JDM H23A Vtec Blue Top Mystery Motor, True Facts, Questions?
Old 04-13-2013, 06:29 AM
  #851
yungmulacrx's Avatar
Default Re: JDM H23A Vtec Blue Top Mystery Motor, True Facts, Questions?
Originally Posted by Jimmynitro
My h2b is using a h23a. Runnng Hondata. I'm a novice tuner. Went to efi classes tuned bunch cars. Anyway. Idk why but my h23a just falls on its face at about 6k. It will spind tires easy in 2nd but then it just looses power. It's not dyno tuned. But I started w the Hondata map. Street tuned air fuel ratio . To mid 12's. but no matter what I do why the wot ignition from 15-35 degrees I've tried,, and it just aint right. Has rmf rep header nice intake pipe. So. I know it needs a true dyno tune. But I know something just ain't right. It should pull way different then it does even on the basemap , so trying get it figured out b4 I spend 400$ to rent the dyno time. Sorry for long *** post. Or can some one send me a base map they no wrked decent ? I did have to really mess w the h22 map alot just to get it to run,, ?? Lol. Doubt i'll get any help on here but. Worth a shot
I might be able to help you.. Are you sure everything is wired and functioning.. Sounds like no vtec.. Did you set vtec @3k and see if it is engaging?
Old 04-13-2013, 07:46 PM
  #852
1funryd's Avatar
Have you checked www.pgmfi.org??
and also www.xenocron.com
Old 04-13-2013, 10:59 PM
  #853
ilovejdm's Avatar
Originally Posted by ESP.net
Well I believe the injector nose is different and injector diameter on the blue top so I would say it is easier to use a normal H22 intake manifold
Same as H22A4
Turbo the Wagon and your easily at 300-350 hp on moderate boost.
Yeah sure if you feel like blowing a ton of money to be faster than a stock Legacy B4. The amount of money you spend on a turbo kit you could have bought the legacy as a second car lol
Old 04-29-2013, 03:18 AM
  #854
schmitty915's Avatar
Search isn't working right now -
What specs do I use for a valve lash adjusment?
EDIT - nvm found it
Old 05-06-2013, 11:24 PM
  #855
niatsi's Avatar
the lash adjustment in the honda service manaul reads .006-.007 intake and .007-.008 ex, the high and low is for highest and lowest setting no higher than .007 on intake and no lower than .006 same for ex. feel between the cam lobe and rocker with each cylinder at tdc use you cam marks to help start with #1 at tdc and then turn the crank counter clock wise to do cylinder 3 then 4 then 2. i just did this on my h22 and it runs 100 times smoother even stoped the chatter
https://honda-tech.com/forums/honda-prelude-4/need-consistant-info-h22-valve-lash-adjustment-3032700/
There you go.
Old 05-16-2013, 05:45 PM
  #856
jsinher3's Avatar
i started to refreshing the JDM H23a Distributor and ran into two problems i cant find the right rotor for it and when i tried to convert it from OBD2 to OBD1 with a jumper harness but i ran into a problem. can anybody help me out please. this swap is going into a ef..
Old 05-16-2013, 06:25 PM
  #857
ESP.net's Avatar
I forget what model possibly 90-91 dx/lx but whatever 90-93 Accord that is internal coil. The coil/igniter/rotor/distributor cap should be the same.
Old 05-16-2013, 06:53 PM
  #858
jsinher3's Avatar
thanks but how I wire up this obd2 dizzy to obd1? I brought a jumper harness but it doesnt work with it..
Old 05-17-2013, 01:17 AM
  #859
1funryd's Avatar
So the adapter you bought does not plug up?
Pics please for a better explanation, this is the internet.
Old 05-17-2013, 04:25 AM
  #860
jsinher3's Avatar
i brought this adapter
and you see close only the big plug connects theres nothing for the smaller plug to connect to... is that going to be a problem? and does anybody on here have a wire diagram so i can just depin the stock dizzy plug and add the the obd1 plug on to it?
Old 05-17-2013, 02:39 PM
  #861
jsinher3's Avatar
bump heres better pictures of the plug from the dizzy. im not sure how i should wire this up to obd1 w/internal coil, can anybody help me out please..
Old 05-20-2013, 06:30 PM
  #862
HiProfile's Avatar
Check out this post:
https://honda-tech.com/forums/showpo...8&postcount=53
You add one wire, move another wire, and connect those two to the 2-pin obd1 plug.
