How To: Cabin Air Filter For 1998 - 2000 Civic
Old 10-01-2007, 12:08 PM
  #26
h2392si's Avatar
Default Re: (Ron454321)
Excellent info!
Old 10-01-2007, 12:19 PM
  #27
philosofy1's Avatar
Default Re: (h2392si)
cool write up, are there cabin filters in 92-95 civics? if so, where?
Old 10-01-2007, 01:39 PM
  #28
Ek4 life's Avatar
Default Re: How To: Cabin Air Filter For 6th Gen with A/C (NOFX)
Nice write up... Got a question though, are there only two parts i would need to get in order to install a cabin filter? Where can I aslo get the civic cabin air filter frame from?
Two things I would need in to install this
1. Cabin Air Filter*:
- '97-'01 CR-V / '00-'06 Insight Cabin Air Filter
2. '97-'01 CR-V / '00-'06 Insight / '96-'00 EDM <U></U> civic cabin air filter frame
Old 10-01-2007, 01:56 PM
  #29
Malakai's Avatar
thing i dont understand is, if the filter is on the passenger side, behind the glove box, why do u need to take off the center part by the 12v outlet and the piece under the steering wheel?
Old 10-01-2007, 09:17 PM
  #30
H-T White Ops
NOFX's Avatar
Default Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">cool write up, are there cabin filters in 92-95 civics? if so, where?</TD></TR></TABLE>
Already answered on the bottom of page one.
No. Not as far as I'm aware at least. EDM VTis from those years don't have them, so I doubt any of them did.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek4 life &raquo;</TD></TR><TR><TD CLASS="quote">Nice write up... Got a question though, are there only two parts i would need to get in order to install a cabin filter? Where can I aslo get the civic cabin air filter frame from?
2. '97-'01 CR-V / '00-'06 Insight / '96-'00 EDM <U></U> civic cabin air filter frame</TD></TR></TABLE>
Everything needed is listed. The CR-V and Insight parts are sold in the US because they came in USDM models. So you can go to Autozone and order the filter and Honda to order the frame. I even listed the part numbers for you.
The Civic parts ARE THE SAME PART NUMBER as the parts I listed unless otherwise noted. And the parts are the same nonetheless.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai &raquo;</TD></TR><TR><TD CLASS="quote">thing i dont understand is, if the filter is on the passenger side, behind the glove box, why do u need to take off the center part by the 12v outlet and the piece under the steering wheel?</TD></TR></TABLE>
Also already answered on page one.
There is one 8mm bolt that is difficult to get to on the left side of the bar that's under the glovebox. You need to remove the bar to access the filter.
In order to reach that one 8mm bolt, you need to remove the middle piece. And in order to remove the middle piece, you need to remove the driver's side piece.
Old 10-02-2007, 11:25 AM
  #31
Malakai's Avatar
ok cool, thanks for clearing that up!
Old 10-02-2007, 11:37 AM
  #32
bpr0422's Avatar
Default Re: (NOFX)
while you were down there.. you could've also disconnected the blower motor, and clean that out..
lots of crap gets stuck there...
it helps if you use a small socket.. because its hard getting a screwdriver down there.. to drop the motor
Old 10-02-2007, 12:01 PM
  #33
HT White Ops
Eran's Avatar
Default Re: (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">while you were down there.. you could've also disconnected the blower motor, and clean that out..
it helps if you use a small socket.. because its hard getting a screwdriver down there.. to drop the motor </TD></TR></TABLE>
Not a whole lot gets stuck in the blower motor. I've cleaned mine out before after a long fall, and the most was a couple pine needles and some leaves.
Old 10-02-2007, 01:37 PM
  #34
H-T White Ops
NOFX's Avatar
I have luckily never really had leaves coming out of my vents. I can't remember it ever having happened at least. It has happened a few times in Eran's (which does not have an evaporator), but not mine.
So I doubt there would even be much, if anything in my blower.
Old 10-02-2007, 08:50 PM
  #35
sniggler316's Avatar
Default Re: (NOFX)
Nice! How did you find out about this? I have asked around and always been told "No way" I ended up doing a kind of ghetto rigged filter on the blower motor, but I like this better. Thanks NOFX!
Old 10-02-2007, 09:43 PM
  #36
00ekcoupe's Avatar
Nice write up.
Old 10-02-2007, 10:21 PM
  #37
H-T White Ops
NOFX's Avatar
Default Re: (sniggler316)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniggler316 &raquo;</TD></TR><TR><TD CLASS="quote">Nice! How did you find out about this? I have asked around and always been told "No way" I ended up doing a kind of ghetto rigged filter on the blower motor, but I like this better. Thanks NOFX!</TD></TR></TABLE>
I was on a Dutch site and saw someone else's how to for changing the filter (they have the filters in their cars already). I've always wanted one, so I started lokoing around to see if they were the same parts.
