My K24/K20 Turbo Crx.... (Pics)
Old 11-23-2007, 08:05 AM
1320whtrex's Avatar
Default My K24/K20 Turbo Crx.... (Pics)
Hey whats up everyone. I dont really post much on here but im around nonetheless. Mainly you can find me on K20a.org. Just wanted to share my ride with you all. I have posted a few pics in the Gallery as well so you will see some of the same pics here. Currently its a '90 Crx Hf that I purchased back in 2001 for $850 and I have been through a few different setups on my quest for a fast car that I will love. Been through d/b series, GSR engine blew on 9-11-05, so I needed something new. I had a stock K20a2 in January of 2006 and then went for a full turbo build, sold it all to get a bike, changed my mind and started buying all the sh*t back. Currently its a K24a4 block with TSX pistons and rods and a stock Type S head..
This is what it used to look like back in 2006
Stock A2 swap with clutch kit and direct port.... Never sprayed on.....
Since I decided to make it turbo, it now looks like this....
Interior not completed yet.... However Cluster is fully functional.
My Jamaica License plate
I have listed the parts and how much I have spent on this swap alone...
(Everything purchased brand new except engine, TB, Intercooler, Turbo)
Stock K20a2 swap with Type S Tranny $3,300 Blown motor
RBC Manifold $200
Karcepts Adapter plate $80
Power2Rev Racing IMG $34
Type R Throttle Body $150
AEM Fuel Rail $130
RC 1000cc Injectors $360
Aeromotive FPR with Gauge $150
Oil Pressure, Boost, Water Temp, & Fuel gauges $200
Apexi Turbo Timer $80
Walboro 255lph in tank pump $90
ClutchMasters FX600 Twin Disc $1,200
Tilton Twin Disc Cerametallic Clutch Kit $1,400 Piece of sh*t broke
Tilton Hydraulic Release Bearing kit $425Piece of sh*t broke
AFI Sidemount T4 Turbo manifold, 3 inch Downpipe & dumptube...$1,400
Precision T4/PT67 Turbo . $800
Tial 50mm Blow off Valve and 44mm Wastegate $500
Precision 680hp Intercooler $300
Perrin Electronic Boost Control Solenoid Valve $95
AEM Uego Wideband $240
Golden Eagle Vacuum Manifold $36
Hondata Kpro... $985
Karcepts Shifter Plate $150
Speed Source Shifter Bushings kit $25
Hasport EFK mounts and Temp Port Switch. $530
Hasport EFWK Wiring Harness $300
BDL Industries Alternator Pulley with 39" 6 ribbed Belt $95
Suja 1 Motoring Clutch line $50
Gator Racing Axles Stg1 $300
OmniPower Sport Suspension... $540
Intercooler piping and CMC install $622
Silicone Couplers, VBand Clamp and T4 gasket $100
9 3" T Bolt Clamps $50
K24a4 Engine Block $600
TSX Rods and Pistons $120 SOLD....
Honda K24a2 Rings and Thrust Washers $135
Hot tank and hone block, polish crank, clean pistons and rods from machine shop $115
CRV Timing Bracket and K24 Headgasket $95
ACL Main and Rod Bearings $120
CP 9:1 87.5mm Pistons $410
IB H Beam Rods $360
K20Z1 Cams $150
ARP Head Studs $100
ACL Main and Rod Bearings $120(For CP pistons)
Bore, Hone, Hot Tank, micrpolish Crank, Pin fit Rods and install pistons, Check A2 Head $300
Cometic 88mm Head Gasket $68
10ft. 4 GA Power cord for battery relocation $13.50
Gold plated battery post $5.00
NGK Spark Plugs (8's) $28
XRP M12x1.25 6AN Solex Fitting $7
Radiator Hose clamp $0.50
3 inch Exhaust and Muffler $360
ETD Racing Traction Bar $200
So far my total invested is a little more than $18,104... (Oil, Coolant, telfon tape and minute miscellaneous things not calculated)
Right now I cant complain about it man... It's very impressive untuned and Im in love with it
Since I made the clutch setup hydraulic, this is what I had to do with the clutch pedal setup
However the twin disc kept breaking the clutch pedal assembly... and this part kept on flexing....
