can u use b16b pistons in a d16a2
Old 08-14-2008, 12:03 PM
mario_pic's Avatar
Default can u use b16b pistons in a d16a2
can u put b16b pistons in a b16a2 motor with out changeing the cam shafts or crank shaft and push rods
Old 08-14-2008, 12:11 PM
$cat /dev/urandom
sanimalp's Avatar
Default Re: can u use b16b pistons in a d16a2 (mario_pic)
uh, you might have some trouble with the pushrods..
Old 08-14-2008, 12:48 PM
Crx Jimmy's Avatar
Default Re: can u use b16b pistons in a d16a2 (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">uh, you might have some trouble with the pushrods..</TD></TR></TABLE>
yeah this is a overhead cam engine,
Old 09-22-2008, 07:12 AM
SwissChEz82's Avatar
Default Re: can u use b16b pistons in a d16a2 (Crx Jimmy)
You need to either change your title or change your initial post, because one says D16a2 and the other says B16a2 which are far different engines.
Old 09-22-2008, 08:38 AM
projectTeG's Avatar
yes you have to modify to get the piston to fit the rod.
Old 09-22-2008, 01:33 PM
mario_pic's Avatar
Default Re: (projectTeG)
lol im talking sir motor the d was a typo lol
Old 09-22-2008, 02:05 PM
slofu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mario_pic &raquo;</TD></TR><TR><TD CLASS="quote">can u put b16b pistons in a b16a2 motor with out changeing the cam shafts or crank shaft and push rods</TD></TR></TABLE>
con rods, not push rods.
SP GARAGE
04-12-2012 02:44 PM
bzyq2001
09-21-2007 04:06 AM
invisible
04-23-2007 06:51 PM
b16a27
12-22-2004 10:28 AM
rice a roni
10-07-2004 10:37 AM
Quick Reply: can u use b16b pistons in a d16a2
