vtec help please
Old 12-14-2009, 04:38 PM
corey89crx's Avatar
Default vtec help please
hey guys my crx is throwing a check engine light and my vtec is not working if install a vtec crontroller will that alow the vtec to kick in? or noo since check engine lights on.. my motor is a d16y6 with obd1
Old 12-14-2009, 06:19 PM
Matt55's Avatar
Default Re: vtec help please
The cel is for vtec not working?
Old 12-14-2009, 06:24 PM
corey89crx's Avatar
yea the vtec cel is working.... its throwing the check engine for the speedo not working..
Old 12-14-2009, 06:27 PM
crx_si-r's Avatar
fix the problem then your vtec will come back. are you running a cable or electric vss? if cable it probably just came loose. dont try to bypass a problem instead just fix it since you already know what it is
Old 12-14-2009, 06:28 PM
Matt55's Avatar
so it wont let you go above a certain rpm? im just makin sure
Old 12-14-2009, 06:29 PM
Matt55's Avatar
yea, vtec works off of speed input
Old 12-14-2009, 06:35 PM
corey89crx's Avatar
yea it lets me rev out but just the vtec doesnt work because of the check engine light...
the engine lights on because i have a stock 89 hf cable tranny with a 92 si motor which is a digital speedo computer.... is there an adapter?
Old 12-14-2009, 06:38 PM
Matt55's Avatar
what makes you think ur vtec isnt working?
Old 12-14-2009, 06:59 PM
crx_si-r's Avatar
im assuming you dont know much about swaps. your cable tranny has nothing to do with your CEL being on. what ecu are you running? it makes no difference which transmission your running as long as it runs. your speed sensor sends a signal to your cluster via the cable that goes from your transmission to your cluster, if this cable is loose then it will not send a proper signal. the signal for cable transmissions is sent via rotations of the cable itself which winds up in teh speedometer cluster and then via i believe a magnet which picks up the signal and displays it for you on your cluster. check to make sure the cable isnt loose.
on another note, does your vtec solenoid even work? to check it attach a wire to the singe wire coming off the solenoid to positive power source (battery), next you should hear a click. the click means its engaging.
just so you know im running an obd1 converted LS/Vtec with a GSR cable transmission, forget what your thinking about it being the transmissions fault you have a CEL.
playin4keeps
11-24-2010 04:16 AM
Fastwhip
08-02-2007 03:58 PM
si90rex
07-05-2006 03:12 PM
dre23
11-14-2005 10:54 AM
Quick Reply: vtec help please