I ended up cutting the shaft off from the pedal assembly, drilling out the hole, went to the local parts store and purchased a stronger bolt. I put it through and welded it fit it up back together. Its much stronger than before now. I also welded a bracket from the bottom of the fabricated bracket fro the CMC to go back up to the chassis to keep it from pushing it in.. After that it didn't give me any more problems.
This build has been in progress for over a took me a very long time to make this money and spend my hard earned money on this car. I know its a hell of a lot, but im happy with it so im good.
At this time I DO NOT have any Dyno Sheets or any track times as she hasnt seen neither. I was able to get a hold of a set of CP pistons and IB rods so I will be yanking the swap out to install the new goodies, and then put her back together. Afterwards I can let you know what the numbers are looking like... Im shooting for 600+whp. Thanks for checking out my build and your +/- comments are more than welcome...... I will post more to keep up with the new build..
Osric...
Modified by 1320whtrex at 8:58 AM 12/7/2007
Modified by 1320whtrex at 9:00 AM 12/7/2007
Modified by 1320whtrex at 9:01 AM 12/7/2007
Modified by 1320whtrex at 8:33 AM 12/20/2007
Modified by 1320whtrex at 8:41 AM 12/20/2007
Modified by 1320whtrex at 8:49 AM 12/20/2007
Old 11-23-2007, 08:14 AM
thevtecnician's Avatar
Default Re: My K24/K20 Turbo Crx.... (1320whtrex)
Wow that things gonna be a torque monster. Nice car
Old 11-23-2007, 08:34 AM
InvaderJim's Avatar
Sweet project. Love the interior too. Can't wait to see what that baby runs.
Old 11-23-2007, 09:17 AM
gibsanez's Avatar
Default Re: My K24/K20 Turbo Crx.... (crxfreak1117)
So do you get traction in like, 4th gear?
Old 11-23-2007, 09:41 AM
B18c1 ej1's Avatar
Default Re: My K24/K20 Turbo Crx.... (gibsanez)
Overkill?
I bet that things a beast!
Old 11-23-2007, 09:49 AM
CBURKE's Avatar
Very nice, but I can't see spending that kind of money on something I am not racing pro.
Old 11-23-2007, 10:15 AM
1320whtrex's Avatar
Default Re: (dwack91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">So do you get traction in like, 4th gear?</TD></TR></TABLE>
Nope...lol.. I wish...... It still untuned and I dont really abuse it 100% but I still have problems with traction..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
Holy crapola Batman. You gotten any runs in with it yet?</TD></TR></TABLE>
No runs yet at this time. I just been driving it on my own in my spare time to make sure that it can handle road trips... I plan to take it out of town from time to time....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">Very nice, but I can't see spending that kind of money on something I am not racing pro.</TD></TR></TABLE>
If you think about it, you end up spending the same or more than this on your car if you think about everything that you have done for it if your in the game for a while and you buy everything that is legit.... Its the inevitable. And besides.. When you love something, you dont really care about how much you put into it... As long as it makes you happy...
Old 11-23-2007, 12:05 PM
boosted_rex_bloNby's Avatar
so did you install the k series your self? i do like the interior also it is different.
Old 11-23-2007, 12:25 PM
1320whtrex's Avatar
Default Re: (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_rex_bloNby &raquo;</TD></TR><TR><TD CLASS="quote">so did you install the k series your self? i do like the interior also it is different.</TD></TR></TABLE>
Yeah.. With a Home Depot Jack, Jack stands and some determination..
