TURBO OIL FEED & RETURN KITS, OIL RESTRICTORS!!!!!!
Turbo Oil Feed & Return kits, Oil restrictors!!!!!!
-4 Oil feed Kit
$55 shipped
* AN 4 Stainless steel braided hose 44" long.
* Two 1/8" to AN 4 straight male adatpers.
* One 1/8"npt plug.
* One oil sensor distribution block with correct 1/8"bspt male that screws into the block, 1/8"bspt female port for stock oil pressure sender to screw into, and two 1/8" npt female ports. One is used for the oil feed and the other can be used for a oil pressure gauge.
Comes assembled. Custom length orders no problem.
-3 Turbo Oil Feed Line Kit
$35 shipped
Standard Kit comes with:
* AN 3 Stainless steel braided PTFE hose 42" long
* Two 1/8" to AN 3 straight male adapter
* One oil sensor distribution block with correct 1/8"bspt male that screws into the block, 1/8"bspt female port for stock oil pressure sender to screw into, and one 1/8" npt female port.
*Add $8 for stainless steel oil restrictor with .035" hole(GT turbos).
*Add $8 for stainless steel 1/8" oil restrictor with .060" hole.
*Add $3 for 90 fitting coming off the turbo
Oil Return Line Kits
$50 SHIPPED Without flange, gasket, and bolt kit
$65 SHIPPED With flange, gasket and bolt kit
You get everything pictured plus:
* 1 ft. of steel braided line (topmount 2ft. add $5)
* 2 Lock washers and 2 allen metric head bolts (8mm-1.25 x 20mm)
Aluminum Flanges available for:
* GT series flange with gasket (GT25R/GT28R/GT30R/GT35R)
- Will also work with older t25 and t28 non ball bearing turbos
* T3, T3/T4, and T04 turbos
Kits also available for after market oil pans, K-series motors, S2000, SOHC VTEC, and d16y8. Please specify in your order.
Buy -3 both oil feed and return kits for $90 shipped!!!!
Buy -3 oil feed kit w/oil restrictor and oil return kit for $98 shipped!!!!
Buy -3 oil feed kit w/oil restrictor and topmount oil return kit $103 shipped!!!!
Buy -4 oil feed kit and oil return kit $110 shipped. $115 for topmount
To order please use paypal (add 3%): send payment to bandrfittings@gmail.com
Orders in CA are subject to 7.75% sales tax.
Modified by B R Fittings at 3:56 PM 3/11/2008
Modified by B R Fittings at 2:35 PM 3/13/2008
$55 shipped
* One 1/8"npt plug.
$35 shipped
Re: Turbo Oil Feed & Return kits, Oil restrictors!!!!!! (B R Fittings)
Borg-Warner Turbo oil feed kits will be available towards the end of this week or early next week. They will come with -4 AN fittings w/steel braided hose, custom ordered for whatever length you need.
how would i go about ordering just the oil restrictor (.035" hole)?
and maybe the distribution block with correct 1/8"bspt male that screws into the block
Re: Turbo Oil Feed & Return kits, Oil restrictors!!!!!! (imprezdcrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imprezdcrew »</TD></TR><TR><TD CLASS="quote">how would i go about ordering just the oil restrictor (.035" hole)?
and maybe the distribution block with correct 1/8"bspt male that screws into the block</TD></TR></TABLE>
Just use my email address to send the money over paypal.
The total for both will be $25 shipped.
Re: (qtrung909)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qtrung909 »</TD></TR><TR><TD CLASS="quote">might have to get back with you soon. thinking about getting some boost</TD></TR></TABLE>
Just let me know when your ready to order.
Re: (B R Fittings)
-4 Oil feed Kit
$55 shipped
* One 1/8"npt plug.
$55 shipped
* One 1/8"npt plug.
Re: (JDMBrian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMBrian »</TD></TR><TR><TD CLASS="quote">Sent payment for -3 Turbo Oil Feed Line Kit
thanks!</TD></TR></TABLE>
Shipped. Thanks for the order.
can you get 1/2" NPT to -10 AN couplers?
if so, i need your drain kit, along with 2 90s, a 45 and 2 straight couplers
i'm really tight on space around my crossmember/pan because i have a RAM manifold and a sc61
i'm just wanting to make sure they'll fit
email me at conlyn@linuxmail.org with cost
and i'll paypal the money
need ASAP
let me know if they can ship tomorrow
are the lines pre-assembled? or do they need assembly
because depending what couplers i use, i'm going to need a 13-14" line so i might just get the 2' and cut it
Modified by conlyn at 1:54 PM 3/14/2008
need ASAP
Re: Turbo Oil Feed & Return kits, Oil restrictors!!!!!! (conlyn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conlyn »</TD></TR><TR><TD CLASS="quote">can you get 1/2" NPT to -10 AN couplers?
need ASAP
Modified by conlyn at 1:54 PM 3/14/2008</TD></TR></TABLE>
Emailed.
need ASAP
Emailed.
can you get the stainless lines in the black braided lines instead with the AN fittings?
Re: Turbo Oil Feed & Return kits, Oil restrictors!!!!!! (riceburner700)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner700 »</TD></TR><TR><TD CLASS="quote">can you get the stainless lines in the black braided lines instead with the AN fittings?</TD></TR></TABLE>
I have access to the black nylon braided hose (pro lite 350). So you would want the red/blue fittings with the pro lite 350 hose?
Just received my 3an feed line. Super Duper Fast *** Shipping! Great seller! will be buying from you again!
Re: Turbo Oil Feed & Return kits, Oil restrictors!!!!!! (JDMBrian)
http://i210.photobucket.com/al...y.jpg
yeah just like the fuel line that i got but want it the same for my oil feed and return. it will going on a d-series to a gt30r and however big that return is. Let me know a price and also if i can get a price with a restrictor so i don't kill my turbo as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner700 »</TD></TR><TR><TD CLASS="quote">http://i210.photobucket.com/al...y.jpg
yeah just like the fuel line that i got but want it the same for my oil feed and return. it will going on a d-series to a gt30r and however big that return is. Let me know a price and also if i can get a price with a restrictor so i don't kill my turbo as well </TD></TR></TABLE>
I only carry the oil restrictors in -3. So the -4 feed line won't work. We carry the steel braided PTFE hose with a 90 degree fitting to connect to the oil restrictor. Here's a picture of it hooked up to a gt30r turbo.