I have the EDM EPC and it shows that at least certain Civics in Europe have this. I compared part numbers and they matched US numbers for other models.
The EPC shows the seal and the frame separately, but after buying the frame I found out that the seal is already included.
Old 10-10-2007, 06:36 PM
  #38
mistahmac's Avatar
good post. im doing it this weekend..
Old 10-10-2007, 09:32 PM
  #39
confucioussae's Avatar
Default Re: (mistahmac)
What does the stock filter look like that you removed, is it just a metal mesh without some sort of filter element?
Would it be possible to gut the stock one, and put a fitting filter inside it? I haven't ever pulled out the filter .
Thanks
Old 10-10-2007, 09:49 PM
  #40
HT White Ops
Eran's Avatar
Default Re: (confucioussae)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucioussae &raquo;</TD></TR><TR><TD CLASS="quote">What does the stock filter look like that you removed, is it just a metal mesh without some sort of filter element?
Thanks</TD></TR></TABLE>
Read the ******* thread, dude. There IS NOT a filter in there originally.
Old 10-25-2007, 09:57 PM
  #41
sk8shorty012's Avatar
Just an update to anyone that tries this. The separate filter frame is on backorder status from Honda, so the only way to do it now is to buy the complete assembly for more money
Old 10-25-2007, 10:08 PM
  #42
H-T White Ops
NOFX's Avatar
Default Re: (sk8shorty012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8shorty012 &raquo;</TD></TR><TR><TD CLASS="quote">Just an update to anyone that tries this. The separate filter frame is on backorder status from Honda, so the only way to do it now is to buy the complete assembly for more money </TD></TR></TABLE>
Do you mean the filter assembly? Looks lik it just includes the filter frame, seal (which my filter frame came with a seal) and the filter. So basically, it just forces you to buy the Honda filter instead of an aftermarket one. So, not too bad, but it keeps you from saving some cash.
Old 10-26-2007, 11:53 PM
  #43
I meant the frame by itself. Anyhow, I just did this today and it worked out great. Thanks for the helpful writeup, it was useful at someplaces. Alot of crap in there and as Amy said, airflow actually increases along with quality of the air
Oh, and on a final note, its VERY apparent that there shouldve been one there from the factory.
Old 10-27-2007, 02:39 PM
  #44
H-T White Ops
NOFX's Avatar
To give everyone an idea of what this filter will catch, here is a dirty filter from a European Civic.
And I believe this is a charcoal filter btw.
Old 10-27-2007, 03:22 PM
  #45
bmoua's Avatar
Default Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">To give everyone an idea of what this filter will catch, here is a dirty filter from a European Civic.
wow, thats crazy
Old 05-22-2008, 12:52 AM
  #46
HT White Ops
BlackDeuceCoupe's Avatar
Default Re: (NOFX)
What am I missing here?!?!?
If I buy the assembly package, it's $40.27...
If I buy the parts separately, it's only $28.54...
Old 05-22-2008, 09:33 AM
  #47
H-T White Ops
NOFX's Avatar
Default Re: (BlackDeuceCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackDeuceCoupe &raquo;</TD></TR><TR><TD CLASS="quote">What am I missing here?!?!?
Things you are missing:
1) The frame by itself is on backorder from Honda.
2) I listed the exact part numbers you need along with the list prices in the first post. The list price for the entire frame and all components besides the filter is $13.74.
3) HondaPartsCheap apparently should be renamed to HondaPartsPricedtoRipYoutheFreakOff.
Old 05-22-2008, 09:58 AM
  #48
Frickr's Avatar
Default Re: (NOFX)
great writeup, next time i get out of the fields, and get up to the big city, ill have to stop by the honda dealership and get these things on the way. i dont have any leaves or anything blowing out, but i hope this will help from having dirt and dust blowing up when i drive down a gravel road.
Old 05-22-2008, 10:17 AM
  #49
Jonathan_ED3's Avatar
Great find Amy!
I love how simply universal Hondas are across the board. Makes these kinds of upgrades possible!
Too bad us 5th gen guys are still screwed. I hate how messed up evaporator cores get without these filters!
Old 05-22-2008, 07:28 PM
  #50
polything's Avatar
I have done this..! great info and fresh clean air.
also i have an xtra filter frame for sale. hit me up!
Quick Reply: How To: Cabin Air Filter For 1998 - 2000 Civic
