Codes: P0301, P0302, P0303, P300, P1399 help
Old 06-07-2008, 07:43 PM
  #26
ChinitodeNJ's Avatar
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (ChinitodeNJ)
bumpppp
Old 06-23-2008, 03:08 PM
  #27
stujohnny's Avatar
I had the same codes coming up on my 97 Accord. I researched this forum, along with some others and found that the P1399 code is pretty mysterious and covers a slew of issues. Some had luck with replacing the dizzy and cap, another had luck with replacing his injectors. I replaced my plugs, wires, dizzy and rotor with no luck. I then did some research on the EGR valve and found that could be causing the P1399, along with the other misfire codes. Before I replaced the EGR valve I cleaned out my EGR ports. Car has been running great since.
Hopefully this help...
Old 06-26-2008, 07:35 AM
  #28
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (stujohnny)
Well it turned to be my valve....lol. After taking it to my performance mechanic(which i should've done first) I blew one of my valves on the head. So i just replaced the head because i didnt feel like resleeving the valve on my head. well hope you guys find your problems..
Old 06-26-2008, 07:36 AM
  #29
all-mtr-teg's Avatar
So you had a bent valve?
Old 06-26-2008, 07:49 AM
  #30
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (all-mtr-teg)
blown actually, im trying find out how to post up pics of it so i can show everyone
Old 07-14-2008, 02:03 PM
  #31
Snoochie Boochies's Avatar
Location: behind the dumpster, w./your bitch, w./your bitch
i am dealing with a car right now that came in with misfire codes. we did a compression check and all were good except #3, put the boroscope in and one of the exhauast valves was melted. so we pulled the head and installed a new honda valve then put everything back together with new plugs. (cap/rotor/wires/etc. had been replaced recently) now the car has good compression but throws the p1399 code an runs like *** so i would like to know if anyone has figured out why these accord 4cyl's are burning valves.
all four injectors sound like theyre functioning with the stethascope.
Old 07-14-2008, 07:31 PM
  #32
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (Snoochie Boochies)
I think Honda should be made aware of this CEL. Maybe they can issue a TSB. I took my GSR to an Acura dealer and they couldn't figure it out either.
Old 06-29-2009, 05:39 PM
  #33
hedfly's Avatar
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (GRAF-FITI)
Originally Posted by all-mtr-teg
I dumped in some of that CRC emission pass and deleted the codes with my scanner, so far the CEL hasnt come on but it seems to just pop on when it feels like it. Sometimes as idle, sometimes while cruising on the freeway
same here bro and the cnc stuff seemed to not have any effects
Old 07-02-2009, 09:23 AM
  #34
backyardinc's Avatar
Suks, I got the P0303 CEL ......ttt
Old 08-10-2009, 09:26 AM
  #35
JMCR277's Avatar
Default Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (gohonda)
My CEL is flashing too and it happend after a high rev misshift what is wrong with my car? 1999 Prelude SH
Old 10-14-2009, 10:12 AM
  #36
JCRXTURBO20916's Avatar
dose your valve tick when cold, cuz you guy could just need a valve adjustment.
Old 10-27-2009, 03:04 PM
  #37
h22_spin_em's Avatar
ok got the same problem too...i jus swapped a jdm h23a in my 01 lude...i know timing is perfect cuz i put the belt on while the motor was still out but i know the plug wires r on the rite way...havent done a compression test yet but it only misfires when its warm...when i first start it theres no problems with misfire or anything...jus when it gets warmed up thats when it starts to run like crap...i have 2 brand new o2's o yea my vtec doesnt wrk either which i dont understand that also....someone plz try and help me out wit some suggestions
Old 10-27-2009, 07:01 PM
  #38
thewrai6th's Avatar
I get these at idle when my ECU is having trouble getting to stoch. Either the PO2 sensor, unsealed/clogged injectors or tune in my case.
Old 12-05-2009, 06:19 PM
  #39
Yosshaa's Avatar
i got the same problem... god it sucks asssssssssss
Old 12-15-2009, 03:58 PM
  #40
Rbehne2's Avatar
Are any of you losing coolant? I have the same codes, keep losing coolant, but no leaks, so i think the head gasket is gone.
