Check Engine Light, 1990 Civic, Help!
Old 06-05-2007, 05:04 PM
92coupe's Avatar
Default Check Engine Line, 1990 Civic, Help!
I have a 1990 civic with the 1.5, base model etc...
After driving the car for a few minutes, sometimes 1 minute, sometimes 10 or so, the check engine light comes on. Then the car idles quite a bit higher, and stumbles a bit getting back on the gas etc...
How do I check codes with this car, and any guesses on what it may be? The car also seems to be getting poor mileage, but thats expected in this situation I guess.
Old 06-05-2007, 05:09 PM
footwork mastery
.Grimace's Avatar
Default Re: Check Engine Line, 1990 Civic, Help! (92coupe)
to check the codes lift up the carpet on your passenger side footwell. there will be the ecu with a little led light. turn the car to auxilary power or whatever it is and count the blinking light. a quick blink =1. a long blink= 10.
Old 06-06-2007, 09:43 AM
ef_hatchback's Avatar
is it multi port or dual point??? like gremice said, check the count of blinks until it stops.
Old 06-07-2007, 11:56 AM
methods555's Avatar
Default Re: Check Engine Line, 1990 Civic, Help! (Gremice)
same problem here....just replaced the plugs and air filter but needs a oil change. Possible I blew the o2 sesnsor but not sure. The CEL does not come one everytime I run the car, only once in a while. Strange....Is there a certain pattern the lights flash and then stop?? Also where can I find a list of the codes for a OBD1....thanks!
Old 06-11-2007, 04:46 PM
92coupe's Avatar
Ok I counted them and wrote them down, now where do I find the list of what they mean? Thanks for the help by the way
Old 06-11-2007, 05:10 PM
julioboostamante's Avatar
tell us what they are and you can find the info in the FAQ section under trouble shoot codes.
Old 06-13-2007, 03:53 PM
RPRacing's Avatar
here you go. there is a key of what they mean here.
http://www.rpracingonline.com/...s.php
oarreguin
08-16-2017 11:58 AM
Maco71
Honda Civic (2001 - 2005)
08-09-2017 07:42 PM
roxics
10
03-01-2013 12:37 PM
khmersouljah
09-23-2010 12:03 PM
Ej1_coupe
12-14-2003 07:44 AM
Quick Reply: Check Engine Light, 1990 Civic, Help!
