CRX S2000 AP2 Cluster Write-up Info
Old 06-15-2008, 12:47 AM
xalents23's Avatar
Default CRX S2000 AP2 Cluster Write-up & Video
Just wanted to share with all of you that own a CRX. This is my S2000 AP2 cluster swap write-up in my 1991 CRX SI. Hope all of my info helps you out. If you ever wanted to do the S2000 cluster swap in your 1990-1991 CRX. This info should help you out. On getting the AP2 S2000 cluster working in your CRX.
These are the items you will need to make the AP2 S2000 cluster work in a CRX. AP2 cluster, Speedohealer V4 with universal harness, Modifry ECT Module, and a VSS Electronic speed sensor from a 1992-1995 Civic.
I have listed my wiring write-up below. And all the links to websites that, I got my info/stuff from. If you need any help feel free to pm me. I will try my best to answer your questions. Only thing not working on my AP2 cluster is the coolant gauge. I should have that up and running soon. I listed three videos of my AP2 cluster at the end of this post enjoy.
1990-1991 CRX cluster pinouts: 2004-Present AP2 S2000 pinouts:
1. Left Turn - Green/Blue <-------------------> 1. Left Turn-Green/Red 30 Pin
2. High Beam - Red/Blue <--------------------> 2. High Beam-Red/Yellow 22 Pin
3. Coolant Temp - Yellow/Green <--------------> 3. Temperature-Yellow/Green 30 Pin
4. Gauge Light Brightness - Red/Black <---------> 4. Lights On Input-Red/Black 22 Pin
5. Guage Lights - Red <------------------------> 5. Dash Lights Dim Out-Red 22 Pin
6. Door Open Light - Blue/Yellow <--------------> 6. Door Open-Black/White 22 Pin
7. E-Brake - Green/Red <-----------------------> 7. Parking Brake-Blue/Yellow 30 Pin
8. Oil Pressure - yellow/red <-------------------> 8. Oil Pressure-Yellow/Red 30 Pin
9. Check Engine Light - Green/Orange <---------> 9. Chk Engine-Green/Orange 30 Pin
10. Switched 12v Power - Black/Yellow <-------> 10. Ignition Key-Red/White 30 Pin
11. Battery/Alternator Light - White/Blue <-----> 11. Alternator-White/Blue 30 Pin
12. Tachometer - Blue <----------------------> 12. Tachometer Input-Blue 30 Pin
1. Ground - Black <--------------------------> 1. Ground 2 Wires-Black 22 Pin
2. Vehicle Speed Plusar - Yellow/Red <--------> 2. VSS Speed Sensor Signal Wire.
3. Empty <-----------------------------------> 3. Empty
4. Trunk - Green/Black <----------------------> 4. Boot Open Light-Blue/Black 22 Pin
5. Seat Belt - Blue/Red <--------------------> 5. Drivers Seat Belt-Blue/Red 30 Pin
6. Fuel Gauge - Yellow/White <-------------> 6. Fuel Gauge-Yellow/Black 30 Pin
7. Switched 12v Power - Yellow <----------> 7. 12V Ignition Supply-Yellow 22 Pin
8. Right Turn Signal - Green/Yellow <--------> 8. Right Turn-Green/Yellow 30 Pin
*To turn off the ABS light on the AP2 S2000 Cluster. Just ground the Blue/Red wire at location B20 on the 30 pin connector on the AP2 cluster.
*To remove the SRS/Air bag light. Just connect the Pink wire on the AP2 cluster to a constant 12V source. The AP2 Pink wire is at location B19 on the 30 pin connector on the AP2 cluster. I just connected the Pink wire to my positive battery.
*To keep the Clock Memory on the AP2 cluster. Connect the White/Red wire on the AP2 cluster to a constant 12V source. The Clock Memory wire is located at A10 on the 22 pin connector on the AP2 cluster. I connected the White/Red wire to my positive battery.
<U>Speedohealer Wiring Info:</U>
1. Red - Power
2. Black - Ground
3. Green - Goes to the speedo input wire on the S2K cluster Blue/White wire location B7 30 pin connector.
4. White - Goes to the speed sensor signal wire/Electronic VSS Speed Sensor signal wire.
<U>Modifry ECT Module Info</U>:
http://www.modifry.com/products/ect/ap2.htm
<U>1992-1995 VSS Speed Sensor Wiring Info:</U>
-Remember to make two wires for the VSS speed sensor signal wire. One wire will go to the Speedohealer White wire. And the Second one will go to the CRX Speed Pulsar Yellow/Red wire.
<U>Links to where you can get the Speedohealer, Modifry ECT Module, S2000 AP2 Cluster, and VSS speed sensor:</U>
<U>-Speedohealer V4 With Universal Harness:</U> http://www.procycle.us/main/speedo_healer.htm
<U>-Modifry ECT Module:</U> http://www.modifry.com/products/ect/ap2.htm
<U>-AP2 Cluster:</U> You can try Ebay, http://www.Honda-Tech.com in the classifieds, or dealer (expensive).
<U>-1992-1995 Civic VSS Speed Sensor -</U> I got mine from the Junk Yard for $40. You can also get one from Ebay. Or at your local Honda dealer which will run you about $200.
