Classic Hondas All Pre-1988 Hondas.
FAQ Thread v1 [NO COMMENTS OR BUMPS]
Old 07-01-2007, 11:14 PM
doublethink's Avatar
Default FAQ Thread v1 [NO COMMENTS OR BUMPS]
NOTE: Much credit goes to:
- thisoldhonda.org
- 1stgencivic.org
- 3geez.com
- redpepperracing.com
which is where many of these links are from. Lets keep this thing growing!
=========<u>GENERAL LINKS:</u>=========
600
Honda 600 Source Specs for coupe and sedan, technical reference, parts for sale, and publications.
Honda Sports Registry S Series owners club, information, cars for sale, brochures, and more. (NY)
Steve's Honda 600 Coupe Pictures, documents, links, mechanical information and more.
Accord
First Gen Accord Information History of the Accord model, specs on engine, emissions, tranny and much more. Good pictures and lots of good info.
First Gen Accords The site text is in Polish but has a number of good photos and links.
Third Gen Honda Accords FAQs, Message Board, Technical Info, Gallery and more, all for the 3rd gen Accord (86-89).
Third Gen Honda AccordsThe site text is in Russian but has a number of good photos and links, and shop manual links.
Civic
1200 Civic Club More on the first gen Civic, discussion board, members area, gallery and more.
1st Gen Civics Discussion Forum, Members Garage and Photo Gallery, Knowledge Base, Engine & Chassis Codes Models and more.
2nd Gen Civics Discussion Forum, Members Garage and Photo Gallery, Knowledge Base, Engine & Chassis Codes Models and more.
CRX Articles and Information CRX Articles and Information, tech data, buying a CRX, concepts, more.
Honda Civic Wagons Honda Civic Wagon Discussion Forum, find parts, events, cars for sale and support with your projects.
The CRX Page Tech specs, maintenance, ads, gallery and more.
Misc
Australian Honda Owners Contains info on S600, S800, City Turbo and 1300 models.
Carfolio - Honda Model Specs This website has more than 300 Honda model specifications including wheelbase, curb weight, engine info, fuel capacity, ground clearance, HP and much more.
First Gen Hondas The site text is in German but has a number of good photos and links.
Helm Find owners manuals, factory shop manuals and TSBs for older Honda models. Alot of good info to help with repairs and restoration.
Honda 1300 Coupe 7 This rare 1972 Honda 1300 is in North America and avilable for dealership visits.
Honda 1300 Coupe Registry History, information, member vehicles, tech support and more.
Honda Car Club of Victoria Australian Honda car club, many photos.
JC Taylor Classic Car Insurance
NADA Special Interest Vehicle Values Find out what your car is worth or what the car you want to buy is worth.
The Honda Beat Honda and Acura news, articles, classifieds, racing updates, high mileage stories, vanity license plates and much more.
Prelude
Craig's Prelude Site Pictures and info on Craig's two Preludes.
Honda Prelude Pictures and info on all generations of Prelude but not in English!
Second Gen Prelude Enthusiast Message board, pictures, info, stats, performance parts list, famous cars and much more.
Third Gen Prelude Restoration and enhancements, engine, suspsension, body, pictures, info etc.
Third Gen Prelude Pages Resource for common repairs, FAQs, wallpaper and more.
Restoration
N360 Restoration Project Diary of repairs, mystery parts, parts for sale, many good pics.
Prelude Restoration Follow the progress of the restoration work on a 1980 Honda Prelude.
S600 Restoration Follow the restoration progress on a 1965 Honda S600 convertible.
=========<u>SPECIFIC HOW TO'S:</u>=========
Any Vehicle
DIY Cylinder Head porting
Make your own cold air intake
Shaving Antenna, Spoiler, Emblems etc....
Check an Alternator
Check Brake Booster
Accords
Convert your carburetted 86-89 Honda Accord to PGM-Fi
Install a Nitrous Purge kit on your Accord
Replace Oil Filter Base Gasket
Convert Automatic to 5 Speed Manual
B16 Intake Manifold on A20 / B20
Changing Water Pump
How to remove & install piston rings
Replace Starter
Check Fill Fluid & Adjust Auto Transmission
Installing a Block Heater
Running Keihin 2bbl Carburetor without emissions or electronic contorls.
Adjusting Valves / Valve Adjustment
Change Thermostat
Injector Installation
Recharging and converting your A/C system.
