> Honda Accord (1990 - 2002)
Old 02-07-2008, 01:09 PM   #26
JDM_CD7
JDM_CD7's Avatar
Send a message via AIM to JDM_CD7
Default Re: How-To: Replace Internal Seal of Distributor (2accrds)
Someone Sticky this....
"expletive what you think, i'll still out handle you"
<----1995 Accord EX Coupe (CD7)
PAYPAL VERIFIED
My Vouches: Bigxclumzy,TheBEeGuY,FF-Greg,FF-Sean, FR-MOB: The B33 Gay,DUFFM4N, Shelton, Freaker, 91CrXB16a, 88crxkidsir (Los), donut, and more just can't remember names http://images.honda-tech.com/set1//smile/emcrook.gif
JDM_CD7 is offline Report Post   Reply With Quote
Old 02-08-2008, 11:43 AM   #27
Lapog
Lapog's Avatar
So... the distributor seal arrived. I went and looked at my car again. It stopped leaking. Now what is that? I haven't yet opened the distributor to check for oil inside, but I am pretty sure there will be none.
Should I still go ahead and replace the seal or let sleeping demons sleep?
1995 LX 2.2L I4 (F22B2), Teal, (Dec 10 2007, 123305)
Lapog is offline Report Post   Reply With Quote
Old 02-08-2008, 11:44 AM   #28
Lapog
Lapog's Avatar
Default Re: How-To: Replace Internal Seal of Distributor (JDM_CD7)
I second it!
Old 02-08-2008, 11:52 AM   #29
TouringAccord
H-T Order of Merit
TouringAccord's Avatar
no need for it to be stickied, there is enough stickies as it is.
Besides, it's linked in the FAQ (which is stickied).
TouringAccord is offline Report Post   Reply With Quote
Old 02-08-2008, 11:59 AM   #30
TouringAccord
H-T Order of Merit
Default Re: How-To: Replace Internal Seal of Distributor (Lapog)
well, you replaced the o-ring right? so that was bad, you fixed it and now oil doesn't leak outside the distributor. It probably wont leak to the inside of the distributor if it doesn't make it past the o-ring.
Old 02-08-2008, 12:04 PM   #31
Lapog
Lapog's Avatar
Default Re: How-To: Replace Internal Seal of Distributor (TouringAccord)
So I spent $17 for the seal that may not need replacing? Ouch!
Old 02-08-2008, 03:56 PM   #32
2BFI
2BFI's Avatar
Default Re: (2BFI)
I finally got mine done. I brought it to a shop who used a vise to push out the pin. Once it was out they replaced the seal and pushed in the pin again. The operation took about 5 minutes.
Yeah, they've done quite a few of it in the past.
My Auto Blog
2BFI is offline Report Post   Reply With Quote
Old 02-27-2008, 12:46 PM   #33
freeyellow2000
freeyellow2000's Avatar
Default Re: (2BFI)
I replaced a coolant hose by removing the distributor to get to the heater hose. When they put it back on the car didn't start. I figured that it had to do with the fact, it hadn't start/driven the car in 4 weeks. So I floor the accelerator and it evenally started up. After that I get extremlely poor acceleration, I am assume that I must have accidentaly rotate distributor it 180 when I initated installed it. I believe my timing is off as well. How would correct this problem.
freeyellow2000 is offline Report Post   Reply With Quote
Old 02-28-2008, 06:20 AM   #34
billyrusa
billyrusa's Avatar
Default Re: (freeyellow2000)
For correcting the timing, the best way is to use a timing gun (timing light). During the inspection and setting process, you need to short the service check connector behind the glove box. Check manual for detail process.
Alternately, even it is not recommended, you can use you ear to judge if the engine is running OK while turning the distributor for a good timing. This way can not set the timing precisely and will need a lot of experience.
billyrusa is offline Report Post   Reply With Quote
Old 06-06-2008, 10:24 AM   #35
Bad_dude
Bad_dude's Avatar
Send a message via AIM to Bad_dude
Default External leak of the distributor
I have a leak which appear below my car. When I changed out the cap about 3 months ago, I did not see any massive amount of oil in the distributor. However the leak seems to be outside and down toward the tranny. I check oil every day and it's not going down.
Do you guys think replacing the o-ring is sufficient, or do I need to replace the inner seal too? I have bought both parts. I am afraid to open the distributor and find out the bearing is going and need a new distributor. I need the car to go to work every day so ordering a new distributor would make my car down for a few days. The dealer want $405 for a new distributor. Any where I can buy the distributor cheaper?
Thanks.
Bad_dude is offline Report Post   Reply With Quote
Old 06-20-2008, 09:36 AM   #36
bopbop93030
bopbop93030's Avatar
I'm going to try this this weekend. I just got the seal and Oring yesterday. Do you think an average joe can do this or shall I just bring it to the mechanic?
I'm afraid that I might mess up the timing. lets say that I mess up the timing, will the car still run?
1995 Accord EX Sedan, F22B1
bopbop93030 is offline Report Post   Reply With Quote
Old 06-20-2008, 10:03 AM   #37
GhostAccord
GhostAccord's Avatar
Default Re: (bopbop93030)
If you remember to scribe a line from the head onto the distributor housing with a screwdriver or permanent marker, before you loosen the dist, you won't have to worry about the timing. Just line the marks up when you put it back together. The distributor only fits onto the end of the cam one way. It would be very hard to screw it up.
CD5 "Ghost" F22B2 ITB Blog
My H-T Build Thread
Cheers!
GhostAccord is offline Report Post   Reply With Quote
Old 11-04-2008, 02:04 PM   #38
RIZOBIZERT
RIZOBIZERT's Avatar
I can't find this 'seal' on partstrain, can you help?
RIZOBIZERT is offline Report Post   Reply With Quote
Old 11-04-2008, 05:15 PM   #39
chriszhou
Default Re: How-To: Replace Internal Seal of Distributor (RIZOBIZERT)
lol,look at Engine Electrical.
chriszhou is offline Report Post   Reply With Quote
Old 11-05-2008, 03:25 AM   #40
RIZOBIZERT
RIZOBIZERT's Avatar
Default Re: How-To: Replace Internal Seal of Distributor (chriszhou)
I did check engine electrical, but I did the search with out the 'all parts'. I called Partstrain and spoke with a representative. They advised they had no such seal. I've now found it utilizing the 'all parts' selection window. Here's the link should anyone need it. Thanks again for your help.
http://www2.partstrain.com/sto...pp=50
Old 12-19-2008, 03:55 PM   #41
SuperSlow
SuperSlow's Avatar
Are all the internal seals the same for f22b1/2 f22a? Because in partstrain they list Accord 1986-2002(!!) for that part.
http://www2.partstrain.com/store/ind...r&No=15&Npp=15
TIA
FOR SALE GOODIES! http://www.hondamarketplace.com/show...6#post37088916
SuperSlow is offline Report Post   Reply With Quote
Old 02-13-2009, 05:41 AM   #42
sheimbach
sheimbach's Avatar
Default Re: How-To: Replace Internal Seal of Distributor (Internal Oil Leak)
has anybody found a source for the bearing some people were talking about
sheimbach is offline Report Post   Reply With Quote
Old 03-31-2009, 11:45 AM   #43
SOHKis
SOHKis's Avatar
Send a message via AIM to SOHKis
of course replacing my o-ring didn't solve my leak...
great writeup, saved me from having to replace the dist. thanks man!
SOHKis is offline Report Post   Reply With Quote
Bookmarks
1995, 1999, 92, accord, distributor, honda, housing, integra, leak, leakage, leaking, oil, replace, replacing, seal, shaft
