TRANSMISSION
Old 05-07-2007, 06:31 AM
GSB1203's Avatar
Default TRANSMISSION
I CURRENTLY OWN A 98 HONDA ACCORD V6. TOTAL MILES 92,745. THE CHECK ENGINE LIGHT CAME ON, ERROR CODE P0730 INCORRECT GEAR RATIO WAS THE CODE. AM I GOING TO NEED A NEW TRANSMISSION, AND WHAT IS THE AVERAGE COST.
I REALLY NEED YOUR HELP, THANK YOU IN ADVANCE
GSB
Old 05-07-2007, 07:59 AM
twkdCD595's Avatar
Default Re: TRANSMISSION (GSB1203)
Are you having any issues with it shifting at all or anything like that?
I know alot of the odysseys/ accords (v6) of your year and newer are also having problems with the transmissions and are throwing the p0730 code and others that are related.
I thought there was an extended warranty issued for the v6 accord for the transmission... you may want to double check (you may not still be elidgable) but agian alot of people are having similar issues (accord, odyssey, etc... v6) with these and rumor has it there is a class action agians honda over this.
Old 05-07-2007, 10:31 AM
GSB1203's Avatar
Default Re: TRANSMISSION (twkdCD595)
I am not having a problems with shifting, however when the vehicle is cold the transmission races while in drive. When the vehicle heats up the problem is not as severe. I will check on that extended warranty.
If a new transmission is needed what is the basic price$$
Thank in advance
GSB
Old 05-07-2007, 12:21 PM
Tech-Nics's Avatar
the RPM is supposed to be high on a cold start, if you put your car into drive right after a cold start without letting it warm up. it rolls alot faster rather than when its warmed up. pretty normal.
Old 05-07-2007, 02:48 PM
YeuEmMaiMai's Avatar
ur trans is toast, been there done that....lol mine quit at 87K, 94K and 98K
Old 05-07-2007, 04:12 PM
funtak's Avatar
Default Re: (YeuEmMaiMai)
Couldn't it even be the differential if its showing an incorrect gear ratio?
rmiv1985
06-27-2019 04:10 AM
fomococo
06-09-2014 04:36 PM
zrock85
05-12-2014 06:41 PM
MemoArgote
06-06-2009 03:31 PM
Jonny-X
09-12-2007 10:53 AM
Quick Reply: TRANSMISSION
