hood latch broken... how to get hood open
Old 07-02-2008, 11:23 PM
SOKDO's Avatar
Default hood latch broken... how to get hood open
my friend had his EG broken into at PCC today and they broke the hood latch cable where it meets the latch under the hood. what can he do to open his hood now that he has basically... no cable???
any help would be much appreciated.
Old 07-03-2008, 07:03 AM
importuner_sc's Avatar
Default Re: hood latch broken... how to get hood open (sokdo321)
you could take off the front bumper and unbolt the latch...the latch would still be connected but you could get the hood open...just a thought. good luck.
Old 07-03-2008, 07:53 AM
SOKDO's Avatar
Default Re: hood latch broken... how to get hood open (importuner_sc)
that's a negative because there's screws for the bumper under the hood. obviously.. you haven't taken off your bumper before.
Old 07-03-2008, 08:01 AM
sde780's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importuner_sc &raquo;</TD></TR><TR><TD CLASS="quote">you could take off the front bumper and unbolt the latch...the latch would still be connected but you could get the hood open...just a thought. good luck.</TD></TR></TABLE>
FAIL
Old 07-03-2008, 08:07 AM
hondroid015183's Avatar
Default Re: hood latch broken... how to get hood open (sde780)
It might end up costing you a grill as well to get in to the hood latch.
Old 07-03-2008, 08:17 AM
SOKDO's Avatar
Default Re: hood latch broken... how to get hood open (hondroid015183)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondroid015183 &raquo;</TD></TR><TR><TD CLASS="quote">It might end up costing you a grill as well to get in to the hood latch.</TD></TR></TABLE>
grill on a EG? 92-95? man... it just goes to show you how many people don't know about honda's. if your referring to the bottom grill... it is not a separate piece from the bumper so it would have to be cut out. there is no upper grill on EG's fyi unlike the 96-00 models.
Old 07-03-2008, 08:24 AM
BlackoutVTi's Avatar
EDIT: try jacking it up and seeing where to go from there. Do you have a jack available?
Old 07-03-2008, 08:31 AM
daniel990836's Avatar
Location: born and raised in norcal, livin in houston, tx, 77073
jack it up and see where it goes from there. pretty sure that their be to much crap in the way before u get to the latch though lol. especially if he still has ac and power steering. did they break the whole latch off or is the little black piece still there? is it just wire thats left? i would recommend tracing the latch wire and yanking on it with some pliers or something. how the hell they break the latch? lol
Old 07-03-2008, 09:15 AM
instructor74's Avatar
Default Re: hood latch broken... how to get hood open (daniel990836)
your best bet is to jack up the car remove the under pan just behind the front bumper and try to reach up between the header and core support. If any of the cable is still left you could remove the lf inner fender and try openning it from there. good luck
Old 07-03-2008, 11:17 AM
instrument's Avatar
i had the same sort of thing happen to me, and follow what instructor/daniel said, removed the splash guard and use a metal clothes hanger and try to hook the little latch deal that the cable was previously attached to.
Old 07-03-2008, 11:23 AM
Stouts 'n' Scotch
wiZCo's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">i had the same sort of thing happen to me, and follow what instructor/daniel said, removed the splash guard and use a metal clothes hanger and try to hook the little latch deal that the cable was previously attached to.
You could also try to use a thin-tipped pry bar or a loooong screwdriver.
Old 07-03-2008, 12:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sokdo321 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Sorry to get you all upset bud, I thought you were talking about EK`s. You need to relax. I do know EG`s because I have owned three of them, as well as an EF, two EK`s and a first, second, and third gen integra. And I build new Hondas every day for my job. I might know a thing or two about them, or maby I don`t.
Thanks
Modified by hondroid015183 at 5:03 PM 7/3/2008
Old 07-03-2008, 12:58 PM
4drkidd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daniel990836 &raquo;</TD></TR><TR><TD CLASS="quote">jack it up and see where it goes from there. pretty sure that their be to much crap in the way before u get to the latch though lol. especially if he still has ac and power steering. did they break the whole latch off or is the little black piece still there? is it just wire thats left? i would recommend tracing the latch wire and yanking on it with some pliers or something.</TD></TR></TABLE>
+1
Old 07-03-2008, 01:24 PM
Hanmin's Avatar
there has to be some cable left, dig your hand between the grill through the bumper and up, or get someone with a smaller build to do it, tell them to look for the cable, it still might be there. just find it and tug, if its not cut then either follow the cable to see if its damaged, if it is then just cut the cable anywhere in the middle, slide the black cover off and pull the metal string.
Old 07-03-2008, 08:36 PM
oh my bad i thught they were just clips...that you could wedge a screw driver under but i guess thats the kind of reaction you can expect on honda tech when you try to help.....
Old 07-06-2008, 01:42 AM
SOKDO's Avatar
i didn't ask anyone to GUESS on what to do and people that don't read the details about the post about what year the car is... i wanted someone who has knowledge on this situation. i stated clearly that there was no cable left and where to go from there. if you don't know... don't answer.
Old 07-06-2008, 03:04 AM
Jonnyb5's Avatar
Not that this would answer your question on how you guys would do it but... Take it to a honda shop and have them figure it out. im sure they have come across the problem many times because by the looks of it a good number of people done know?
Old 07-06-2008, 03:27 AM
omghiii's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sokdo321 &raquo;</TD></TR><TR><TD CLASS="quote">i didn't ask anyone to GUESS on what to do and people that don't read the details about the post about what year the car is... i wanted someone who has knowledge on this situation. i stated clearly that there was no cable left and where to go from there. if you don't know... don't answer. </TD></TR></TABLE>
Wow since when are people who are asking for help such bitches?
Figure it out yourself then asshat
People these days I swear
Old 07-06-2008, 08:05 AM
formby's Avatar
dont get upset at the OP. he is right. if you have dont know dont answer. why have him mess up his car or waist his time on misinformation.
the asshats are the idiots who are just giving suggestion to give them. not knowing what th F the are saying...
like stated above take out the splash guard and use a hanger to pull the latch.
Old 07-06-2008, 04:27 PM
Hanmin's Avatar
its been 3 days and you still havent figured it out. Just play with it, stick a flatheat in there and pry it open.... doesnt take a genius to get the hood unlatched....
Old 07-10-2008, 05:08 PM
Default Re: (Jonnyb5)
damn.....what a dick !!!! lol cant even appreciate a little help. but whatever lol sucks for ur friend.
Old 07-10-2008, 05:11 PM
EquipedWithVtec's Avatar
Default Re: (daniel990836)
BMFH anyone?
Old 07-10-2008, 05:13 PM
and i dont understand how the hell there aint no wire left........i mean its one thing that it's not visible but the wire runs all the way to the latch. trace the wire........
Old 07-10-2008, 05:18 PM
are you sure they broke the cable OR did they brake the handle i work in a shop and someones hood handle was broken all i had to do was use pliers to pull the cable back enough to pop the hood.
BlitzSix
07-16-2018 05:22 AM
julianbc2
05-22-2010 01:16 PM
AznJdmKid
07-23-2009 12:29 PM
brentmc79
01-14-2005 09:23 AM
stealth89hatch
10
11-12-2004 08:12 AM
Quick Reply: hood latch broken... how to get hood open
