ECU Code 8? Question - Top Dead Centre Sensor. TDC
Old 06-02-2008, 04:15 PM
rival12's Avatar
Default ECU Code 8? Question - Top Dead Centre Sensor. TDC
From the searches i did, i think the sensor may be inside the distributor...anyone know which one it might be?
Old 06-02-2008, 04:32 PM
rival12's Avatar
Default Re: ECU Code 8? Question - Top Dead Centre Sensor. TDC (rival12)
http://media.honda.co.uk/car/o...2.pdf
This kind of helps.
Old 06-02-2008, 06:26 PM
jaywongwong's Avatar
the tdc sensor is inside the distributor, but its not shown in that pic. dont think your ment to change it. think youll have to change the dist.
Old 06-02-2008, 07:35 PM
90sedan's Avatar
Default Re: ECU Code 8? Question - Top Dead Centre Sensor. TDC (jaywongwong)
You'll need to replace the distributor assembly. The sensor is not sold separately.
It's much easier to swap out the entire distributor rather than cutting and soldering in another used sensor and then trying to adjust the air gap perfectly. I've done it before and it has worked just fine, but it's not something i would recommend.
Old 06-02-2008, 10:30 PM
rival12's Avatar
Default Re: ECU Code 8? Question - Top Dead Centre Sensor. TDC (90sedan)
Thanks, i just found this site actually, really cheap distributors.
http://www.hondadistributors.net/
I think this will be the cheapest route.
SIDreamer
05-02-2011 09:51 AM
$C-BRAM$
02-12-2010 09:34 AM
YellowR2000x2
03-04-2005 04:29 PM
quik89
11-30-2003 06:43 PM
fast-rex
01-27-2003 03:06 PM
Quick Reply: ECU Code 8? Question - Top Dead Centre Sensor. TDC
