Help with Honda Code 730
Old 03-03-2007, 01:45 PM
Buddy10297's Avatar
Default Help with Honda Code 730
Hello Everone,
I have a 1998 Honda Civic with an automatic transmission it has a 1.5ltr engine. I went to the mechanic due to the engine light being on and found out that my car was giving off a 730 code. Does anyone know what this means? Do you know where I can get a manual or some information in fixing this? Thanks.
Old 03-03-2007, 01:49 PM
HT White Ops
Eran's Avatar
P0730 is related to the automatic transmission sensors, more specifically the linear solenoid being fouled or clogged. Does your transmission feel like it's shifting harshly?
Old 03-03-2007, 01:57 PM
Buddy10297's Avatar
Default Re: (Eran)
Hey Eran,
Yes the transmission does feel like it's shifting harshly. How do I locate it and how do I fix it? I don't have a manual so I"m a little in the dark. Thanks.
Old 03-03-2007, 02:03 PM
HT White Ops
Eran's Avatar
Well, one thing you should do is flush your transmission.
Drain your transmission, and fill it back up to spec with cheap 10w30 motor oil. Run it for 5 minutes, and then shut it off. Drain it, and then fill it again with 10w30. Run it for 5 minutes, and then drain again. Fill back up with Honda ATF (Automatic Transmission Fluid). Replace your linear solenoid.
Linear Solenoid: Honda Part# 28250-P4R-315 - $128.41 @ slhondaparts.com
http://www.slhondaparts.com/se...se%21
Old 03-03-2007, 02:45 PM
Buddy10297's Avatar
Default Re: (Eran)
Eran,
Thanks for your helpful advice. I will def. try that and keep you posted.
Old 03-03-2007, 02:47 PM
HT White Ops
Eran's Avatar
Actually, don't flush with 10w30. Use some generic Honda-specific ATF. I was giving you instructions on flushing a manual tranny.
Old 03-03-2007, 02:51 PM
ifIexplode's Avatar
Not to thread jack. But is D4 by any chance flashing in your cluster?
nikboca
Honda S2000
11
03-25-2006 08:44 PM
microjubei
09-17-2005 11:25 PM
Leo95SE
11-04-2001 08:02 PM
Quick Reply: Help with Honda Code 730
