| Welcome to Honda-Tech! | ||
#1 | |
Today I decided to try testing out my 1998 GSR's full potential.
I was planning on revving first gear all the way up, but at around 6500-7000 the rpms just dropped like the power was cut. So I shifted to 2nd and kept going, kinda bummed. Any ideas why this happened? The car does have 147,xxx and it's bone stock.
#2 |
Have you checked out your cat? might be cloged
#3 | |
Nope, but that would be great since I'm looking to replace it anyway. is this a common problem?
#4 |
I've seen it happen a few times, I had an accord that had a similar power problem and it turned out the cat was clogged.
#5 |
i kinda dont think it would be the cat, if it was a dramatic cut off. i would think it would have to do somthing with spark/fuel. Or something on the more technical line.
#6 | |
I'm not sure if it completely cut, but the rpms dropped, and there was definitely a loss of power for a second before I shifted into second.
Any other suggestions?
#7 |
Daisy... Daisy...
1997 Acura Integra |
Was the car fully warm? Any CELs?
404: Care not found. |
#8 |
Certain VTEC cars will not allow you to use vtec until the car is warm enough, and just so you know, if I take my 96' gsr right when it is cold and get on it, it does exactly what you are saying. Let it warm up and then check again...
'97 Honda Civic LX - DD '10 Ram 1500 '12 Mustang Boss 302 - The 1st affordable mustang worth buying! |
#9 | |
I'm not sure how long I had been driving it that day, but no CELs at all. I guess I'll try it again when she's warmed up.
#10 |
check oil level also.. not enough oil pressure..
Vouches : Frank_2.0L |
#11 |
It's also possible your tach was just being slow, I know a friend of mine had that issue on a turboford he drove. He would hit rev limiter well before the needle would get to redline, but an aftermarket tach that was considerably quicker solved that issue.
[quote=yc_dc4mar]SEARCH! and kill yourself[/quote] |
#12 | |
2002 Mustang GT - Play car 1997 Civic DX - DD 1997 Integra LS - Sold |
#13 |
| Garage is empty, add now |
was ur car already warmed up? because if not it probably wasnt hot enough for your vtec to engage yet, or ur oil pressure was to high or to low.
#14 |
2003 BMW Z4 |
I doubt it is because of vtec.
are you certain the tranny was not swapped for a ls tranny. if it is a gsr tranny i would lean more towards you hit a fuel cut and thus it stoped making powerdroped your rpms etc. this could because of a few reasons.
For Sale: 2003 BMW Z4: 3.0, 6-spd, Navi, DVD, PWR Convertible, All Options, etc - http://hondamarketplace.com/showthread.php?t=2859904 SOLD: 91 Talon, 92 Hatch Si, 95 Jeep, 91 Teg, 92 CBR 600, 01 CBR f4i, 98 GSR, 03 G35 |
#15 |
Resident Gearhead
The tach on my Civic with a B16A is slow, some times I hear VTEC engage and the tach says about 4500 and then it cuts off well before redline on the tach. VSS I believe, but a lot of the answers above could be true as well.
#16 | |
#17 |
2003 BMW Z4 |
yeah i dont know what i was thinking when i wrote that.
my old NA Built DA non vtec would rev to 8800 with stock LS Gears so i dont know why i was thinking that, long day in the office i blame it on still could be a fuel cut though
#18 | |
It's not an LS tranny, it's bone stock like I said in the first post. I have a feeling it just wasn't warmed up, because it was probably around 6800.
#19 |
2003 BMW Z4 |
^ which would most likely be a 'fuel cut'
#20 |
* B A N N E D *
check you oil.....i had a prelude that was fairly built but before the motor was done it burned oil nasty (as the h22 is known to do)......i didn't know how low the oil level was, but when i tried running it up to redline one time it cut at like 6500rpms (felt like hitting a rev limiter)....checked the oil and it was INSANELY low, like 1 qrt.....filled it up, let the car warm up, and was good to go
moral of the story: with that many miles, monitor your oil level....let the car warm up fully before taking it to the higher rpm's as well my vote is for low oil level |
#21 | |
I just got an oil change, and my oil doesn't leak.
#22 | |
and yeah, they are known for electrical issues but in this case it wasn't one.
#23 | |
Ripped it today with a warmed up engine, pushed it passed 7k and everything was butter smooth.
#24 |
I figured it was just cold!!! Good deal!!!
| Tags |
| 1st, accord, b18, civic, forum, gear, hit, honda, line, red, redline, turbo, why, won, wont |