<U>1990-1991 CRX Cluster Plug Pinouts:</U>
<U>2004-Present AP2 S2000 Cluster Pinouts:</U>
http://www.marklamond.co.uk/pr...r.pdf
<U>-My 1991 CRX SI with the AP2 S2000 Cluster installed. I have not received my lexan pieces in to cover up the gaps on the cluster:</U>
<U>Videos of My AP2 Cluster can be found on youtube.</U>
Old 06-15-2008, 03:00 AM
EF9yee's Avatar
Default Re: CRX S2000 AP2 Cluster Write-up Info (xalents23)
Sticky this mother faaawwking ****
The following 2 users liked this post by EF9yee:
Old 06-15-2008, 08:08 AM
doublethink's Avatar
wait a minute.
2008, informative, knows how to speak english properly, faq worthy thread.
if it starts raining frogs or locusts too im fu*kin out!!
all kidding aside, awesome post
Old 06-15-2008, 08:24 AM
thevtecnician's Avatar
Default Re: CRX S2000 AP2 Cluster Write-up Info (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">wait a minute.
all kidding aside, awesome post </TD></TR></TABLE>
Lol seriously!
Thanks for taking the time to do this
Old 06-15-2008, 11:20 AM
abnaasefmb's Avatar
Default Re: CRX S2000 AP2 Cluster Write-up Info (thevtecnician)
great job
Old 06-15-2008, 11:29 AM
blaak-crx's Avatar
Default Re: CRX S2000 AP2 Cluster Write-up Info (abnaasefmb)
Let's see a video of this.
Old 06-15-2008, 10:27 PM
ozrednsx's Avatar
Default Re: CRX S2000 AP2 Cluster Write-up Info (blaak-crx)
nice! too bad i just spent 180 on a dscustom
but great writeup!!!
Old 06-15-2008, 10:53 PM
Red_ED8's Avatar
Default Re: CRX S2000 AP2 Cluster Write-up Info (ozrednsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9yee &raquo;</TD></TR><TR><TD CLASS="quote">Sticky this mother faaawwking **** </TD></TR></TABLE>
X2
Old 06-16-2008, 12:13 AM
xalents23's Avatar
Thanks for the comments guys. I just uploaded some videos for your viewing pleasure. And added some more info on the swap in the first post I made.
Old 06-16-2008, 08:09 AM
Mr.Death's Avatar
Default Re: (xalents23)
Awesome post. I need one of these BAD!
Old 06-16-2008, 09:44 AM
BiG Chris's Avatar
good info if i dont do this ill just go with a dc2 cluster
Old 06-16-2008, 11:33 AM
Red_ED8's Avatar
Default Re: (BiG Chris)
In your video's after having the car started for about 20 sec's your temp gauge reads hot? or am I just reading that wrong?
Old 06-16-2008, 11:44 AM
sinepome's Avatar
Default Re: (Red_ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">In your video's after having the car started for about 20 sec's your temp gauge reads hot? or am I just reading that wrong?</TD></TR></TABLE>
x2
it looks really nice though. good write-up
Old 06-16-2008, 11:51 AM
hondaownr's Avatar
I'll be using this thread real soon.
This should be stickied
Old 06-16-2008, 01:00 PM
dr_latino999's Avatar
Default FV-QR
I've bookmarked this thread for future reference.
Old 06-16-2008, 01:23 PM
xalents23's Avatar
As mentioned in my first post. Everything is working on my AP2 cluster except for the coolant gauge. I couldn't upload the Modifry files because my laptop screen died out on me. So, I am waiting on my laptop backlight to come in. Then I can upload the files and mess with the modifry numbers to get my coolant gauge working.
Old 06-16-2008, 03:47 PM
Red_ED8's Avatar
Old 06-16-2008, 05:33 PM
AllMotoRex's Avatar
Great post.. very useful.. STICKY!!
Old 06-30-2008, 08:43 AM
atarigamer01's Avatar
Default Re: (AllMotoRex)
Any write ups for ap1 cluster?
Old 06-30-2008, 09:39 AM
xalents23's Avatar
Default Re: (atarigamer01)
Sorry, I don't have the write up on an AP1 cluster. But, I can pm you the AP1 info if you like.
Old 07-02-2008, 06:04 PM
alscrx's Avatar
Has anyone tried fitting the oem plastic cluster cover on the s2000 cluster???
If it fits on the cluster then the cluster hood would look better!
I have yet to play with this, but when i do i will post pics of different mounting options!
Old 07-03-2008, 09:33 AM
Nerologic's Avatar
bump because i might do this soon...
Old 07-03-2008, 03:17 PM
harmonator84's Avatar
Default Re: (Nerologic)
Really nice! Thanks
Old 07-03-2008, 03:44 PM
Crazy Honda Guy
Deetz's Avatar
Default Re: (harmonator84)
I can understand many people like to be different and all, and thats why the interest. Personally i don't like the whole digital image, as well as fitment.
Good job on the write up though, it'll help a lot of people out who are interested in the mod.
Old 07-03-2008, 11:14 PM
The Boot
Smokinsax's Avatar
this is something that I have wanted to do for a long time now. great stuff
Quick Reply: CRX S2000 AP2 Cluster Write-up Info
