P1362 TDC no signal...
Old 03-19-2007, 05:16 PM
SupRlude01's Avatar
Default P1362 TDC no signal...
Just got back from inspection and failed due to:
P0301- Cylinder 1 misfire
P1362 TDC Sensor no signal
The Car is a 99 LS by the way.
So far I got new plugs for to see if that'll correct the first issue and what exactly should I do/ look for to correct the TDC issue? I did a search and found nothing. What would be the first place to start to diagnose this problem?
Also:
When I tried doing the self check (paper-clip circuit) it wouldn’t blink or work like on my other Honda. Instead the Check engine light stays on when the keys in the on position (radio on, etc) and then once I turn the ignition on and the motors running it shuts right off? It’s like the old owner created a way to hide the CEL which doesn’t bother me but how can I fix this also?
Any help is greatly appreciated!
Old 03-20-2007, 05:28 AM
SupRlude01's Avatar
anyone?
Old 03-20-2007, 05:35 AM
SuzukaBlueAP2's Avatar
Default Re: (SupRlude01)
Sounds more like a TDC sensor that has failed.
You could try calling a dealership and ask them what that code means...
I'd have to look around more on this one to figure it out because that's not an error code that comes up frequently.
Old 03-20-2007, 08:27 AM
SupRlude01's Avatar
Ok solved the check engine light issue. It seems the previous owner tapped the original CEL light with the oil light to hide the check engine. So thats all set, but I still have the TDC code... Any suggestions what to try first?
Old 03-20-2007, 10:37 AM
99Geeezer's Avatar
Default Re: P1362 TDC no signal... (SupRlude01)
will the car start and run?
Old 03-20-2007, 02:11 PM
SupRlude01's Avatar
Starts & runs perfect, no stutter, hesitation etc... Everything is 100% Just reset the ecu and so far 2 10 mile trips with no CEL. Maybe it was just on the memory...we shall see soon
Old 03-22-2007, 04:33 PM
SupRlude01's Avatar
Its back, but its only the TDC Cel. Any ideas on how to trouble shoot this? Where is the sensor on a b18b?
Old 03-22-2007, 05:17 PM
thecunningham's Avatar
dude, the tdc sensor is part of the distributor sub assembly, I suggest you replace it
Old 07-11-2007, 07:47 AM
evolutionglitch's Avatar
im not sure if you still have this problem but the tdc sensor should be on the crank pully side of the engine under the timing belt cover from 1996 on and in the distributor from 1995 and earlier...
...ran across your thread and wondered if you ever fixed it... well good luck.
Old 06-29-2009, 04:58 PM
SupRlude01's Avatar
Bringing this thread back from the dead, my CEL issue was never fixed and i still have
P1362 which is the TDC. What part should i replace to fix this? Anyone ever have this problem, my car runs fine just have the cel
Old 07-05-2009, 06:27 AM
SupRlude01's Avatar
anyone?
APAem1
06-03-2010 09:42 AM
bstaralways
09-04-2007 02:51 PM
SlipAngleX
05-04-2003 09:14 PM
[626]95-GSR
09-19-2002 09:26 PM
Malgerus
08-15-2002 07:06 AM
Quick Reply: P1362 TDC no signal...
