
06-24-2006 12:10 PM
slowcivic888
12-15-2004 06:32 AM
Quick Reply: Supplemental Restraint System Indicator stays on.