Old 11-23-2007, 12:34 PM
downandgoing's Avatar
sick!! looks like it has a smoking problem tho....
prolly smoking to many V8s!! heh
Old 11-23-2007, 12:43 PM
turboZChatch's Avatar
Default Re: (thevtecnician)
SICK take this thing to get tuned and lets see some #'s
Good luck with it
Old 11-23-2007, 01:48 PM
DaNnYsEvEn's Avatar
Default Re: (turboZChatch)
nice, in for some #s
Old 12-04-2007, 07:17 AM
team1320_k26eg's Avatar
Default Re: (DaNnYsEvEn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaNnYsEvEn &raquo;</TD></TR><TR><TD CLASS="quote">nice, in for some #s</TD></TR></TABLE>
Old 12-04-2007, 08:52 AM
jdm-judah's Avatar
Default Re: My K24/K20 Turbo Crx.... (thevtecnician)
sick car. must have been alot of work
Old 12-04-2007, 10:18 AM
4door4sho's Avatar
def worth the money. nice setup
Old 12-04-2007, 10:28 AM
ESP.net's Avatar
Default Re: (CRXBart)
Nice build! definetly squeezed in there.... just tell us all it has a nice SAFE home/garage?
Old 12-07-2007, 06:20 AM
1320whtrex's Avatar
Default Re: (kassus)
Well I pulled out the swap about a week ago since I got some Rods and Pistons to put in there now.... CP 9:1 comp and IB H Beam Rods.. Numbers are coming soon....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by layedoutat0psi &raquo;</TD></TR><TR><TD CLASS="quote">hell yeah that thing is badass, and i bet you **** yourself everytime you drive it. do you have any estimated times you "think" it might run??? and what is that dash out of and how hard was it to get it to fit?
Im looking to get mid 10's out of it almost full potential.... Just wanna wait till I get it tuned first.... That dash is an Integra Dash 94-01
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">Glad you posted these pics. I noticed they were down on k20a.org. I was wondering how the car was doing. </TD></TR></TABLE>
Really? Not sure why.. Maybe its your comp....lol... I see them fine.... So far she's doing good..<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP.net &raquo;</TD></TR><TR><TD CLASS="quote">Nice build! definetly squeezed in there.... just tell us all it has a nice SAFE home/garage? </TD></TR></TABLE>
Yes.. Well she never sleeps outside at all.... You gotta be good to get it where it is...
All in all everything is going fine for now... The engine should be assembled today, if not today then over the weekend & then get my Traction Bar, then I just have to get it on the dyno & I will share the numbers with all...
Old 12-07-2007, 06:55 AM
Autoworks's Avatar
Default Re: (4door4sho)
That's beautiful...if there was a "smiley icon" for standing ovation I'd click it.
You're brave, I don't even want to tr making an invested parts list for my car...it'd be my luck I'd cause myself a massive heartattck
Old 12-07-2007, 07:19 AM
EFB055
~sp33~'s Avatar
I just like looking at the detail gone into that front end.
Old 12-07-2007, 07:29 AM
Flip's DC5's Avatar
Mad props to you bro! there used to be a "bow down" icon but I guess that's only on crsx. anyways, GL with the build I've subscribed to your build so keep us posted. Btw, I like the whole 1-pc fiberglass front end. Really adds to the "badass-ness" of it all.
Old 12-07-2007, 08:42 AM
bigluelok's Avatar
looks good
Old 12-07-2007, 11:41 AM
90efhatch's Avatar
Default Re: (Mr.Meowsome)
Thats a sweet ride post up some vids and some more pics when you get it done and tuned..
I really like the conversion from cable to hydraulic. I though about doing that.
Old 12-07-2007, 01:17 PM
xxnickpxx's Avatar
holy crap...... very nice, hi five ^_^
Old 12-07-2007, 03:08 PM
MurtazaDSM's Avatar
nice setup man, but you should have kept the gold rims you had in your first pic
Old 12-08-2007, 12:26 AM
1320whtrex's Avatar
Default Re: My K24/K20 Turbo Crx.... (MurtazaDSM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MurtazaDSM &raquo;</TD></TR><TR><TD CLASS="quote">nice setup man, but you should have kept the gold rims you had in your first pic</TD></TR></TABLE>
Oh don't worry... I still have those rims... I'm just waiting until the motor is done and I will buy some tires for them..... Those Gold sunflowers I got for $150 with almost new tires on them... Couldn't pass that offer up.....
Quick Reply: My K24/K20 Turbo Crx.... (Pics)
