92-00 Civic - Does it Have Shocks, or Struts? I Want to Hear What YOU Have to Say.
Old 04-06-2009, 08:26 PM
  #26
batallic's Avatar
Default Re: (B18C5-EH2)
Originally Posted by spivt11
Yeah I remember this discussion awhile ago. In my opinion 92-95 Civics (what I have knowledge on) have struts in the front and shocks in the rear. The whole spring and shock combined makes a strut is an interesting point, but falls short when you look at a Honda parts list. I don't know... I definetely want to hear a definitive answer.
Juz incase u didnt know 92-00 civics have the same front shocks as with the 94-01 integra there rear are basically the same jus the ek has thinner lcas
Old 04-06-2009, 08:41 PM
  #27
93egSLEEPER's Avatar
Default Re: 92-00 Civic - Does it Have Shocks, or Struts? I Want to Hear What YOU Have to Sa
Struts. Period
Old 04-07-2009, 10:53 AM
  #28
buff1110's Avatar
struts on a civic
shocks are whats on the rear of my tacoma (front has struts)
Old 04-07-2009, 11:23 AM
  #29
infinitypro12's Avatar
Used interchangably among many autoparts. It happens. Yeah, there is a techincality but all in all...oh well.
Old 04-07-2009, 11:32 AM
  #30
brutekiller787's Avatar
does it matter what they're called. if you say shock an auto shop knows what you're talking about, same thing with strut.
Old 04-07-2009, 11:45 AM
  #31
Ksoulja's Avatar
Here's a great article for you guys.. http://www.team-integra.net/sections...?ArticleID=525
Also, I believe the newer honda cars have front macpherson struts such as the dc5, fg/fd civic while EKs, EGs, and DC2s have the double wishbone setup in the front.
Old 04-07-2009, 02:23 PM
  #32
D16Z6racing's Avatar
I think I called them shocks when I used to order from a shop. Shock or strut I always got the parts I wanted. Really that's what it comes to for me.....just make sure what I clicked on to order, is the right part when it shows up on my door step.
Old 04-07-2009, 03:05 PM
  #33
Resident Gearhead
BryanM.'s Avatar
Originally Posted by 93egSLEEPER
Struts. Period
The double wishbone suspension uses shocks.
Old 04-07-2009, 04:29 PM
  #34
crip's Avatar
It's a shock
Old 04-07-2009, 06:11 PM
  #35
alacard's Avatar
Holy non-definitive/unsuccessful/open argument, Batman!
Old 04-07-2009, 07:55 PM
  #36
redline870's Avatar
wrong! it uses struts. just because it doesnt have the mcpherson strut suspension doesnt mean that it doesnt use struts.
Originally Posted by crip
It's a shock
a strut is a certain style of shock so you are right in that way but if you want to be technical than its referred to as a strut.
UNLESS THE SPRING CAN BE REMOVED FROM THE VEHICLE WITHOUT THE REMOVAL OF THE SHOCK ABSORBER THAN IT IS A STRUT. IF THE SHOCK AND SPRING ARE REMOVED AS ONE SINGLE UNIT THAN IT IS A STURT S-T-R-U-T!!! A STRUT IS THE COMBINATION OF THE SPRING AND SHOCK ABSORBER IN ONE UNIT. END OF DISCUSSION.
Old 04-08-2009, 08:16 AM
  #37
fastrxu's Avatar
I think they're struts
why are mcpherson struts called macpherson "struts"?
the only difference is that ef,eg,and ek struts don't turn with the wheel
Old 04-08-2009, 08:42 AM
  #38
318 Curves, 11 miles
Vindicator9000's Avatar
My $.02
According to wikipedia, they're shocks. In a strut setup, the damper/spring are the main vertical structural component to the suspension, and the damper/spring assembly is known as a strut.
In a double wishbone setup like on the 92-00 civic, the knuckle is the main vertical structural component, and the damper is known as a damper or shock.
http://en.wikipedia.org/wiki/MacPherson_strut
Technically though, a damper or shock does exist in a both strut assembly and a double wishbone setup (assuming it doesn't use something crazy like torsion beams).
Old 04-08-2009, 09:22 AM
  #39
instructor74's Avatar
Originally Posted by Vindicator9000
My $.02
This was my thinking also.
Old 04-08-2009, 09:28 AM
  #40
HatchVX's Avatar
If the vehicle uses the shock spring combo to pivot on ( when turning the wheels) its a Strut. If its just used to hole up the car its a shock. 92-00 civics use shocks. 01 and up use struts.
Old 04-08-2009, 09:38 AM
  #41
Relic1's Avatar
spring - used to absorb energy
shock - dampening device used to resist motion
strut - shock + spring + some other integral part of the suspension. (balljoint, knuckle, upper a-arm, etc)
we have coilover shocks.
struts were introduced to the civic in 01.
Old 04-08-2009, 04:24 PM
  #42
redline870's Avatar
Originally Posted by Ice78transam
MacPherson struts. Plain and simple. We have a coil spring, and DAMPENERS. DAMPENERS are valved differently than SHOCKS because they perform slightly different tasks. SPRING+DAMPENER=MacPherson STRUT
wrong. mcpherson struts rotate when the wheel is turned. the struts in 92-00 civics do not rotate when the wheel is turned. the suspension in 92-00 civics is a double wishbone strut setup not a mcpherson strut setup.
wrong. if the shock absorber has a perch that the spring sits on then it is a strut! there are two different styles mcpherson and double wishbone. o and HatchVX a strut does not hold up the car, the spring holds up the car. theoretically if you take the struts completely out and leave the springs in place then the car will not sit any lower.
***many peoples arguments is that honda lists the part as a shock absorber, but what no one has realized is that even in the 01 and up civics which obviously have a mcpherson strut suspension the "strut" is listed as a "shock absorber unit." SO SHUT UP WITH THIS ARGUMENT. A STRUT IS A SHOCK ABSORBER! but if it has a perch for the spring to mount on then it is correctly called a strut.***
Old 04-13-2009, 01:30 PM
  #43
fastrxu's Avatar
In my own post I recognized the differences in the two.
I was just saying that they're both struts in my opinion, seeing as their only difference is whether they turn with the wheel or not
Old 06-03-2009, 08:18 PM
  #44
Swansen's Avatar
Originally Posted by redline870
a strut is a specific style of a shock absorber. a "strut" is a shock absorber with a coil spring mounted on and around it. a "shock" is mounted by itself seperate from the spring. although it is a shock the correct terminology is a "STRUT."
great answer
http://www.carbibles.com/suspension_bible.html
Old 06-03-2009, 08:31 PM
  #45
sp00ledbseries's Avatar
Old 06-03-2009, 08:54 PM
  #46
Froth's Avatar
Wow, this is nuts.
The technically correct way of determining shock from strut is pretty simple.
Struts Locate Suspension components.
Shocks Dampen/control movement speed of Suspension components.
SPRINGS are a suspension component and the 92-00 Civic's springs are located where they are because of the perches which are located on the STRUTS.
End. Of. Story.
-Froth
taimysho0
08-17-2008 05:12 PM
RighteousRyano
Suspension & Brakes
04-02-2007 07:38 PM
Flex1
10-13-2006 05:41 PM
AmbiguousCivic
09-05-2006 12:56 PM
DrunkPunk702
01-20-2003 09:15 PM
Quick Reply: 92-00 Civic - Does it Have Shocks, or Struts? I Want to Hear What YOU Have to Say.