Old 01-11-2010, 08:05 PM
  #41
timdcfd's Avatar
Originally Posted by gohonda
P0301- Cylinder 1 misfiring
P0302- cylinder 2 misfiring
P0303- cylinder 3 misfiring
P0300- random / multiple misfire detected.
P1399- Manufactures control Ignition system OR Misfire
ANYone have any ides how to fix this or where to start. The CEL blinks while driving right now!
car just had tune up: plugs, wires, distributor cap and rotor.
Old 01-11-2010, 08:07 PM
  #42
timdcfd's Avatar
Have same codes (P0300-301-302-etc.) Been told by mechanic that it might be a blown head gasket.
Old 01-12-2010, 09:33 AM
  #43
I believe this was the problem in my case. I burning through about a quart of antifreeze a month, then I replaced the headgasket, ever since then, the CEL's haven't come back, been about a year now.
Old 01-13-2010, 12:33 PM
  #44
JZs15's Avatar
i just replaced my head gasket, crank sensor, spark plugs, fuel filter, cap and rotor, and my timing is adjusted. and im still getting the p0301,p0302,p0300 and a p1399 pending. what else can i do to fix this on a 98 dx with a mini me setup?
Old 01-14-2010, 11:28 AM
  #45
JZs15's Avatar
leaky intake manifold gasket or bad spark plug wires?
Old 01-24-2010, 07:55 PM
  #46
dirtnyurface's Avatar
id.like.to.know.wtf.this.is.about...just.got.my.em 1...drove.it.4.hours.home.with.no.codes,then.it.th rew.this...
Old 03-03-2010, 06:51 PM
  #47
nfsintegra's Avatar
me too but i only got po301 and p1399 and 1999 integra gsr was sitting in storage for few years... so what could it be?
Old 03-15-2010, 05:20 AM
  #48
TRIAL USER
tygr20's Avatar
Getting a blinking CEL + lit ATTS light after running at a consistant RPM, be it idle or cruising.
Hate to revive this thread yet again, my 98 Prelude SH is throwing P0300, P0301, P0302, P0303, and P1399. My timing belt went out about 3 weeks ago, and damaged some valves. Did a head swap to a head with good valves, valves have been tuned, timing is in, just changed plugs, wires, cap, rotor, cleaned out the EGR itself and the EGR ports, still idling rough and making a poppoppoppoppoppop noise at the exhaust. As of this morning, she's also bitching when I start her up, just struggles for the first couple of cranks, then starts fine.
No loss of power from what I can tell, no loss of VTEC, but I haven't pushed to redline to see if I'm floating at 6800 or the typical 8100. Ideas on what to do next? I'm assuming check the injector connectors and the fuel rail.
Old 04-06-2010, 08:28 PM
  #49
EJtypeR's Avatar
Icon3 Re: CODES: P0301, P0302, P0303, P300, P1399 HELP! (gohonda)
Originally Posted by Dogginator
Let's start with some questions.
When did this problem start? (Did you overrev with a misshift, etc.?)
Are the valves adjusted? Have you performed a compression check?
Is the timing adjusted?
What do the spark plugs look like?
Does the CEL blink only at low RPM or at all RPM?
Im having the same problem in cyl four...i misshifted and overreved. what could that mean?
Old 04-08-2010, 01:21 AM
  #50
dc2monsta's Avatar
Default Re: Codes: P0301, P0302, P0303, P300, P1399 help
I know this thread is kinda old but im having the same problem kind of. Well long story short, i misshifted into 2nd from 3rd cause my clutch was worn out and overreved it. i slowed down and was like wtf so i did it again. As i got home the cel came on ive changed the spark plug first thinking that was it but nope wasnt the problem a yr and a half later i decided to get a rebuild since everything was due for service come to find out that i had to slightly bent valves so got everything fixed and the cel is still on. Its still reading cylinder misfire 1&2 and random misfire. and the car is running rich too. what ive done to try to solve this was spark plugs, plug wires, dizzy, rotor, cap, switch the fuel pressure regulator, adjust the valves, new o2, maps good, iacv good, no air leaks. swapped the injectors around and still getting the same code. timing good. any suggestion would be great. thanks
Quick Reply: Codes: P0301, P0302, P0303, P300, P1399 help
