Automatic transmisson help
Old 03-09-2008, 08:50 PM
elitesi8's Avatar
Default Automatic transmisson help
I got a 00 civic auto today for cheap, problem is that when I start to take off it pulses and kinda studders, also after I get going it the D on the gauge cluster flashes like it has a some kinda fault. I didn't see anything in the manual about the flashing, anybody got any ideas?
Old 03-10-2008, 10:09 PM
elitesi8's Avatar
Default Re: Automatic transmisson help (elitesi8)
Old 03-11-2008, 10:34 AM
teal_dx's Avatar
is it an HX or an other model? HX's use a CVT automatic.
Old 03-11-2008, 11:17 PM
elitesi8's Avatar
Default Re: Automatic transmisson help (teal_dx)
dx
Old 03-11-2008, 11:21 PM
edmek4's Avatar
how much did you get it for?
Old 03-11-2008, 11:40 PM
elitesi8's Avatar
Default Re: Automatic transmisson help (edmek4)
1000 bux, help!
Old 03-11-2008, 11:44 PM
p10hlm's Avatar
does the vehicle have a check engine light on?
if so i predict a p0740/p0730 code in your future
hook up a scanner to your car and let us know what dtc's you have
Old 03-12-2008, 06:27 PM
elitesi8's Avatar
Default Re: Automatic transmisson help (p10hlm)
No check engine light
Old 03-12-2008, 07:03 PM
p10hlm's Avatar
so did you hook up any type of scanner to it?
Old 03-12-2008, 08:06 PM
elitesi8's Avatar
No, but whats the code p0740/p0730 faults you said that I would have?
Old 03-12-2008, 08:27 PM
JEGD16Z6's Avatar
Time for a 5-speed manual swap
Old 03-12-2008, 11:26 PM
elitesi8's Avatar
Default Re: Automatic transmisson help (JEGD16Z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JEGD16Z6 &raquo;</TD></TR><TR><TD CLASS="quote">Time for a 5-speed manual swap </TD></TR></TABLE>
Not worth the time and effort, I'm just trying to fix this so I can re-sell the car.
Old 03-12-2008, 11:42 PM
ifIexplode's Avatar
When D4 flashes it gives off a code, Just like the check engine light. If you do get a CEL the only thing its going to read is Autimatic transmission malfuntion. (with the paper clip trick anyway)
The D4 blinking is like a seperate Check engine light, But more like "Check transmission Code"
The two codes mentioned above are.
P0740- Problem in Lock-up Control System
P0730 -Problem in Shift Control System
But it could be anything really.
Whats the ATF look like?
Change it.
When D4 starts blinking have a OBDII scanner hooked up to it.
Old 03-22-2008, 02:25 PM
elitesi8's Avatar
Default Re: (ifIexplode)
I it is a HX, now what?
Old 04-09-2008, 07:39 PM
hiya vtec's Avatar
Default Re: (elitesi8)
I have the same problem with my 97 civic hx with a d16y8!!! I'm wondering what's the flashing d4 mean.
Old 04-09-2008, 07:58 PM
htechnician's Avatar
now if its a hx trans. its a c.v.t it has a chain belt that dives the trans so its like having a very very long 1st gear. now if it shuters taking of from a stop it means the trans fluid is contaminated and needs to be flush with about 9qts. of honda c.v.t fluid. now when the d light flashes it means that there is a fault in the trans. ,so you need a obd2 scanner to find what code it is and then let me know what it is or hit me up at jorge112686@yahoo.com and yes im a honda cert. tech
Old 04-09-2008, 09:42 PM
elitesi8's Avatar
Default Re: Automatic transmisson help (htechnician)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by htechnician &raquo;</TD></TR><TR><TD CLASS="quote">now if its a hx trans. its a c.v.t it has a chain belt that dives the trans so its like having a very very long 1st gear. now if it shuters taking of from a stop it means the trans fluid is contaminated and needs to be flush with about 9qts. of honda c.v.t fluid. now when the d light flashes it means that there is a fault in the trans. ,so you need a obd2 scanner to find what code it is and then let me know what it is or hit me up at jorge112686@yahoo.com and yes im a honda cert. tech</TD></TR></TABLE>
Thanks, I'll get it down loaded and let you know.
rgearin
Honda Civic (2001 - 2005)
06-11-2012 02:43 PM
Buddy10297
03-03-2007 02:51 PM
x1N5AN3x50ULJAHx
01-19-2007 10:55 PM
hondaeg95
23
01-20-2004 04:51 PM
D_TY3
12-12-2003 04:43 AM
Quick Reply: Automatic transmisson help
