cruise control wont work
Old 07-29-2008, 08:41 AM
boarding2008's Avatar
Default cruise control wont work
I have a 92 accord ex AT and When i turn on the cruise control the cruise control light on the dash turns on and when i take my foot off the gas the car doesnt stay at that speed it just drops and drops. if i press the accelerate button it wont accel unless im at 45-55mph. checked for vacuum leaks but couldnt find any. any ideas?? Thanks in advance.
Old 08-04-2008, 09:37 AM
99accordFX's Avatar
Default Re: cruise control wont work (boarding2008)
Check for loose or broken cable in throttle body. Maybe a bad diaphram on CC unit itself. Check fuses and Relays if is not a vacumm controoled unit.
Old 08-07-2008, 03:40 PM
Default Re: cruise control wont work (99accordFX)
I havent had a chance to check any of those. I went to Cedar Point OH, about 225 miles, and when i got up to 60+ mph it stayed where it should and the accel and decelerate buttons works. Just Puzzles me. My guest is the cc unit or the diaphram
Old 08-07-2008, 03:50 PM
He knows where you live!
TheMuffinMan's Avatar
What speed were you trying to do it at?
IIRC it's like 20 and lower it will not work.
Old 08-07-2008, 07:49 PM
mongtite's Avatar
Default Re: (TheMuffinMan)
from what I remember, Cruise control works after 30mph. If your cruise control doesn't work at all then U have a problem with impedence, there are two lights in the push button that goes green when U push, when U set the button on the steering, it turns on at U'r dash light.
Old 08-08-2008, 04:45 AM
Default Re: (mongtite)
the light turns on when im going 35-55 but it wont hold that speed. but when im going 60+ it holds the speed fine.
cloud2kz
08-26-2009 11:13 AM
speedfreek128
02-19-2009 10:06 PM
darkslide_77
11-06-2004 08:53 PM
noble4ws
08-16-2004 02:24 AM
Kazmans94cord
03-20-2002 04:41 PM
Quick Reply: cruise control wont work
