ARP TORQUE SPEC AND PATTERN
Old 04-17-2008, 01:39 AM
avotegra's Avatar
Default ARP TORQUE SPEC AND PATTERN
WHAT TORQUE SPEC IS FOR THE ARP HEAD STUD....ON A B18C1...I SEE 60 BUT THE PAPER SAY 80. AND WHAT IS THE Pattern on who to torque the head to the block.........like.......what needs to be torque first.........please help..........
Old 04-17-2008, 03:50 AM
MidShipCivic's Avatar
60ft lbs is when using ''ARP Moly Lube'' and 80ft lbs is when using engine oil.
Torque in 3 steps 10-20 wait for a bit (15-20mins) loosen then do it again all the way to a max of 60ft lbs. ( I do this process 3 times on heads & mains) Reason is because stud stretch for each individual stud is irregular. You'll notice after torquing all heads studs then loosening them that you don't use the same force loosening them.
Torque sequence image below.
Old 04-17-2008, 06:27 AM
Eklsv-t's Avatar
Default Re: ARP TORQUE SPEC AND PATTERN (avotegra)
we torque my gsr head with arp head studs 70ilb and it holds up fine, it ran hard at the track and daily driver boosting 15pounds
Old 04-17-2008, 08:55 AM
patrick4588's Avatar
yeah i put mine at 70, thats what laskey racing recommends i believe
Old 04-17-2008, 01:29 PM
avotegra's Avatar
Default Re: (patrick4588)
are you sure....cuz on the paper that arp send it........it says 80 with the lube and 85 with 10w30 or 5w30 cant remember..........if it is then 60 is too low..........
Old 04-17-2008, 09:29 PM
i know for a fact the mains are 70. i have a brand new box of head studs in my room, ill go check and see what it says for ya
Old 04-17-2008, 09:33 PM
ok, quoting from the paper:
preload torque recommendations
A)torque values are based on 75% of the fasteners yield strength. use the manufacturers torque sequence but do not use the engine manufacturers torque specs. torque the nuts to 70 ft lbs for arp moly assembly lubricant or torque to 85 ft lbs with 30wt motor oil.
b) due to the expansion rate of ALUMINUM, it is recommended that the torque should be 65 ft lbs with arp moly assembly lubricant.
Old 04-17-2008, 09:52 PM
chubz0r's Avatar
So, we should torque them to what then? Lol, so many different answers in here. Also, sorry if this is noob but its my first time with the head off, do the washers go between the head and block? or between the head and nut?
And do I just hand tighten the studs into the block, then torque it down with the head? What is the correct way to do so?
Sorry for thread jack. Thanks in advance.
Old 04-17-2008, 09:57 PM
the washers go between the head and nut... lets use a little common sense. use a thread chaser to get any gunk out of the threads and hand tighten the studs in. then torque it in sequence first to 20 ft lbs, then 40, then the final 70 if using arp lube. if you use engine oil, go 30, 60, 85.
Old 04-17-2008, 10:37 PM
chubz0r's Avatar
Lol, thats right, I dont know how that got into my head. Ah, I saw a pic earlier of a block with the washers around the studs resting on the deck, just threw me off i guess. Lol.
Thanks.
Old 04-18-2008, 12:06 AM
avotegra's Avatar
Default Re: (chubz0r)
what........i though due to the expansion rate of ALUMINUM, you said 60....now 70..........please what is the right way of doing this......need to know.......dont wanna over tight or too lose..........
Old 04-18-2008, 03:43 AM
:Sighs: mannn just go and do what one of us said or just FOLLOW what tq spec it says on the paper with ARP MOLY LUBE....
or
Just do w/e the hell you want.
Old 04-18-2008, 04:55 AM
Eklsv-t's Avatar
Default Re: (MidShipCivic)
Torque it 70 with arp molylube bro. Trust me bro, My friend, me, torque 70 and boost 15 pounds daily
Old 02-26-2009, 03:22 PM
HELLO,GOOD MORNIN'
ahobbs's Avatar
im puting this in the FAQ. just needed to bump it for my subscribed items
Old 02-26-2009, 03:47 PM
b20beast83's Avatar
when hand tightening it, wont ie be loose?
Cant vibrations make it slack
Old 02-26-2009, 05:02 PM
bigD's Avatar
When tightning by hand I like to torque the studs to 10ft lbs
Old 02-27-2009, 12:34 AM
hondaapi's Avatar
Yesterday I also wanted to assemble some blocks.
The paper with the 80 Ft.lbs tourque specs seems to be new in some ARP boxes.
In the older boxes they recommended something else.
Maybe they changes the material or they notices problems with the old lower tourquw specs.
Does someone know more about it?
Old 02-27-2009, 10:09 AM
HELLO,GOOD MORNIN'
ahobbs's Avatar
talked to a few people that build motors and used these often and they got 78-80 with molly lube
Old 02-27-2009, 10:18 AM
hayabusa160's Avatar
i did 76 on a ls motor. runs great. lol
Old 02-27-2009, 11:07 AM
Ls_dx's Avatar
I do steps with a final of 65-70 with moly lube on the nuts washer and stud thread.
Old 03-29-2009, 01:36 PM
justinsane's Avatar
I just got my head(b18c1) back from laskey racing. I bought the ARP Head Studs and Mike Laskey recommended I torque them to 80 ft/lbs in 3 step increments w/ ARP moly lube on the threads nuts and washers. Then retorque the bolts after 500-1000 miles or so. I even asked him if 70 was ok but he said "I would go ahead and take it on up to 80 ft/lbs with the moly lube"
Mike Laskey's opinion is basically the bottom line for me. Laskey's reputation speaks for itself.
Old 03-29-2009, 07:41 PM
HELLO,GOOD MORNIN'
ahobbs's Avatar
yes thats all right but the only thing is the re-torque. if your using a stock 3 ply headgasket there is not need to re-torque.
do 25-50-80 and your set.
Old 10-12-2011, 10:21 AM
eleon's Avatar
Location: southside brook nah,ease over..bang bang main..yadiiihh
Stud snapped at 70!!! Fml
Old 10-12-2011, 11:40 AM
sc34dc4's Avatar
I don't see how that's possible considering ARP's final torque spec is 80ft/lbs on their head studs when using thier moly lube. 25-50-80
Old 10-12-2011, 03:43 PM
Gunmetal_B20_Hatch's Avatar
x2
Ive never heard of an ARP stud breaking when torquing.
Quick Reply: ARP TORQUE SPEC AND PATTERN
