| Welcome to Honda-Tech! | ||
#1 |
| Garage is empty, add now |
I am trying to replace a stock headlight bulbs with blue color heligen bulbs. But seems to have little problem. The driver side has no clearance for my hand to get to the bulbs. I probably have to take out some parts like battery and such. Or is there better way to do it without taking out any parts???
And when I am able to access to the light bulbs, then what do I do to take out the bulbs? Thanks in advance for your respond. |
#2 |
What car do you have????
I have an Si, so this will be the procedure for an Si. In the manual, it says something about removing phillips head screws that are holding the fender well, but the only phillips screw in the fender well, is the one holding the bumper on. I am assuming that is the procedure for the non-si models. So if you have a non-si, when I say clips, they may be phillips head screws instead, I'm not sure. In the manual, Honda recommends peeling back the fender well to replace both low beam bulbs (the ones on the outside). You really only need to do this on the passenger side. Passenger side: Pop out the clips that are holding the front of the fender well in. There is one just in front of center of the well on the outside lip. There are one or two more on the front side of the fender well. Peel the plastic fender well out as far as you can, so that you can get your arm up in the front of the car. Grasp the bulb and turn it 1/4 turn counterclockwise. You should be able to pull it out of the headlight. Unclip the bulb from its clip and pull the old bulb out. Put the new bulb in the clip. It only goes in the clip one way. Direct the bulb back into the headlight housing, so that is turn a little to the left, the same way it was when you took it out. Gently push it flat and turn it clockwise. You will feel it stop. Look in there and make sure the bulb clip is straight up and down, not on an angle. If its on an angle, try again. Pull your arm out, push the plastic back to where it goes and replace any clip you took out. That is just for the low beam bulb, you should be able to replace the passenger high beam bulb just by popping the hood and replacing the bulb. Driver side: Pop the hood and loosen the two battery tie downs. You don't need to remove them. Just loosen them really good so that you can move the battery about an inch back. Reach down and pull the radiator catch can out. It is the white plastic thing in front of the battery, with a black hose leading its top. You may need to release the little black hose from its clips, so that you have enough slack to pull it out. Also, you might have to grab a flathead screwdriver and pry with it on the clip holding the catch can in. It doesn't just pull out the first time. Make sure you don't pull too far, or pull the cap or the hose off. Place it on the front of your car. Repeat the above process for removing and replacing the bulb or bulbs. Push the catch can back into its clip. Put the hose back in its clips and put the battery back where it was. Tighten the battery tie downs and you're good to go.
FG SQUAD #2 |
#3 |
Thanks alot for this great info!!!
#4 |
By the way I own a 07 Civic LX.
#5 | |
FG SQUAD #2 |
#6 |
I had to remove my front bumper to replace my D2S bulb(s)...
» Comptech Supercharged 2006 Honda Civic Si Coupe | Got e85? » More Info | Teaser Video | Carbon8mag Feature! » flickr | johnfuggi.com photography |
#7 | |
FG SQUAD #2 |
#8 | |
#9 |
you might have to change the bulb thru the fender liner by turnin one wheel either left or right and pulling down the fender liner a bit so u can see the plug...on the new accords that the way we have to change them
B.A.R. member as of 3/18/09 JDM gsr in 98 hatch Voches: chickwithastick,93allmotorcoupe,jomama,punoy69,Tom theman70 |
#10 |
when you say fender liner, do you mean by the plastic trim underneath metal sheet(fender) ?
#11 |
I agree with you and hoping you are right. It seems very odd that you have go through all that trouble just for changing a light bulb doesn't make any sense. I don't think Honda engineering is that stupid. Anyhow I got to give it a try this weekend, wish me luck!
#12 |
Yeah i ahve done this multiple times.. i just used the well wells.. ttake em off but be careful with them clips.. they like to break and loose their strength
~Nighthawk Black Civic Si Sedan~ Injen Cold Air Intake, H.I.D. Kit, Kobe Cam 5's in Black |
#13 | |
FG SQUAD #2 |
#14 |
the only thing you have to do is pull up on the radiator fluid reservoirs and you can then slip your hand in there and take them out like that.
#15 |
Yeah, for the driver side. But its not that easy for the passenger side.
FG SQUAD #2 |
#16 | ||
#17 |
MiG-21 superfan
1975 MiG 21bis |
http://www.honda-tech.com/zerothread?id=2111455
http://www.honda-tech.com/zerothread?id=2121798 http://www.honda-tech.com/zerothread?id=2055085 some of the members were gracious enough to answer, but just remember the process for changing the headlamp bulbs is detailed in your owners manual. just so you remember down the line when one of your bulbs blows out and you forget exactly how to do it, you can look there
модератор / '09 Mercedes-Benz C63 AMG / '07 Si sedan / END OF AN ERA / 5'16", 149.7kgs / RON PAUL |
#18 |
Anyone ever changed the low beam bulb on a 2001 Acura TL, right side? Looks like a bugger?? Help please.
#19 |
#20 | |
Or...better yet..http://honda-tech.com/forumdisplay.php?f=17
FG SQUAD #2 |
#21 | |
I just changed mine. I still haven't posted pics yet.bollocks.
go to our discussion on on civic headlights. we have very detailed instructions and comments there. No offense to the people here, but what I did to remove and replace the bulbs was much easier. Quote:
| Tags |
| 2001, 2006, acura, bulb, bulbs, change, changing, civic, crx, headlamp, headlight, honda, replace, rsx, tl |
