Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
OBX LSD sale B series, D series and GSR
Old 01-09-2009, 04:10 PM
  #426
kaj
kaj's Avatar
Default Re: OBX LSD sale B series, D series and GSR
has anyone asked if you have one for an ITR transmission? assuming same as B16?
Old 01-09-2009, 04:14 PM
  #427
kaj
kaj's Avatar
Default Re: OBX LSD sale B series, D series and GSR (mike93eh2)
Originally Posted by teal_dx
So I got an OBX lsd from you a couple months ago and finally got around to installing it. Everything went smoothly and the tranny was back in the car & everything was back together. I filled the tranny with fluid and called it a night.
The next morning there was a puddle under the car from the right axle. I thought it was an axle seal (even though they were brand new) But I grabbed the inner CV joint and pulled on it and it moves in/out about 1/8 to 3/16"
The axle clip is seated because it was not pulling all the way out, only about 1/8 to 3/16". So I took it all back apart, had a hell of a time prying the axle out with a screwdriver (typical OBX trait from what I've read) and tried 3 different stock right axles - all with the same result of play!
I still had my stock diff and they fit perfect in there. So I got a strip of putty and made an imprint of the inside of where the axle goes into, with the grooves and the ridge where the clip settles into.
Problem found, The grooves on the inner edge of the OBD stop about 1/8" sooner on the inner side than the grooves on the stock diff.
So the axle clip is going in, but the OBX LSD has the grooves ending too soon and that allows the axle clip to lock in, but still slide back & forth about 1/8 to 3/16"
This is only happening on the passenger side, the driver side is fine. I have not heard of this particular problem anywhere else yet.
It was the latest version of the LSD, 3.0 they call it, with no stampings on the outer casing.
Before I bother taking everything back apart & try to get a refund/exchange (Will you even offer me a refund or exchange?), what is a possible solution for this?
The only thing that comes to mind right now is to get an axle custom machined on a lathe a little bit so that the groove for the axle clip is 1/8" more toward the inner CV joint (away from inner tip of axle). Then load the new wider slot up with 3 or so axle clips (or one really wide clip?)
This is
i used to have the same issue with my quaife. i had to get a passenger-side axle from a Gen 2 integra.. or something weird like that. the reason being, the splines on the axle were shorter the newer b-series axle.
sorry for being so vague.. this was about six yrs ago. i still have the axle, if you want it.
this was a quaife in a B16 cable tranny, converted to hydro.
it drove me crazy 'till my friend said, "oh. you need 'this' axle". problem solved. but: even if you get my axle.. what will you do if it ever breaks??
good luck.
Old 01-09-2009, 05:58 PM
  #428
Honda Gen's Avatar
only GSR LSD instock
Old 01-19-2009, 10:54 PM
  #429
civicboyvtec's Avatar
looking for an lsd for my b16a gearbox which is y21 with 4.4 final drive, Amer
Old 02-23-2009, 05:08 AM
  #430
pgpbubble's Avatar
has obx straightened this out?
Old 10-26-2009, 05:55 AM
  #431
egturbolsvtec's Avatar
I NEED A LSD FOR 99 B16 TRANS ASAP!
Old 01-13-2010, 05:16 PM
  #432
dicxonjim's Avatar
i need a LSD for a 99 B16 Tranny ... i cheked your website but they say none in stock!
Old 01-13-2010, 05:56 PM
  #433
Honda Gen's Avatar
OBX don't have LSD9000 in stock anymore
Old 01-14-2010, 04:11 PM
  #434
dicxonjim's Avatar
So what LSD can I get for the B16. ?? Any suggestions ????
Old 01-14-2010, 05:47 PM
  #435
Honda Gen's Avatar
quaife ones
Old 01-18-2010, 11:22 PM
  #436
PAT86KID's Avatar
got one for a ae86?
Old 01-19-2010, 02:06 AM
  #437
gator1's Avatar
Originally Posted by PAT86KID
got one for a ae86?
Why don't you just buy a two way diff.
Old 01-21-2010, 11:48 AM
  #438
stankcrx's Avatar
so no more for cable b16 y1 tranny
Old 05-10-2010, 08:03 PM
  #439
need a lsd for b16 hydro
Old 05-20-2010, 04:03 PM
  #440
need a lsd for b16 hydro trans
gnxpro24
Transmission & Drivetrain
12-19-2013 01:58 PM
fernek200+
01-28-2009 05:55 AM
Quick Reply: OBX LSD sale B series, D series and GSR