Nippon-DENSO AC Compressor Stator Coil Replacement
Camshaft Removal/Replacement
Increase Oil Pressure ( PSI )
3rd Gen Accord Clutch Replacement
3rd Gen Accord 1st Gen Integra Hybrid Transmission
Bleed & Flush Cooling System
A/C Removal
Remove Power Steering (and changing PS fluid)
Change Your Timing Belt
1st Gen Civics (1973-1979)
<u>Maintenance & Specs:</u>
VIN Chassis Codes
VIN Engine Codes
Wiring Diagrams (1973-1979)
Mugen Ms-1,Ms-2 Ms-3 Parts Papers
1200 Service Info
CVCC Service Info
Engine Specs
Tranny Specs
Paint Codes
1200 Engine Timing
<u>Upgrades:</u>
DR.Zoom's How to Page:
-Jetting for a single weber 40 DCOE
-Junkyard Hunting Tips
-Koni inserts with Ground Control coil overs
-How to install 1335 crank and rods
-Weber DCOE Jetting for ZC / D16A1 Integra / Civic DOHC
-Jetting for Dual Mikuni 36PHH cars. Close for Dellorto DHLB 35mm
-How to install the Honda Goldwing motorcycle higher compression pistons
Matt's 1200cc Upgrade Page
Bolt On Mods
Cylinder Head Mods
Bottom End Mods
Engine Swaps
Performance Parts
1200 Distributor Upgrade
Induction Options
2nd Gen Civics (1980-1983)
VIN Chassis Codes
VIN Engine Codes
Engine Specs
(Need more here!!!)
3rd Gen Civic & 1st Gen CRX (1984-1987)
84-87 CRX Full Specs
VIN #'s Explained
Gear Ratios
Idle Fluctuation
Reset the ECU
Replacing D16A1 Headgasket
Hardwire Cooling Fan
<u>Upgrades:</u>
Correctly Lower a First Gen CRX
Lowering and Rear Axle Problems
DIY Adjustable Panhard Bar
86-87 CRX Door Panels on a 84-85 CRX
DIY Alternator Rebuild
JDM Digital Dash Install
DIY Black Housing Headlights
86-87 CRX Headlights onto a 84-85 CRX
Steering Wheel Compatibility Info
Seat Swap Info
Sway and Torsion Bars
Increase Negative Camber in the Frontend
Rear Camber/Toe Adjustments
Rear Spring Replacement
Install Aftermarket Torsion Bars
Stiffer Front Torsion Bars
Stiffer Motor Mounts
Tuning Stock Carb For More Power
Rear Disc Brakes
Big Brake Upgrade
Master Cylinder Upgrade
88-91 CRX Brakes on a 84-87 CRX
<u>Swaps:</u>
88+ D-Series Into 84-87 Civic/CRX
General B and D Swap Info
B-Series Wiring Chart for 85-87 CRX Si
Non-Vtec B-Series Wiring for 85-87 CRX Si
SI head on a DX Block
Feel free to help me add to this, I'd like to get as many good links in here as possible.
I will update this main with things you add.
Modified by doublethink at 2:50 PM 7/2/2007
Old 03-27-2008, 07:32 PM
ice_man_619's Avatar
Default Re: FAQ Thread v1 [NO COMMENTS OR BUMPS] (doublethink)
need help in converting my 1987 honda civic from a carbureator to a fuel injected need help quick
Old 09-01-2008, 05:18 PM
hondalx89's Avatar
HELLO I GOT A QUESTION I GOT MY CAR MOTORS REBUILT NOW WHEN I PUT THE CAR IN DRIVE IT VIBRATES REAL HEAVY AND WHEN I PUT THE CAR IN PARK IT DONT VIBRATE AND ALSO WHEN I PUT MY A.C ON THE CAR VIBRATES EVEN MORE CAN SOMEONE HELP ME WITH THIS PROBLEM ? THANKS ...
Old 09-01-2008, 06:42 PM
badboyr66's Avatar
Default Re: FAQ Thread v1 [NO COMMENTS OR BUMPS] (ice_man_619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ice_man_619 &raquo;</TD></TR><TR><TD CLASS="quote">need help in converting my 1987 honda civic from a carbureator to a fuel injected need help quick </TD></TR></TABLE>
Would like to see this as well. I will look for any useful links
Old 06-05-2009, 08:21 AM
scubb's Avatar
Thanks for the links buddy you have really worked hard.
Old 08-20-2009, 12:10 PM
E-AT_me's Avatar
huh. it's a shame that none of the 84-87 links work.. i wonder why? it would be nice to have those working again because i JUST ANSWERED the exact same question twice, which SHOULD BE in the FAQ but it is blocked out.. huh.
Old 08-24-2009, 05:20 PM
dasreedster's Avatar
I agree, might as well remove the links.
Old 03-07-2010, 05:46 AM
TRIAL USER
Civica2k's Avatar
Great list! Got some excellent resource here.
Old 10-26-2010, 04:16 PM
catlvr's Avatar
very helpful list of links, thanks!
90babyblue
12-07-2004 10:57 AM
Omicron
09-05-2003 09:19 PM
ACC0UPE
04-26-2003 11:43 AM
Quick Reply: FAQ Thread v1 [NO COMMENTS OR BUMPS]
