How-To: Replace Internal Seal of Distributor (Internal Oil Leak)
Old 02-02-2010, 09:37 PM
  #51
Hondaphile13's Avatar
Default Re: External leak of the distributor
Originally Posted by Bad_dude
I have a leak which appear below my car. When I changed out the cap about 3 months ago, I did not see any massive amount of oil in the distributor. However the leak seems to be outside and down toward the tranny. I check oil every day and it's not going down.
Do you guys think replacing the o-ring is sufficient, or do I need to replace the inner seal too? I have bought both parts. I am afraid to open the distributor and find out the bearing is going and need a new distributor. I need the car to go to work every day so ordering a new distributor would make my car down for a few days. The dealer want $405 for a new distributor. Any where I can buy the distributor cheaper?
Thanks.
AutoZone, Pep Boys, Napa Auto Parts, or even online. Honda Civics and Accords are notoriously easy to shop for. It should cost about 1/3 the dealer price. I would go ahead and buy it if you think theres a chance that it will need to be replaced. Its not that hard to do and doesnt take that long. And if you dont need it, you could always resell it.
Old 03-22-2010, 02:43 PM
  #52
TRIAL USER
H23Vtec94Accord's Avatar
Default Re: How-To: Replace Internal Seal of Distributor (Internal Oil Leak)
were can i find the internal shaft seal for h23 obd1 dizzy partstrain wont come up
Old 03-22-2010, 04:05 PM
  #53
GhostAccord's Avatar
No and nether does Honda. It is a NOK HTC seal part No. BH3888E. Call your local parts stores or machine/bearing supply shops. There is an idiot on ebay that just jacked his prices up $30/seal. $50 is a rip off when you may be able to get these from some machine/bearing supply shops.
Edit* Found a new seller selling at 1/4 the price. NOK BH3888E for $15.00 shipped to USA.
Old 03-31-2010, 07:22 PM
  #54
TRIAL USER
drojo's Avatar
Does the f22b1 distributor have the same seal? i can only find f22b2 seal.
Old 03-31-2010, 08:09 PM
  #55
Yes, They are the same.
Old 04-01-2010, 10:50 PM
  #56
h22apwrcb7's Avatar
DIY that I posted on CB7tuner.com
http://www.cb7tuner.com/vbb/showthread.php?t=88245
Old 04-02-2010, 06:19 AM
  #57
Why would you post your DIY in a thread that is already a DIY?
Your pictures are terrible in your DIY and you don't even know where to get the inner seal.
Troll?
Old 04-11-2010, 12:08 PM
  #58
h22apwrcb7's Avatar
Troll?
Why would I post my DIY in a DIY? Well obviously you looked at it, which were my intentions, for anyone who wanted more info on the subject. It was clearly stated as a link to my DIY, and you clicked anyway. My thread has ALL the steps including pictures. Not only does it show how to replace the inner seal but also the other seals in the dizzy and the symptoms of each going bad. (No offense against this thread)
As for the pictures... this is not a photo enthusiast forum, who cares!! They are good enough for all intended purposes.
And finally, no I dont know where to get the seal because the local place where I got mine no longer carries them. By the way, this thread is called
not
Where to buy: Internal Seal of Distributor
Now go find something constructive to do with your time
Old 07-05-2010, 02:17 AM
  #59
itr1244's Avatar
when the dizzy was leaking oil. where did you find the oil leak?
i have this oil leak i couldnt figure out where it is coming from..
Old 07-05-2010, 03:19 AM
  #60
holmesnmanny's Avatar
And finally, no I dont know where to get the seal because the local place where I got mine no longer carries them. By the way, this thread is called not
Why link to that other thread when this thread already has a perfect write-up and even better pictures. The pictures to that other thread are all blurry. You can't really see anything.
You act like you're right.
Old 07-05-2010, 07:31 AM
  #61
lol that troll is long gone don't bother wasting your time. 2 post wonder boy!
Old 07-05-2010, 07:38 AM
  #62
Have you taken off the distributor cap and looked inside the distributor? If there is oil inside the distributor, it would probably be the shaft seal, it's the only internal oil seal inside the distributor. The DIY and pics are on the first page.
If the oil is on the outside of the distributor. It would more than likely be the outer shaft O-ring that seals the distributor to the head.
Old 09-10-2010, 12:33 PM
  #63
j894's Avatar
Has anyone done this seal replacement on a 2000 accord (EX) with the 2.3l Ulev engine?
