#1 | ||||||
http://images.honda-tech.com/set1/smile/embeer.gif http://images.honda-tech.com/set1/smile/emcocktl.gif http://images.honda-tech.com/set1/smile/embeer.gif http://images.honda-tech.com/set1/smile/emcocktl.gif Free The Mind - NGE -_-</FONT> |
#2 | |
Brake drums: these usually come on older/lower model trucks, cars, and diesels. they aren't bad brake setups, just not the best for high intensity track racing. many people just say forget it and ditch them for a rear disk conversion, but some people don't have the resources/money to do that at the time. if you just wanna stick it out with the drums there is a way out. there is shoes (like pads but for drums) which as opposed to clamping in on something to create friction to slow down, it pushes out on the inside of the drum to slow itself. upgrading anything more than the shoes will not be profitable in brake performance. may as well upgrade to rear disks
rear discs: this could be an extremely good bang for the buck upgrade since most cars with rear drums (in the honda world anyway) have a superior counter part with rear discs. 4th gen civics can directly swap with 2nd gen integras and have rear discs. 5th and 6th gen civics can grab them from either a 3rd gen teg or 99-00 si model. pros of rear discs: --> preforms noticeably better than drums, stock vs. stock. --> easy to find upgrade from faster/higher models --> fairly inexpensive (about $100-200 depending on variables) --> upgradeable- you can upgrade calipers, rotors, and pads fairly easy cons of rear discs: --> if the proportioning valve isn't right for the car and brakes, they may not stop as good as the drums. Master Cylinder: these are another part that can be replaced by an oem part. since the brake pedal is more or less connected to the booster which is connected to m/c this can also help pedal feel and reaction. some replacements are: --> a standard replacement from the same make and model if yours isn't performing as well as it could --> a m/c from a higher trim or power model, when replacing a civic with an integra it is wise to grab the brake booster also seeing as its not a direct bolt up to the civic brake booster. but one that is a direct bolt up is from a 1991 civic which is 15/16 (proportioned like integras) that directly bolts to the civic brake booster. --> an aftermarket m/c designed for your specific caliper and rotor setup. there is also m/c braces which prevent it from moving when you mash on the brakes. the usually mounts in front of it and to the chassis. this can also help pedal firmness. a cusco m/c brace for an EG/DC ![]() Last but not least 2 things that can improve your acceleration, braking and handling at the same time! yes, all that at the same time. witchcraft you say? no it is.... weight reduction:removing excess weight from your car can help a lot that might cost a little. also re-arranging the weight to a lower part of the car can help too, ex: instead of the battery sitting high in the engine bay, you can relocate it to sit lower like where the spare tire was. there are many ways to reduce weight, be creative but SAFE! Tires: the only part of your car that touches the ground (unless you got a m4d jdm towhook doll). the "stickier" or softer the tire, the better it can grip. which will help slowing down and keep the brakes from locking up, because some times rolling wheels can slow a car down faster then locked up wheels (hence ABS). but be careful, softer tires wear faster than regular tires. here's the highly popular FALKEN AZENIS RT-615
#3 |
Nice!!!
#4 | |
thanx
![]() took me 6 hrs to do =/
#5 |
Do you have anymore info on the Master cylinder brace? I think this would be a great sticky and a good place to post reviews of different brake products.
#6 | |
#7 |
I mean like experiences.
#8 |
Nice.
= Track Braking for dummies.
Oh snappies L:O I'm Back. |
#9 | |||
#10 |
Nice post, i vote for sticky. Nice info for newbs
#-~-|D15b vtec block with Oem bearings - Lightweight Vx Flywheel and Crank pulley|~-~# #-~-|D16z6 head with valve job, new valve seals and milled to remove warpage|~-~# #-~-|95 Vx Hatchback . GSR Wheels, GSR Brakes, GSR Sway bars, and GSR LCA's|~-~# |
#11 |
Very good general info about brakes - I'm adding it to my FAQ section now.
Need suggestions on good xbox 360 games - I don't play multi-player (online) and first person shooters I reserve for the computer - Any suggestions are welcome '97 EX - Stock as stock can get - Daily driver, KYB struts, Tokico reds, I/H/E |
#12 | |
thank you
#13 | |
Nice, very informative.
"Shifting to 5th, nothing better." Quote:
99 EJ6 - Totaled http://images.honda-tech.com/set1/smile/emthdown.gif God's In His Heaven, All's Right With the World |
#14 |
2008 Porsche 911Join Date: Apr 2007
Very nice write up.
Nikon l Flickr Skunk2 IM & M/T Slicks BNIB 4 Sale CHEAP NEED GONE ASAP!! LOUD NOISES!! |
#15 | |
=G106= |
#16 |
HONDA The Power of Dreams
1994 Honda CivicJoin Date: Nov 2007
Great job man
#17 |
great write up
quick question though, ive been playing with then idea of swapping some ef calipers and rotors onto the front of my eg lx....i recently discovered the older rotors are actually larger, but would still fit in my steel running shoes. is this a viable option, or not worth the trouble? |
#18 |
old thread but has alot of very useful information, thanks op
| Bookmarks |
| Tags |
| asshole, brake, bullshit, calipers, civic, cooling, diy, dryer, duct, ducts, honda, hose, monoblock, spoon, tuna, upgrade, upgrades |
