Synthetic vs. Non-synthetic Transmission fluid
Old 06-16-2002, 10:43 AM
Si_Allen's Avatar
Default Synthetic vs. Non-synthetic Transmission fluid
I am wondering what is better to run in my 1992 civic si hatch. I bought some mobil one fully synthetic transmission fluid but haven't put it in yet. Also how often should transmisson fluid be changed? Tell me what you all think, what do you all run how does it treat you? thanks -Allen
Old 06-16-2002, 10:46 AM
neveronlines2k's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (Si_Allen)
I run neo trans fluid and I change mine every 20,000 to 25,000. I think recomends every 30,000. I like the NEO fluid I would recommend it
Old 06-16-2002, 02:21 PM
ejprimo's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (stuckatworksi)
i use the mobil 1 syn. tranny fluid...it works fine
Old 06-16-2002, 02:23 PM
buzlink's Avatar
I use AMSOil synthetic in mine.
Works great so far. Oh and its a synthetic. Expensive ****.
Old 06-16-2002, 02:44 PM
VXpride's Avatar
The tranny fluid works good.
Old 06-17-2002, 03:49 AM
D Tranny Guru
Mista Bone's Avatar
10w30 or Honda MTF. The Mobil Syn. tranny fluid is for automatics.
I know D trannys, do YOU?
Old 06-17-2002, 03:53 AM
IdotheSHOCKER's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (Mista Bone)
Another Mr. Bone "TuDe" thrown at us.
Old 06-17-2002, 04:53 AM
D Tranny Guru
Mista Bone's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (EGB18hatch)
I guess you have nothing better to do but go around CRYING because you are clueless and have no idea.
Research is key.
Old 06-17-2002, 02:55 PM
Si_Allen's Avatar
It says on the the bottle I have here in my hand that it offer maximum protection for manual transmissions where an API GL-5 quality oil is recommended. What is recommended for a d=series tranny? Sounds like its meant for manual and automatic trannys.
Old 06-17-2002, 02:56 PM
Si_Allen's Avatar
ttt
Old 06-17-2002, 05:35 PM
ejprimo's Avatar
you dont buy mobil one transmisson fluid cuz thats for auto. you buy the mobil one gear oil.
Old 06-17-2002, 05:52 PM
shawnhayes's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (ejprimo)
Although Mobil one gear oil may be acceptable for Honda manual transmissions (because of superior formulation, and the fact that gear oil is close to motor oil), the manual specifies MOTOR OIL. A more appropriate fill would be Mobil-1 10W-30 (as specified in the manual).
Shawn
Old 06-17-2002, 06:36 PM
Plan B's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (shawnhayes)
mobil 10-30 is good,
don't use redline, not good for honda's.
Old 06-17-2002, 07:28 PM
JeffS's Avatar
Keep in mind guys that the things that make an oil good for an engine aren't necessarily good qualities for a transmission. In an engine, wear properties, heat resistance and overall friction are important. The tranny is subjected to much less of these stresses. The syncro's in a honda tranny need a certain amount of friction to work properly... meaning that if you use some super-slippery lubricant it might be great for the gears, but would result in torn up synchro's.
There's stories of people running into problems after using various synthetic oils in the transmission. Most of them seem to be heresay though. Personally, while I run Mobil1 in my engine, I choose to stick with Honda MTF for the trannies. Wear is rarely the thing that kills a tranny anyway... it's abuse such as mis-shifts, forcing into gears, etc...
Old 06-18-2002, 06:09 PM
shawnhayes's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (JeffS)
Would 100,000 miles of trouble free operation of my 1992 Honda Civic with Mobil-1 motor oil as the transmission fluid sway you at all?
Shawn
Old 06-18-2002, 06:19 PM
deepnite's Avatar
honda does not recommend syn. tranny fluids..30w dino. juice works best
Old 06-18-2002, 06:21 PM
deepnite's Avatar
yup, yup
Old 06-18-2002, 06:22 PM
Si_Allen's Avatar
sounds good to me. I like to here all this info to make a more educated decision. ttt
Old 06-18-2002, 06:46 PM
shawnhayes's Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (deepnite)
Ummm. Honda doesn't recommend 30W. Its absence from the manuals confirms that, but where does Honda recommend against synthetics?
Shawn
Old 06-24-2002, 09:31 AM
Si_Allen's Avatar
ttt
Old 06-24-2002, 09:36 AM
SIINSI's Avatar
I just put in BG Synchroshift Synthetic MTF. Works AWESOME....
Also, here is a post I recently made and you can get some more views on it.
https://honda-tech.com/zerothread?id=213002
Also, you can buy it here...
http://www.machv.com/bgsynchroshift.html
Hope that helps.
Miguel
Old 06-24-2002, 11:21 AM
Kamin's Avatar
honda MTF
Old 06-24-2002, 12:36 PM
Charles B.'s Avatar
Default Re: Synthetic vs. Non-synthetic Transmission fluid (KAMiN)
i use the mobil 1 sythetic gear oil 75w-90
Old 06-24-2002, 12:37 PM
DragII's Avatar
honda MTF
Old 06-24-2002, 12:50 PM
Viorent GRIP!'s Avatar
Im running Honda ATF. Had Redline before a lil too slick for my worn 3rd gear, it kept crunching, threw in some ATF boom crunching subsided. yay!
Quick Reply: Synthetic vs. Non-synthetic Transmission fluid
