My D16Y8 300-350 whp Build up
Old 09-13-2007, 07:51 AM
JDMCRX's Avatar
Default My D16Y8 300-350 whp Build up
The stock motor after 60,000km of boosted KM passed away spun a rod bearing on the #1 piston.
So i decided to build my motor .
D16Y8 Block
CP Pistons .20 over
Crower Rods
ACL bearings machined out to 8mm on crank side.
Modified OEM Honda Oil pump
OBX modified oil pan to fit Y8 block.
D16Y8 Head
REV 1mm Over Valves
REV Valve spring retainers
REV Valve springs
Some Josh port work.
Here are some quick pics, Ill post more later.
26mm seats vs 28mm with some clean up just the begining
Some cleaning of the right port not done more pics soon
Some head pics still needs to polished and some clean up
Well here is the finished shot of the head.
Some shots of the DP and Oil pan.
Inside shot of the oil pan
Block all ready to go
Plastic Gauged all withn spec
Pistons in there home
Block all assembled
Gurdle Notching for Eagle rods with 3/8" rod bolts
Oil Pump mods some of
Some pics of the oil pan clearence.
Well here are some underhood shots. Still need to put the new valve cover on and the catch can.
Some ground clearence of the pan. Took about 5.6L of oil
Modified by JDMCRX at 11:55 PM 10/1/2007
Modified by JDMCRX at 3:24 AM 10/2/2007
Modified by JDMCRX at 7:04 PM 10/8/2007
Old 09-13-2007, 03:14 PM
boostincoupe's Avatar
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: My D16Y8 300-350 whp Build up (JDMCRX)
That oil pan will ride the ground!
Old 09-13-2007, 04:42 PM
civicious's Avatar
That oil pan is hideous...how many gallons does it hold?
Old 09-13-2007, 04:47 PM
i ♥ snails
quicksilver1689's Avatar
Nice work on the build, i love these kind of setups. Did you do the portwork yourself? Yeah that oilpan has a huge sump
Old 09-13-2007, 05:48 PM
standbackimapro's Avatar
Jesus, how many quart oil pan is that?
And what did u mean by modified oil pump?
Old 09-13-2007, 10:18 PM
Drew Peacock's Avatar
Default Re: (standbackimapro)
port work is interesting goodluck.
Old 09-13-2007, 11:20 PM
JDMCRX's Avatar
Default Re: (turbozxi)
The oil pan sits .25-.50" higher then the D16Y8 oil pan. Its suppose to hold 5.6L so we will see. Im going to weld it up tomorrow and ill measure out the total oil cap. The head work was all done by me. Pretty much the same as my last motor.
Old 09-13-2007, 11:22 PM
JDMCRX's Avatar
As for oil pump mods basicly opening up the pick up and cleaning up all the sharp edges. On the oil pressure side were the pump feeds the block will be rounded out and opened up and polished. The relief valve i have a shim thats i believe. .40th thinner. Ill dig up my old oil pump mods.
Old 09-14-2007, 03:22 PM
JDMCRX's Avatar
Default Re: (JDMCRX)
Oil pan is alll welded up
Old 09-16-2007, 04:48 PM
civicsi940's Avatar
can't wait to see the updates
Old 09-16-2007, 04:58 PM
Newt Dog's Avatar
Default Re: My D16Y8 300-350 whp Build up (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">That oil pan will ride the ground! </TD></TR></TABLE>
I was wondering this also. Other then that.. Nice build.
Old 09-16-2007, 05:38 PM
Man U FTW
Schister66's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote"> Its suppose to hold 5.6L so we will see. Im going to weld it up tomorrow and ill measure out the total oil cap.</TD></TR></TABLE>
Thats not as much as i thought. From the pics that oil pan looks huge, but only holds 6 quarts. Nice build so far
Old 09-16-2007, 06:23 PM
JDMCRX's Avatar
Default Re: (Schister66)
Well here is some shots of the motor u can see the sump hangs higher
Old 09-17-2007, 05:18 PM
JDMCRX's Avatar
Well the pan holds 5liters with the oil pick up in it and so forth so another .5-.75 Liters in the oil filter and head and lines id say maybe 1 liter
Old 09-21-2007, 08:30 PM
Go Tigers!
Bense's Avatar
awesome
Old 09-23-2007, 06:47 AM
JDMCRX's Avatar
Update motor is getting assembled today ill post some pics of the final work soon
Old 09-23-2007, 04:43 PM
b18c1ej8's Avatar
one of the nicer d bangers ive seen
Old 09-23-2007, 05:37 PM
DaveF's Avatar
Default Re: My D16Y8 300-350 whp Build up (b18c1ej8)
1st time ive seen someone polish the inside of the block like that. ive seen v8 guys do it in the past to promote drainback, but that is a 1st on a honda (for me anyhow)
nice build up
Old 09-23-2007, 07:02 PM
JDMCRX's Avatar
Default Re: My D16Y8 300-350 whp Build up (DaveF)
Thanks man
Motor should be all done next weekend Ran into a problem this weekend with the ARP's hitting the main crank gurdle
Old 09-23-2007, 08:08 PM
KhanhCord's Avatar
lo0ks purty .. g'luck
Old 10-01-2007, 02:55 PM
JDMCRX's Avatar
Default Re: My D16Y8 300-350 whp Build up (KhanhCord)
Alot more pics posted. Motor is in car now.
Old 10-01-2007, 03:00 PM
90dxhmt's Avatar
Great work so far looks like this should be a solid setup when its done What is the rest of the setup turbo wise etc?
Old 10-06-2007, 03:18 PM
JDMCRX's Avatar
Default Re: My D16Y8 300-350 whp Build up (90dxhmt)
Well its alive ill get some pics this week up.
Old 10-06-2007, 03:19 PM
JDMCRX's Avatar
As for oil pressure at idle at 900 rpm im getting about 20-22psi warm.
Old 10-08-2007, 10:22 AM
JDMCRX's Avatar
Well motor is up and running. 8psi first night was pulling well set my AF to 11.9-12.0 car runs stronger then at 12psi on old motor. Put it to 12psi and the car pulls very well . But my PCV is leaking and pressuring my motor so dipstick popped out. So going to put the new valve cover on this weekend with the -8 breather ports and catch can.
Quick Reply: My D16Y8 300-350 whp Build up
