New anodized & polished catch can kits!!!!!!!!!!!!!
BREATHER TANK KIT
1 Gallon Capacity
$525 SHIPPED
Comes with:
*14 ft. of steel braided line
*10 AN 10 straight swivel seal fittings
*2 AN 10 90° degree fittings
*1 AN 10 hose separator
*4 AN 10 aluminum male bungs for valve cover
*2 block port fittings for the back of the block with sealing washer
*B & R block plug
*3 breather filters
BREATHER TANK KIT
1 Gallon Capacity
$560 SHIPPED W/BLACK FITTINGS & HOSE
Comes with:
*14 ft. of Pro Lite 350 Hose
*B & R block plug
*3 breather filters
B-SERIES CATCH CAN DRAIN BACK KIT
$290 SHIPPED
Comes with:
* 1 polished aluminum catch can with 3 -10 male bungs & filter
* 10 ft. of AN 10 steel braided hose
* 3 AN 10 swivel seal hose ends
* 3 AN 10 90° swivel seal hose ends
* 1 block port fitting with sealing washer for the back of the block
* 1 B & R block plug
* 1 AN 10 hose separator
* 2 -10 male aluminum weld bungs for the valve cover
This kit hooks up with two lines going from the valve cover to the side of the catch can and one line going from the bottom of the catch can to the back of the block.
$330 SHIPPED W/BLACK FITTINGS & HOSE
Comes with:
* 1 Anodized black aluminum catch can with 3 -10 male bungs & filter
* 10 ft. of AN 10 Pro Lite hose
VALVE COVER KIT
$205 SHIPPED
Comes with:
* 1 Polished aluminum Catch can with drain valve
* 2 AN 10 90° swivel seal hose ends
* 2 AN 10 straight swivel seal hose ends
* 2 Aluminum AN 10 male bungs for valve cover
* 8 ft. of steel braided hose AN 10
* 1 AN hose separator
VALVE COVER KIT
$240 SHIPPED W/BLACK FITTINGS & HOSE
Comes with:
* 1 Anodized black aluminum Catch can with drain valve
* 8 ft. of AN 10 Pro lite hose
D-SERIES CATCH CAN KIT
$285 SHIPPED W/POLISHED CATCH CAN
$295 SHIPPED W/ANODIZED BLACK CATCH CAN
Comes with:
* 1 aluminum polished catch can with 2 -10 male bungs and 1 -12 male bung (on bottom of the catch can) & Filter
* 8 ft. of AN 10 stainless steel hose
* 3 ft. of AN 12 stainless steel hose
* 2 AN 10 straight hose ends
* 2 AN 10 90 degree hose ends
* 2 AN 10 male aluminum bungs for the valve cover
* 2 AN 12 45 degree hose ends ends
* 1 AN 12 D-series block plug adapter with flange for the back of the block
We charge $70 to weld two bungs onto the valve cover if you purchase a catch can kit.
If you just need two bungs welded on your valve cover and you don't purchase a kit its $100 shipped back to you.
Please make payment using paypal(add 3%): send to bandrfittings@gmail.com
Orders in CA add 7.25% sales tax.
1 Gallon Capacity
$525 SHIPPED
Comes with:
*B & R block plug
*3 breather filters
BREATHER TANK KIT
1 Gallon Capacity
Comes with:
*B & R block plug
*3 breather filters
$290 SHIPPED
Comes with:
Comes with:
VALVE COVER KIT
$205 SHIPPED
Comes with:
VALVE COVER KIT
Comes with:
Comes with:
Re: CATCH CAN KITS W/AN FITTINGS (GarageAlchemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist »</TD></TR><TR><TD CLASS="quote">you guys should be fuel lines for ef's</TD></TR></TABLE>
Maybe down the road, we'll see.
Bump it up.
Bump it up.
Re: CATCH CAN KITS W/AN FITTINGS (hotrod99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrod99 »</TD></TR><TR><TD CLASS="quote">pm'd</TD></TR></TABLE>
Replied.
For those who just want the catch can by itself:
Its $80 for the catch can.
Replied.
Re: (akunamatta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta »</TD></TR><TR><TD CLASS="quote">what is the purpose of using the setup?</TD></TR></TABLE>
The purpose of this setup is to vent crankcase pressure. The stock PCV valve closes under positive pressure thus creating excessive crank case pressure. By using a catch can it allows the pressure to escape thru filter on top of the catch can.
Re: CATCH CAN KITS W/AN FITTINGS (ForceFed_Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports »</TD></TR><TR><TD CLASS="quote">Good deal, very complete </TD></TR></TABLE>
Thanks
Thanks
Re: CATCH CAN KITS W/AN FITTINGS (methos713)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 »</TD></TR><TR><TD CLASS="quote">nice prices </TD></TR></TABLE>
Thanks
Thanks
Re: CATCH CAN KITS W/AN FITTINGS (Disco Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disco Monkey »</TD></TR><TR><TD CLASS="quote">those look nice.
do the cans come with a mount?</TD></TR></TABLE>
Yes they do. It depends where the can is mounted. If you want to flush mount it against something flat then I weld a flat bar across the back of the can with one hole on each side.
If you want to mount it in between the battery and fuel filter then the can will have two upside down L shaped brackets welded onto the can. Then another two L shape brackets that you screw into the firewall. Here's a picture. In this picture there is only one bolt holding the can to the bracket on the firewall. I recommend using 2 bolts so the catch can doesn't move from left to right. The kit comes with all the bolts and self tapping screws. Pics
