OBD2 Port Location
Old 10-24-2007, 08:42 AM
Honda_Accord's Avatar
Default OBD2 Port Location
I got my car inspected and the guys say they cant find my damn OBD Port..
where exactly is this located at? (pics would be nice also)
thanks
*EDIT* in a hurry i didnt search but with a little i did find out where its located (behind astray)
Is this plug GREY? with 5 wires coming out of it? is that the OBD2 Port
Modified by Honda_Accord at 11:57 AM 10/24/2007
Old 10-24-2007, 08:49 AM
JDM_Acccord's Avatar
Default Re: OBD2 Port Location (Honda_Accord)
i believe it's behind your ashtray.. near your 12v outlet
Old 10-24-2007, 08:57 AM
Old 10-24-2007, 09:27 AM
GhostAccord's Avatar
It's not hard to find. pull out our ashtray and there it is. You don't need to remove anything else to get to it and there is no other connector there. You shouldn't see any wires hanging out of it.
They are usually black and look like the image below.
Old 10-24-2007, 09:31 AM
Default Re: OBD2 Port Location (GhostAccord)
ya thanks man that sit, i guess whoever had the car before me, took it off ... or something
Old 10-24-2007, 09:37 AM
Old 10-24-2007, 10:57 AM
Ok i went to go get it inspected and i failed i belive is the Monitor Part of it, it says the
02 Sens - Not Ready
EGR Sys - Not Ready
Catalys - Not Ready
However
Misfire
FulSys
Comp Cmpnt
02 Sense HTR
DLC
all passed and where ready
my question is what would cause those 3 not to be ready? I haven't done nothing to the engine except for Intake and Ebay Headers. I haven't disconnected my battery, anytime recently. However i didn't drive it when i lived in Virginia for a years time ( I did however start it up periodically). I cleaned the EGR ports once a few months ago.
Any ideas what would cause this would be appricated. Thanks
Car runs perfect, starts up prefect has good gas mileage for 156K miles
It does say something about if you dont drive your car enough after disconnecting the battery it can have the "not ready" settings and having the battery dissconnected .. which honestly in va i did disconnect it a few times and never really drove it afterwards, but i would think driving 1500 miles straight would set everything to be READy.
My check engine light does work (it lights up when i turn the car on and then goes back off after a few seconds) the only bulb NOT in there is the SRS light bulb, bu t i dont know if that really makes a difference
Old 10-25-2007, 03:13 AM
You should ask the previous owner if he removed or moved anything else while he was installing his stereo.
710times
08-21-2018 06:51 PM
B_Swapped93
03-23-2017 09:23 AM
jaydm ferio
12-12-2006 04:04 PM
[PL]typeR
05-03-2005 08:20 AM
hitvtecgetloud09
09-30-2004 08:25 AM
Quick Reply: OBD2 Port Location
