BRAICH BUILT A/M H2B Build
Old 02-16-2010, 08:19 AM
  #1251
scmil95eg's Avatar
Default Re: my h2b build
Looks sweet Jeff.
Is there a drastic difference between the port in the ITB and the H-series adapter?
scmil95eg is offline
Old 02-16-2010, 08:28 AM
  #1252
JDM JEFFREY's Avatar
Originally Posted by scmil95eg
Looks sweet Jeff.
Thanks
I had steve port match both sides of the plate to the itbs and the head..
I can take some pics next time the itbs are off the motor..
the way that Josh made the plate was k port on one side and h on the other..
JDM JEFFREY is offline
Old 02-16-2010, 11:58 AM
  #1253
jdmintegraxsi's Avatar
Man Jeff everything is looking amazing. Can't wait to see what it puts down on the dyno, and more importantly how deep into the 10's you dip. I like having the northwest record so try and keep it under a 10.79
Hopefully we get a chance to line up again this year
Everything you do is so clean.
jdmintegraxsi is offline
Old 02-16-2010, 12:01 PM
  #1254
88ED8's Avatar
I'm sure he wants to be under a 10.79!
88ED8 is offline
Old 02-16-2010, 05:30 PM
  #1255
lol thats the goal
Old 02-16-2010, 05:31 PM
  #1256
thanks bro...
Old 02-16-2010, 07:28 PM
  #1257
some more parts came in today
hasport solid mounts
Speedfactory's scha Thanks James and Matt
Old 02-16-2010, 07:29 PM
  #1258
wow I need to clean the oil off the camera..lol
Old 02-16-2010, 07:34 PM
  #1259
97pInGaLoKa's Avatar
very nice i just creamed all over my shorts
97pInGaLoKa is offline
Old 02-16-2010, 07:40 PM
  #1260
lol
Old 02-16-2010, 07:43 PM
  #1261
91' LS-VTEC's Avatar
serious parts there Jeff. Looking foward to hear this beast fire up.
91' LS-VTEC is offline
Old 02-17-2010, 04:55 AM
  #1262
NAH2B's Avatar
nice
are those anodized billet mount inserts?
NAH2B is offline
Old 02-17-2010, 06:28 AM
  #1263
lau
lau's Avatar
car is looking mighty sexy grats
lau is offline
Old 02-17-2010, 07:27 AM
  #1264
Originally Posted by NAH2B
nice
yes sir
Old 02-17-2010, 08:13 AM
  #1265
Moderator
crazes's Avatar
cars is coming along great congrats
this is only question i have when it comes to the itbs test vs randy mainfold. didn't randy mainfold work due to the force air pushed in the tb at the track. is there that you can replicate it at the dyno like if it was at the track ? just wondering
crazes is offline
Old 02-17-2010, 10:17 AM
  #1266
RaceCarRyne's Avatar
is that piece from speed factory just an oe replacement or is there someting special about it?
RaceCarRyne is offline
Old 02-17-2010, 05:53 PM
  #1267
hollandallmotor's Avatar
took some pics showing sensor location, fuel rail setup, tps plug, etc:
i really like that setup, only thing is there will be a huge difference on the dyno vs going down the track. That setup has to create some boost on the top end i would think.
hollandallmotor is offline
Old 02-17-2010, 06:04 PM
  #1268
King of the One Liners
2fastGSR's Avatar
The manifold also made more power on the dyno then any other H manifold randy tested . . . While it shines on the track, It also does well on the dyno . .
I think it will be a great test if it gets done . .
2fastGSR is offline
Old 02-17-2010, 06:26 PM
  #1269
back to back testing at the track would be ideal also. Jeff lets run a number in ur car then throw the motor in my chassis and see what it can do. LOL.
Old 02-17-2010, 07:10 PM
  #1270
if Randy would let me have the mani for a bit mybe a week or so...
and im down to put the motor in your car..
Old 02-17-2010, 07:13 PM
  #1271
http://www.speedfactoryracing.net/st...roducts_id=247
Old 02-17-2010, 07:32 PM
  #1272
2fastGSR's Avatar
Of course, I was merely pointing out the fact that this manifold worked well on the dyno as well . .
Well funnelled air to an ITB setup has been proven to show very good positive pressure results as well, same principle really . .
2fastGSR is offline
Old 02-17-2010, 07:47 PM
  #1273
Randy's manifold made really good power on the dyno 320+ i think...
But for the postive pressure me and Derek are make an air box that will pull the air off the
windsheild. That should work the same as Randy manifold..but I still want to test his
with the kinsler...and we are also going to try a set up Like bisi's
Old 02-17-2010, 08:07 PM
  #1274
2fastGSR's Avatar
base of the window . . . look at all the CFD models/programs . . . Any wind tunnel test . .
They tend to all say the same about the base of the windshield . . .The results mean something Not so good for gas mileage on daily drivers, but great for drag cars sucking air from that point . . . Get to it homie ! ! !
2fastGSR is offline
Old 02-17-2010, 09:21 PM
  #1275
Moderator
crazes's Avatar
you forget sometimes that you need like an engineering degree or every good understanding of air dynamics to help your motor breath so you can make serious power.
crazes is offline
Quick Reply: BRAICH BUILT A/M H2B Build
