BAD strut
Old 03-20-2008, 06:05 AM
honda_ek9's Avatar
Default BAD strut
hey guys...gotta a noob question....i was wondering how much it would be to fix the bad srtuts...and what does it mean by bad struts.....thanks...
Old 03-20-2008, 06:46 AM
* B A N N E D *
spivt11's Avatar
Default Re: BAD strut (honda_ek9)
If you do the labor yourself than you could by struts anywhere from $100(stock) to $400(aftermarket). Indicators that struts are in need of replacement include a marked decrease in ride quality, changes in handling, play in the steering or uneven tire-wear. If any of these symptoms occur on your vehicle, it's a good idea to do a visual inspection of your struts to see if it may be time to replace them. Most struts are hydraulic, so check for signs of fluid leakage. Also check for visible damage to the outside of the strut's casing.
jooky5
09-02-2009 01:39 PM
SIMATIC
11-07-2004 03:40 PM
DJ_CARY
19
08-09-2004 12:26 PM
XxLuckyLisaxX
09-01-2003 11:31 AM
hellas
04-12-2003 02:31 PM
Quick Reply: BAD strut