Old 05-21-2013, 07:37 PM
  #863
jsinher3's Avatar
thanks man life saver!
Old 07-04-2013, 01:40 PM
  #864
TheKeymaykr's Avatar
Soooo......does nobody have a pinout for the PCF ecu? I've been searching everywhere for a solid week and found nothing. Might end up removing and selling the H23A
Old 07-15-2013, 07:15 PM
  #865
Acg123's Avatar
I have a actual helms for this motor. It is in Russian though. I ran a pdf program and made it searchable so you can go to Google translate ;English to Russian; type what you want and copy paste to search in pdf. Can I post attachments? I did this swap in my 90 cb7 and just kept my f22auto with tcu as 01 tranny wouldn't fit and didn't have fundage for manual swap. Runs great decided to just keep it auto for now. Much faster than my f22. Lol
Old 10-01-2013, 10:05 AM
  #866
kingofbattle909's Avatar
mind =
great info here!
I missed the part about the cams,.. same as type s??
Old 10-01-2013, 11:41 AM
  #867
Sparksman's Avatar
Originally Posted by kingofbattle909
mind =
great info here!
No, there mild cams almost same as base h22a, may even share same part#. This thread has alot of misinformation as well as good info....
Type-s has way more aggressive cams/valvetrain and is 11.0:1, H23V is only 10.6:1
Old 11-13-2013, 06:13 AM
  #868
slobalt716's Avatar
i just have 2 quick questions, what valve cover gasket do i use and what spark plugs do i use? 00-01 h23a
Old 11-13-2013, 09:58 PM
  #869
1funryd's Avatar
Simple.
The head is a stock H22 head, so use those parts.
Old 11-14-2013, 09:21 AM
  #870
ESP.net's Avatar
mind =
great info here!
JDM H22 Cams same H23V BT (Same Part#)
I have measured the cams as well to compare to F20BMT/EuroR/TypeS they are smaller. Swapped cams in my JDM DC2 with PS for F20BMT/EuroR/TypeS with matching valvesprings/retainers 210 hp 174 trq
Old 11-19-2013, 06:40 AM
  #871
slobalt716's Avatar
is the h23a knock sensor the hame as the h22?
Old 01-08-2014, 04:26 PM
  #872
Civic44's Avatar
I just ordered my blue top and can't wait to install it in my 2000 Civic Si!
Is there a parts list for what is needed for the manual timing belt tensioner conversion? There is a list of hardware on page 15 of this thread, but I believe that is for people who already have an H-series motor with a manual tensioner that they wish to re-use. Thanks!
Old 04-13-2014, 06:37 AM
  #873
Carlos Mcg's Avatar
Default JDM H23A Vtec Blue Top Mystery Motor, True Facts, Questions?
Hey guys working on a breakdown of the JDM H23A myself seeing that my piston rod bent.
I noticed that the size of the mains from the JDM H23 to the H22A4 are completely different sizes.
There is no squirters in the H23 but potential to add them in the block
There is a little difference in the guard for the crankshaft
The piston rods are the big difference. They do not use the six point nut to keep the rod on the crankshaft instead they use a 10 point bolt to hold it in.
I'm still doing the breakdown but I should have more information later today with pictures if not soon.
Old 04-13-2014, 03:13 PM
  #874
Sparksman's Avatar
yes
Buy a KaizenSpeed tensioner and call it a day.
The H23aV has 55mm mains and H22A4's pending on year it came had 50mm AND 55mm mains so you need to be more specific on exactly which year A4 before saying they are different. They only came in two sizes.
And PS if you are replacing your bent rod dont get a H23A1 rod without replacing ALL of them. H23aV blue-top have .0020" shorter rods then the A1's.
Also you can install oil squirters on ANY H series block. The H23aV and even the H23A1 have oil passages in the rods them selves that help lubricate. So although you can install some, not 100% needed.
Old 04-15-2014, 08:16 AM
  #875
jsalas623's Avatar
Would I be able to use the stock H23A Vtec Fuel Rail w/ my h22a4 Fuel Injectors? Just was curious because the H23a Vtec Fuel rail looks like a nicer billet aluminum look to it. Ive tried searching but didnt come up with an answer.
Quick Reply: JDM H23A Vtec Blue Top Mystery Motor, True Facts, Questions?
