what kind of tranny fluid?
Old 04-08-2008, 09:12 AM
9cobra4's Avatar
Default what kind of tranny fluid?
i tried to search guys but didnt come up with a straight answer..i have a 1995 honda accord dx 4 cylinder non vtec five speed, i just need to know what kind of tranny fluid to use and how many quarts?...thanks in advance.
Old 04-08-2008, 10:04 AM
Hobbs94's Avatar
Default Re: what kind of tranny fluid? (9cobra4)
i would only use honda trans fluid. just og to your local dealer and ask for it in the parts department. i can't remeber how many quarts it holds though
Old 04-08-2008, 10:53 AM
AR-cb7's Avatar
yeep go honda but yea u need 4 quarts
Old 04-08-2008, 12:45 PM
YeuEmMaiMai's Avatar
Honda ATF or MTF only depending upon auto or manual
Old 04-08-2008, 01:09 PM
professorman's Avatar
Default Re: (YeuEmMaiMai)
I think he says that he has a 5spd. You use Honda MTF. You can use regular 10W30 Motor oil as well. I used that for a while, but I changed to Honda MTF when I changed my clutch.
Old 04-08-2008, 02:16 PM
extralargenog's Avatar
Default Re: (professorman)
Friction modified Syncromesh... Only the GM ****, NOT ANY other.
Old 04-08-2008, 07:20 PM
AR-cb7's Avatar
Default Re: (extralargenog)
go wit honda atf cuz it will act up after a while if u use sum 10w bull ****
Old 04-09-2008, 04:14 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: (AR-cb7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AR-cb7 &raquo;</TD></TR><TR><TD CLASS="quote">yeep go honda but yea u need 4 quarts</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AR-cb7 &raquo;</TD></TR><TR><TD CLASS="quote">go wit honda atf cuz it will act up after a while if u use sum 10w bull **** </TD></TR></TABLE>
what are you talking about???
4 quarts?? try only 2 qts.
ATF in a manual transmission, no... yes you can use 10w-30 in a manaul transmission though I prefer to use Honda MTF. Also, like stated above, some use GM syncromesh. I believe Honda also came out with their own version of syncromesh which you could use as well.
Old 04-09-2008, 06:59 AM
Default Re: (TouringAccord)
Ya know what else I had REALLY good luck with was straight 10-30 Royal purple..... Shifted smooth as silk
Old 04-09-2008, 07:25 AM
Heat's Avatar
Buy Honda manual tranmission fluid, you can get it from your local dealer for $5.90 per quart. You either need two, or just over two, quarts - just buy three and keep the receipt in case you don't need to tap into the third bottle.
You can also buy it online for around $4.50 per quart plus shipping if you don't have a honda dealer nearby. One site would be http://www.handa-accessories.com (on that site you can't select a '95 Camry - just choose a '98 and you'll see the manual transmission fluid under maintenance items).
Old 04-09-2008, 09:15 AM
flight50's Avatar
Default Re: what kind of tranny fluid? (Heat)
back before honda came out with tranny fluid they did use motor oil. and at the least use MTF. all though most dealers have gone with the newer version that has the syncromesh like additive. not all are carrying the newer version. it took mine like a year or so to carry it vs one in San Antonio or Cali, they had it like a year before that. its the one in the green bottle. i don't remember the part number though. it has solved a lot of peoples grinding problems and getting into gear problems.
Old 04-09-2008, 10:16 AM
9cobra4's Avatar
thanks alot for the replies.
Old 04-09-2008, 11:14 AM
Derek128's Avatar
Default Re: (9cobra4)
some honda dealer in us got the Honda MTF II
its semi syn & Made in Japan
Old 04-09-2008, 12:19 PM
Derek128's Avatar
Default Re: (Derek128)
btw here is the Honda MTF III (i don't think any dealer in US have them yet)
I found these pics from egay
the Item number is 130206221989
Old 04-09-2008, 12:21 PM
dleccord's Avatar
so that's the semi synch?
Old 04-09-2008, 12:27 PM
Derek128's Avatar
Default Re: (dleccord)
I know the MTF II is semi synch
but not sure about the MTF III
Old 04-10-2008, 11:05 PM
oo_phuong's Avatar
Default Re: what kind of tranny fluid? (flight50)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flight50 &raquo;</TD></TR><TR><TD CLASS="quote">it has solved a lot of peoples grinding problems and getting into gear problems.</TD></TR></TABLE>
would using castrol full syntec 10w30 motor oil be good?? would it lead to any grindin or gettin into gear probs??? im kinda goin through the same thing
Old 04-10-2008, 11:46 PM
TOO MUCH TORQUE's Avatar
Default Re: what kind of tranny fluid? (oo_phuong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oo_phuong &raquo;</TD></TR><TR><TD CLASS="quote">
would using castrol full syntec 10w30 motor oil be good?? would it lead to any grindin or gettin into gear probs??? im kinda goin through the same thing</TD></TR></TABLE>
dont use motor oil. why would you use it if honda has made dedicated tranny fluid? come on logic folks.
Old 04-10-2008, 11:54 PM
dleccord's Avatar
yeah but maybe they didnt think we would find a better substance?
Old 04-11-2008, 01:20 AM
oo_phuong's Avatar
Default Re: what kind of tranny fluid? (TOO MUCH TORQUE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">
dont use motor oil. why would you use it if honda has made dedicated tranny fluid? come on logic folks. </TD></TR></TABLE>
well not everyone know bout that, if you go to autozone, they'll say 10w30 motor oil for mt, well atleast for me thats what they said
Old 04-11-2008, 05:53 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">dont use motor oil. why would you use it if honda has made dedicated tranny fluid? come on logic folks. </TD></TR></TABLE>
logic tells me to look in the service manual and see what they list. So do that and let me know...
Old 04-11-2008, 06:06 AM
FInd a tall building, and leap from it in a single bound....
Old 04-11-2008, 10:33 AM
Default Re: what kind of tranny fluid? (extralargenog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extralargenog &raquo;</TD></TR><TR><TD CLASS="quote">
FInd a tall building, and leap from it in a single bound.... </TD></TR></TABLE>
if you want to use motor oil for your tranny, be my guess, im not stopping you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
logic tells me to look in the service manual and see what they list. So do that and let me know...</TD></TR></TABLE>
the manual says to use honda mtf or use motor oil if absolutely necessary, but change it out asap.
Old 04-11-2008, 11:19 AM
H-T Order of Merit
what manual are you looking at? Haynes/Chiltons or Helm/factory? Because I don't see anything about if absolute necessary or changing out asap.
Old 04-11-2008, 11:24 AM
I have....
Royal purple 10-30... Making over 600WHP... No issues (with the oil or failure due to it).
Quick Reply: what kind of tranny fluid?
