noise when engaging clutch
Old 12-14-2007, 10:00 AM
Inextricabledrvr's Avatar
Default noise when engaging clutch
I was driving yesterday and I noticed when I engaged the clutch in 1st gear theres a squealing noise like something is rubbing. (not any my belts cause its a different squealing) It only happens in 1st gear from a complete stop.
Does anybody know what this may be? Is my clutch going out?
Old 12-14-2007, 10:25 AM
ECX
* B A N N E D *
ECX's Avatar
Default Re: noise when engaging clutch (Inextricabledrvr)
Mine just got replaced and makes a humming noise until I push the clutch IN, but curious as to see what yours is.
Old 12-14-2007, 11:45 AM
Default Re: noise when engaging clutch (ECX)
Im thinking the sudden cold weather here in ca confused my car as its not used to anything around the 40's causing something to go out of whack, but i dont know.
Another thing is that when I engage(out) the clutch slowly(extremely slow) the sound doesn't come up. If I release it a little bit quicker(normal speed) it makes the squeaking/squealing sound.
Im just trying to figure out this annoying sound.
Old 12-14-2007, 11:58 AM
kacivic's Avatar
possibly your throw out bearing? i'm just making a guess because i haven't witnessed a sound like you're describing, but it seems possible.
Old 12-14-2007, 01:26 PM
Dicorp's Avatar
Default Re: (kacivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kacivic &raquo;</TD></TR><TR><TD CLASS="quote">possibly your throw out bearing? i'm just making a guess because i haven't witnessed a sound like you're describing, but it seems possible.</TD></TR></TABLE>
i second that, i have that humming noise when the clutch is engaged and the car is in neutral. 99.9 sure that its the throw out bearing
Old 12-14-2007, 02:57 PM
ECX
* B A N N E D *
ECX's Avatar
Anyone have any ideas on what mine is? Makes the noise while the clutch is not engaged, but when I push it in it goes away?
Very frustrating after just having this done.
Old 12-14-2007, 04:01 PM
Dicorp's Avatar
Default Re: (ECX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECX &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have any ideas on what mine is? Makes the noise while the clutch is not engaged, but when I push it in it goes away?
Very frustrating after just having this done.</TD></TR></TABLE>
yes, my issue exactly...not pushed in (engaged) = humming noise
pushed in (disengaged) = no humming noise
its your throw out bearing
Old 12-14-2007, 04:08 PM
I know what everybody is talking about with regards to the humming noise when the car is idling or when the clutch is pushed down and that is not what I am experiencing.
My issue is when I engage the car in 1st gear and start moving. There is a slight squeal when the car first starts moving and then disappears once I get going. It only happens in 1st gear.
Old 12-14-2007, 07:17 PM
ECX
* B A N N E D *
ECX's Avatar
Default Re: (Dicorp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dicorp &raquo;</TD></TR><TR><TD CLASS="quote">
its your throw out bearing</TD></TR></TABLE>
In that case, I'm going to go shoot that ************ that just changed my clutch in the FACE when I see him.
Old 12-14-2007, 10:46 PM
Default Re: (Inextricabledrvr)
Man somethin must be seriously wrong with mah sh*t cause nobody else has ever heard of this.
Old 12-15-2007, 12:22 PM
M2B4's Avatar
ECX is it a high pitched humming noise or is it more like a whirring noise?
Old 12-15-2007, 01:44 PM
ECX
* B A N N E D *
ECX's Avatar
Default Re: (M2B4)
Both, it's a humming noise (not sure about the high pitch part, only heard it from inside the car I haven't listened outside of the car...) and it sounds like a whirring noise as well.
Old 12-16-2007, 07:44 AM
* B A N N E D *
InitialJRift's Avatar
Default Re: (ECX)
i'm actually having the EXACT same problem with my 5th gen, it makes the most horrid squeak/screech/chewbacca/nails on a chalkboard sound when letting the clutch out in 1st, it used to only happen when the car is cold but it's getting worse and now does it even when the car is warmed up sometimes, shifting through every gear is still fine though, i'm going to have Honda check it out, if i could get youtube to accept AVI files i'd take a quick vid or something for you guys to hear
Old 12-16-2007, 09:23 AM
h23prelude's Avatar
it could be your first gear syncro slipping when trying to match speeds to shift, how many miles are on the transmission?
