Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
TURBO COOLANT LINE KITS W/BLACK FITTINGS!!!!!
Old 06-14-2007, 07:15 PM
B R Fittings's Avatar
Default TURBO COOLANT LINE KITS!!!!!!
We just got these in. Their 28mm to -6 machined 6061 aluminum fittings used for the turbo feed line going to the turbo. PM me if you have any questions.
$30 Shipped
Front Block Port Coolant Kit
$115 Shipped in USA
Comes with:
28mm to -6 front block port
Two 14mm to -6 fittings for GT series turbos
Two -6 90 degree fittings
Two -6 45 degree fittings
5 ft of -6 steel braided hose
1 -6 aluminum weld bung for the radiator
For black fittings and pro lite 350 hose (black hose) its $135 shipped.
Inline Kit
$99 SHIPPED
Comes with everything pictured plus 7 ft. of AN 6 steel braided hose. Push lock ends attach to stock lines and run back to turbo. Also comes with a hose separator to keep your lines looking good. No ghetto zip ties here.
RADIATOR KIT
$120 SHIPPED
Comes with 7 ft. of AN 6 steel braided hose. Just weld the AN 6 bung to the bottom of your aluminum radiator and connect the line to the turbo. Use the AN 6 Tee to tap for your other source.
T KIT
$139 SHIPPED
Comes with 7 ft. of AN 6 steel braided hose. Just use the 2 AN 6 T's to tap into your stock lines for the feed and return. Also comes with a hose separator to keep you lines looking good. No ghetto zip ties here.
Please send payment using paypal (add 3%): bandrfittings@gmail.com
Credit cards will be accepted soon.
Orders in CA add 7.75% sales tax.
Modified by B R Fittings at 8:37 PM 6/14/2007
Modified by B R Fittings at 8:41 PM 6/14/2007
Modified by B R Fittings at 11:00 PM 8/23/2007
Modified by B R Fittings at 11:55 PM 8/23/2007
Modified by B R Fittings at 5:36 PM 7/20/2008
B R Fittings is offline
Old 06-14-2007, 07:22 PM
89efDUSTY's Avatar
Default Re: TURBO COOLANT LINE KITS!!!!!! (B R Fittings)
damn let me be the first to say very nice product.
89efDUSTY is offline
Old 06-14-2007, 07:27 PM
Default Re: TURBO COOLANT LINE KITS!!!!!! (89efDUSTY)
Thank you very much.
Old 06-17-2007, 10:37 AM
0TT
0TT's Avatar
have you got some pictures of the inline kit installed onto a b-series engine?
0TT is offline
Old 06-17-2007, 04:01 PM
Default Re: TURBO COOLANT LINE KITS!!!!!! (0TT)
I don't have any pics of it installed, but I can send you pictures of where to tap the lines into. I have a b series engine sitting in my garage.
Old 06-19-2007, 07:35 AM
bump
Old 06-21-2007, 04:01 PM
bump
Old 06-23-2007, 07:22 AM
up top
Old 06-26-2007, 06:05 AM
bump
Old 06-27-2007, 04:47 PM
Pm's replied
Old 06-29-2007, 07:20 AM
bump
Old 06-30-2007, 08:24 PM
bump
Old 07-02-2007, 06:34 AM
bump
Old 07-02-2007, 01:21 PM
96ex's Avatar
bump check pm
96ex is offline
Old 07-02-2007, 06:41 PM
Default Re: TURBO COOLANT LINE KITS!!!!!! (96ex)
Replied, will have tracking # tomorrow, shipped 2nd day air.
Old 07-03-2007, 06:16 AM
up top
Old 07-05-2007, 06:46 AM
bump
Old 07-06-2007, 06:28 AM
up top
Old 07-07-2007, 03:31 PM
up top
Old 07-09-2007, 05:56 AM
bump
Old 07-10-2007, 06:14 AM
up top
Old 07-11-2007, 06:35 AM
bump
Old 07-12-2007, 04:21 PM
bump
Old 07-14-2007, 04:30 AM
bump
Old 07-15-2007, 11:12 AM
bump
Quick Reply: TURBO COOLANT LINE KITS W/BLACK FITTINGS!!!!!
