help,left turn signal,parking lights and tail lights won't turn off!!
Old 06-13-2008, 07:49 PM
vteckid79's Avatar
Default Help!!!!!left turn signal,dash light,parking lights and tail lights won't turn off!!
Hey guys,so i bought a wrecked 2000 prelude sh and the right turn signal,parking lights, dash lights and tail lights won't turn off when i turn the car off,i have to disconnect the battery,it has a viper alarm and an amp kit hooked up, i have checked the fuses,connectors,bulbs and have been trying to remove the mitsuba fr-3501 flasher to check and see if thats the issue even though i don't understand why the tails, parking lights,and dash lights stay on,any help would be awesome,does anyone know how to remove the mitsuba flasher,i did depress the bottom tab with a screwdriver but no luck getting it out.seems like a ground issue but can't find ****.
Modified by vteckid79 at 1:19 PM 6/15/2008
Old 06-21-2008, 02:07 PM
GraphiteMW's Avatar
Default Re: Help!!!!!left turn signal,dash light,parking lights and tail lights won't turn off!! (vteckid79)
Sounds like a definite wiring issue to me. Check the wiring and grounds.
Old 06-21-2008, 06:07 PM
jdm_rb20's Avatar
I'd start looking at a common area for those lights....first thought would be under the carpet in the trunk where those lights are wired. or...
parking light could be a bad bulb somewhere?? But the dashlight will come on ALWAYS if the parking lights are on. And if your parking lights are on, then you have taillights on. So really a single problem can cause all of those but the turn signal, unless the turn signal is shorted to the parking lights and lighting the dash in a backwards kind-of-way.
--TJ
Old 06-24-2008, 11:25 PM
vteckid79's Avatar
Thanks for the feedback guys,ive checked and unhooked all after market audio and alarm,the wiring looks a little shady,all new wiring up front maybe?
KrazeeDav
05-27-2018 05:32 PM
!!miguel!!
12-03-2016 02:43 PM
my93civiceg
02-08-2009 11:04 PM
Pandahatch
11
12-08-2004 01:49 PM
Quick Reply: help,left turn signal,parking lights and tail lights won't turn off!!