Old 12-16-2007, 09:49 AM
M2B4's Avatar
Default Re: (h23prelude)
i know mine makes a kinda whirring noise at idle I can hear when listening to the motor. I was told thats from having the 3 puck clutch (exedy stage 2) instead oem.
Old 12-16-2007, 11:52 AM
Default Re: (InitialJRift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InitialJRift &raquo;</TD></TR><TR><TD CLASS="quote">i'm actually having the EXACT same problem with my 5th gen, it makes the most horrid squeak/screech/chewbacca/nails on a chalkboard sound when letting the clutch out in 1st, it used to only happen when the car is cold but it's getting worse and now does it even when the car is warmed up sometimes, shifting through every gear is still fine though, i'm going to have Honda check it out, if i could get youtube to accept AVI files i'd take a quick vid or something for you guys to hear</TD></TR></TABLE>
This sounds exactly what my car is doing. It does it when I let it out in 1st, but its not all the time. Let us know what the problem is when you get it back.
Old 12-16-2007, 04:17 PM
Blacktt7's Avatar
Sounds like what mine does also.
Does it sound like it comes from the driver front tire area? Mine sounds like a mix between horrible belt squeel and metals rubbing together.
I'm finishing up changing my timing belt and manual tensioner swap so i'll let you guys know if it goes away.
Old 12-16-2007, 04:19 PM
Default Re: (Blacktt7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blacktt7 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like what mine does also.
I'm finishing up changing my timing belt and manual tensioner swap so i'll let you guys know if it goes away.</TD></TR></TABLE>
Yeah thats where mine sounds like its coming from. And you explained it right on the money.
Old 12-16-2007, 08:58 PM
Blacktt7's Avatar
Well i took her for a test drive for about 10 minutes and didn't hear anything yet, but it didn't always do it so we'll see after i run some errands in her tomorrow.
Old 12-17-2007, 07:40 PM
honda_andy's Avatar
i have the exact problem, i asked on here before and everyone told me it was my throw out bearing, i learned to drive it so it doesnt do it that often. doesnt it feel like when you here the noise your clutch starts slipping? im gonna assume its the TOB. anyways, like i said i learned to drive it so it doesnt do it so ill just wait til my clutch goes.
Old 12-17-2007, 10:04 PM
HeDge_BB6's Avatar
It's your throw out bearing for sure. I had the exact same problem on my 5th gen. a couple of months ago. I would disengage my clutch in 1st, and hear that whinning type of noise. I would only hear it in that gear!! I changed my clutch, flywheel, and of course the throw out bearing, and the noise was gone. I knew since the beginning it was the throw out bearing, but since I was changing my clutch and flywheel, I waited till then. You dont want to bring down your tranny just for a bearing!! If you haven't upgraded your clutch or flywheel, and your gonna change that bearing, THIS WILL BE THE TIME!!!
Old 12-17-2007, 10:57 PM
Default Re: (HeDge_BB6)
This is F*kin great...Time to fork out some cash...
Old 12-18-2007, 01:40 PM
Blacktt7's Avatar
Don't change your throw out bearing. It's not a whining noise. It's a screeching noise.
After doing some driving, it's definetly still there so it's nothing to do with timing belt, auto tensioner or that general area.
After doing some thinking it might be the clutch disk. I'm not saying it's going out but it just might be the way it is. Brakes squeek and they're made of the same general material.
Isn't there a window on the tranny so you can see into the bell housing? You should be able to see if your clutch disk is low if there is a window. I'll probably check in a couple months once it warms up and i can pull the race car off the lift.
Old 12-18-2007, 02:27 PM
M2B4's Avatar
if you guys are referring to the noise i was talking about thats not a throw out bearing. My silver prelude had a bad tob and its not the same noise i get on my stage 2 I would say around the driver side area i have a whirring noise. cant really describe it very well.
Old 12-27-2007, 09:22 AM
Default Re: (M2B4)
Anyone figure what this noise may be?
It seems like it is getting worse the more I use it. I just haven't had the time to get it checked by a mechanic.
Quick Reply: noise when engaging clutch
