Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
NEW ANODIZED & POLISHED CATCH CAN KITS!!!!!!!!!!!!!
Old 06-20-2007, 11:26 PM
B R Fittings's Avatar
Default CATCH CAN KITS W/AN FITTINGS
BREATHER TANK KIT
1 Gallon Capacity
$525 SHIPPED
Comes with:
*15 ft. of stainless steel braided line
*10 AN 10 straight swivel seal fittings
*2 AN 10 90° degree fittings
*1 AN 10 hose separator
*4 AN 10 aluminum male bungs for valve cover
*2 block port fittings for the back of the block with sealing washer
*B & R block plug
*3 breather filters
BREATHER TANK KIT
1 Gallon Capacity
$560 SHIPPED W/BLACK FITTINGS & HOSE
Comes with:
*15 ft. of Pro Lite 350 Hose
*B & R block plug
*3 breather filters
B-SERIES CATCH CAN DRAIN BACK KIT
$300 SHIPPED
Comes with:
* 1 polished aluminum catch can with 3 -10 male bungs & filter
* 10 ft. of AN 10 steel braided hose
* 3 AN 10 swivel seal hose ends
* 3 AN 10 90° swivel seal hose ends
* 1 -10 block plug adapter
* 1 AN 10 hose separator
* 2 -10 male aluminum weld bungs for the valve cover
This kit hooks up with two lines going from the valve cover to the side of the catch can and one line going from the bottom of the catch can to the back of the block.
NOTE: If you have a B20 block then you will need a 28mm to -10 adapter since it doesn't have the port for the -10 block plug adapter.
$330 SHIPPED W/BLACK FITTINGS & HOSE
Comes with:
* 1 Anodized black aluminum catch can with 3 -10 male bungs & filter
* 10 ft. of AN 10 Pro Lite hose
VALVE COVER KIT
$215 SHIPPED
Comes with:
* 1 Polished aluminum Catch can with drain valve
* 2 AN 10 90° swivel seal hose ends
* 2 AN 10 straight swivel seal hose ends
* 2 Aluminum AN 10 male bungs for valve cover
* 8 ft. of steel braided hose AN 10
* 1 AN hose separator
VALVE COVER KIT
$245 SHIPPED W/BLACK FITTINGS & HOSE
Comes with:
* 1 Anodized black aluminum Catch can with drain valve
* 8 ft. of AN 10 Pro lite hose
D-SERIES CATCH CAN KIT
$285 SHIPPED W/POLISHED CATCH CAN
$295 SHIPPED W/ANODIZED BLACK CATCH CAN
Comes with:
* 1 aluminum polished catch can with 2 -10 male bungs and 1 -12 male bung (on bottom of the catch can) & Filter
* 8 ft. of AN 10 stainless steel hose
* 3 ft. of AN 12 stainless steel hose
* 2 AN 10 straight hose ends
* 2 AN 10 90 degree hose ends
* 2 AN 10 male aluminum bungs for the valve cover
* 2 AN 12 45 degree hose ends ends
* 1 AN 12 D-series block plug adapter with flange for the back of the block
Please make payment using paypal send to bandrfittings@gmail.com
Or
You can call us to order with a credit card.
831-262-6468
Orders in CA add 8.75% sales tax.
Modified by B R Fittings at 10:11 PM 6/21/2007
Modified by B R Fittings at 11:10 PM 6/22/2007
Modified by B R Fittings at 5:55 PM 8/16/2007
Modified by B R Fittings at 11:49 PM 8/23/2007
Modified by B R Fittings at 11:50 PM 8/23/2007
Modified by B R Fittings at 5:49 PM 10/3/2007
Modified by B R Fittings at 4:09 PM 1/13/2008
Modified by B R Fittings at 11:17 PM 2/7/2008
Modified by B R Fittings at 7:13 PM 2/12/2008
Modified by B R Fittings at 10:12 PM 2/13/2008
Modified by B R Fittings at 2:47 PM 4/5/2008
Modified by B R Fittings at 9:49 PM 7/20/2008
Modified by B R Fittings at 9:54 PM 11/2/2008
B R Fittings is offline
Old 06-21-2007, 04:00 PM
Default Re: CATCH CAN KITS W/AN FITTINGS (B R Fittings)
Up top
Old 06-22-2007, 12:16 PM
A.E Motoring's Avatar
very nice
A.E Motoring is offline
Old 06-22-2007, 03:17 PM
Default Re: CATCH CAN KITS W/AN FITTINGS (Dual Cam Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing &raquo;</TD></TR><TR><TD CLASS="quote">very nice</TD></TR></TABLE>
Thanks
Old 06-23-2007, 10:08 PM
hoskos's Avatar
If i were to get the valve cover kit. Do i still need to remove the black box behind my block and plug up the hole??
