For TSX K24 swap in to EG, how do I get it going without drive by wire throttle cable?
Old 08-23-2008, 10:35 AM
Banned
OneSimpleHatch's Avatar
Default For TSX K24 swap in to EG, how do I get it going without drive by wire throttle cable?
For TSX K24 swap in to EG, how do I get it going without drive by wire throttle cable? What do I need to get my car running? I'm thinking about picking up a K24 from this guy that has a totalled TSX. Any information would be greatly appreciated. Thanks!
Old 08-23-2008, 11:21 AM
ITR-EKcoupe's Avatar
Default Re: For TSX K24 swap in to EG, how do I get it going without drive by wire throttle cable? (OneSimpl
pretty sure you can throw a K20 head on there and do the frankenstine and get rid of the drive by wire. correct me if im wrong.
Old 08-23-2008, 04:14 PM
ekb16's Avatar
k20a.org is ur new best friend
Old 08-27-2008, 11:43 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-EKcoupe &raquo;</TD></TR><TR><TD CLASS="quote">pretty sure you can throw a K20 head on there and do the frankenstine and get rid of the drive by wire. correct me if im wrong.</TD></TR></TABLE>
I've heard that I can just switch to a K20 Throttle Body, but wanted to confirm this.
And again, I'm referring to a TSX K24 already with 11:1 compression. Just do some headwork and call it good. I dunno.
Banned
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">k20a.org is ur new best friend</TD></TR></TABLE>
Got it. Thanks.
Old 08-27-2008, 12:45 PM
k24_dc5's Avatar
Default Re: (OneSimpleHatch)
swap to a RSX throttle body and KPRO and you are good to go
Old 08-28-2008, 09:58 AM
Turbowa's Avatar
Like stated above, Just swap out the TB for one off of a RSX w/ a regular throttle cable and run k-pro. Problem solved. There is no need to swap the whole head.
Old 08-28-2008, 10:38 PM
Sanji
toyomatt84's Avatar
In order to run a K20 throttle body, you'll need an adapter plate. To do as direct of a swap as possible, get an Accord ('02 - '04) throttle body. They use similar intake manifold designs and are cable driven.
Old 08-29-2008, 08:29 AM
Banned
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24_dc5 &raquo;</TD></TR><TR><TD CLASS="quote">swap to a RSX throttle body and KPRO and you are good to go </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbowa &raquo;</TD></TR><TR><TD CLASS="quote">Like stated above, Just swap out the TB for one off of a RSX w/ a regular throttle cable and run k-pro. Problem solved. There is no need to swap the whole head.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">In order to run a K20 throttle body, you'll need an adapter plate. To do as direct of a swap as possible, get an Accord ('02 - '04) throttle body. They use similar intake manifold designs and are cable driven.</TD></TR></TABLE>
Thanks guys! That's some good info there!
Old 08-29-2008, 12:10 PM
oneslowstd's Avatar
you can also use 06 accord throttle body those arent drive by wire poo!
Old 08-29-2008, 07:16 PM
Banned
Default Re: (oneslowstd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslowstd &raquo;</TD></TR><TR><TD CLASS="quote">you can also use 06 accord throttle body those arent drive by wire poo!</TD></TR></TABLE>
Good stuff thanks for the continuous info guys!
Old 08-30-2008, 02:46 PM
oneslowstd's Avatar
good luck
tracychase
Acura TSX
11
11-27-2012 01:52 PM
chzlc
Honda Civic (2006 - 2015)
15
01-11-2009 12:22 PM
campbuds
30
08-23-2007 09:07 AM
speedracer209
43
12-13-2006 08:37 PM
cmdr430
Acura TSX
12-05-2004 08:49 AM
Quick Reply: For TSX K24 swap in to EG, how do I get it going without drive by wire throttle cable?