Im just worried about part interchangeability: (W0133-1640599)
http://shop.autopartsfair.com/store/...4963365%2B1631
I found this website that lists the replacement distributor seal for 1984-2002 accords...However it has a note there saying "# 2000: DX; All Engines;"
Now I looked at the distributor part number for the DX model (F23A5) as well as the EX model (F23A4) to see if they are the same but some of the part numbers are the same and some are not...... so does anyone know if the distributors are the same on the F23A5 Vs the F23A4?
Or can anyone tell me if the distributor seal in the link above (for the older accords) will work in mine (2000 EX, 2.3 ulev (F23A4)
Old 09-13-2010, 12:24 PM
  #64
j894's Avatar
any1?
Old 09-27-2010, 06:56 PM
  #65
h22apwrcb7's Avatar
I'm still here buddy.. I just don't post anymore b/c of a**holes like you that flame for no reason at all. I try to help someone out and get flamed on my first post. I thought this was suppose to be a community for us to help each other out not for because I garantee you wouldn't talk to me like that to my face.
Old 09-27-2010, 07:43 PM
  #66
Sorry but to me it seemed like you were just trying to one-up this guys DIY. When yours, in my opinion, really isn't any better.
Your probably correct in saying I wouldn't talk to you like this in person. That's becuase hopefully, if we were hanging out in a group, you wouldn't try and one-up someone for no reason.
Old 09-27-2010, 07:46 PM
  #67
phootbag's Avatar
CRIPPLE FIGHT!!!!!!!
Old 09-27-2010, 08:33 PM
  #68
h22apwrcb7's Avatar
So let's put this behind us and move foward
Old 09-28-2010, 04:13 AM
  #69
Old 10-25-2010, 11:32 AM
  #70
b16racereg6's Avatar
glad i found this. mine needs a seal its PISSING OIL ALL OVER THE TRANS LOL. about 1 to 2 quarts in between oil changes. will be ordering them next payday. wooohooo
Old 10-29-2010, 01:53 PM
  #71
Bad_dude's Avatar
Post Re: (deklao)
Originally Posted by 2accrds
I replaced both the o-ring and seal. You can see where the bearing is in pic 3 next to my finger. It is held in place by the three screws. You would most likely have to press it on and off to replace. My bearing was fine so I didn't replace it.
Hi,
You have any info or instructions on how to press it out and in? What kind of press would you need? Could you just buy one of those manual press or a hydraulic one is needed?
Thanks.
Old 10-29-2010, 01:56 PM
  #72
Bad_dude's Avatar
Post Re: How-To: Replace Internal Seal of Distributor (TouringAccord)
Originally Posted by Lapog
Sorry I missed this new thread and kept posting on the old one...
Anyway, I used the previous write up and replaced the O-ring. The pictures really helped! Thank you.
However, I could not remove the distributor because the electrical connectors did not want to detach. I did press the tab and pulled hard on the casing... no luck. I stopped short of using vice-grip to pull them apart. Any suggestions?
Use a flat head screwdriver a the same time as you press. That works for me.
Old 11-24-2010, 05:28 PM
  #73
teahtime's Avatar
Hopefully, this thread is still "live" because in as much as there is great information here, I'm not seeing any info on the V6 distributor. I've searched high and low for the parts listed in this thread and every time I enter v6 in the "car type", I get nothing. I could very well be misunderstanding the thread, so my apologies. Still, if anyone can help find the "internal seal" for the 1995 Honda Accord V6 (2.7L) distributor (websites, links, other threads), I can possibly drive my car places without having to park miles away so i don't mess up people's driveways :[
I know i can buy a whole new one, but if i can get my hands on this seal...
Old 11-27-2010, 05:35 AM
  #74
CBL9's Avatar
Where is oil accumulating on your motor, what area do you see it dripping from?
Old 12-16-2010, 11:49 AM
  #75
typer2k1's Avatar
this is awesome, i just came across this thread because i bought another Honda. (1994 LX Accord with a Ex engine) I started to check under the car casue after all, buying a new car to me i would want to get familiar with whats going on with the new ride.
Both outer cv joint boots are ripped, steering rack boots ripped, leak comming from the driver side of the car(PS pressure line is leaking) and a oil leak comming from the rear of the transmission. This had me puzzled, i know its not tranny fluid because its brown in color, and i didnt think its comming from the tranny seal because its not leaking from where the tranny and engine bolt together.
This leaves me to believe its leaking from the dizzy o ring, that and because when i changed my lower coolant hose i took the dizzy off and saw a bunch of oil on the tranny housing,
good info guys! keep up the good work
Quick Reply: How-To: Replace Internal Seal of Distributor (Internal Oil Leak)