hoskos is offline
Old 06-23-2007, 11:36 PM
Default Re: (hoskos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoskos &raquo;</TD></TR><TR><TD CLASS="quote">If i were to get the valve cover kit. Do i still need to remove the black box behind my block and plug up the hole??</TD></TR></TABLE>
If you car is turbocharged I would get rid of the PCV valve and black box. What happens is, the PCV valve closes under boost creating positive pressure in the crankcase. If your car is all motor you would be fine with leaving it hooked up (pcv valve and black box).
How much power do you plan on making?
Old 06-24-2007, 03:48 AM
hoskos's Avatar
Default Re: (B R Fittings)
i'm already running 420hp
But i'm still on my stock PCV
So i'm very interested in getting the vented catch from ya. i just need alittle help on which to get.
I'm planning to run vented. So from what i understand i should be getting the valve cover kit + the block plug from you?
hoskos is offline
Old 06-24-2007, 09:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoskos &raquo;</TD></TR><TR><TD CLASS="quote">i'm already running 420hp
I'm planning to run vented. So from what i understand i should be getting the valve cover kit + the block plug from you?</TD></TR></TABLE>
Then I would ditch the stock PCV system and buy a block plug. The more vents you have the better the car will breath. For the amount of power your making 2 vents off the valve cover will be adequate. However, the best would be to run either 4 vents off the valve cover, or run 2 off of the the valve cover and two off the back of the block. Do you plan on making more power?
Old 06-24-2007, 09:46 AM
hoskos's Avatar
I'll most prolly be driving ard like this for awhile.
i reckon need to do is vent the valve cover and remove the stock PCV and plug up the hole?
BTW are the fittings swivel fit? i don't want to end up with my fittings in various funny positions
hoskos is offline
Old 06-24-2007, 09:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoskos &raquo;</TD></TR><TR><TD CLASS="quote">I'll most prolly be driving ard like this for awhile.
BTW are the fittings swivel fit? i don't want to end up with my fittings in various funny positions</TD></TR></TABLE>
Yes, they are swivel fit fittings. You would need to remove the black box and plug it up. Then remove your PCV valve.
Old 06-24-2007, 10:04 PM
inspyral's Avatar
Do you have the block port fittings in -12?
inspyral is offline
Old 06-25-2007, 01:27 AM
hoskos's Avatar
hoskos is offline
Old 06-25-2007, 01:28 AM
hoskos's Avatar
ok. why don't u pm me with the quote for what i need.
Thanks
hoskos is offline
Old 06-25-2007, 06:41 AM
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">Do you have the block port fittings in -12?</TD></TR></TABLE>
I currently don't, but I can get them made. Let me know and I can get it shipped out tomorrow.
Old 06-25-2007, 10:02 AM
inspyral's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B R Fittings &raquo;</TD></TR><TR><TD CLASS="quote">
I currently don't, but I can get them made. Let me know and I can get it shipped out tomorrow. </TD></TR></TABLE>
Can you PM me the pricing?
inspyral is offline
Old 06-25-2007, 04:36 PM
Can you PM me the pricing?</TD></TR></TABLE>
replied
Old 06-25-2007, 07:59 PM
Hondatron's Avatar
pm'd
Hondatron is offline
Old 06-25-2007, 10:02 PM
Default Re: CATCH CAN KITS W/AN FITTINGS (Hondatron)
replied
Old 06-27-2007, 04:46 PM
bumpity
Old 06-29-2007, 07:18 AM
up top
Old 06-29-2007, 07:27 AM
MindEracer's Avatar
Just wanted to say thankyou great product, been looking for something like this.. You'll be hearing form me soon..
MindEracer is offline
Old 06-29-2007, 07:32 AM
Default Re: CATCH CAN KITS W/AN FITTINGS (MindEracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MindEracer &raquo;</TD></TR><TR><TD CLASS="quote">Just wanted to say thankyou great product, been looking for something like this.. You'll be hearing form me soon.. </TD></TR></TABLE>
Thanks, looking forward to hearing from you.
Old 06-30-2007, 08:23 PM
bump
Old 07-02-2007, 06:37 AM
bump
Old 07-02-2007, 11:56 AM
inspyral's Avatar
Fast shipping, great service
inspyral is offline
Quick Reply: NEW ANODIZED & POLISHED CATCH CAN KITS!!!!!!!!!!!!!
