Check Engine light on 1999 HOnda Accord Code 420 Need Help!!
Old 02-17-2007, 05:01 AM
rickytz7111's Avatar
Default Check Engine light on 1999 HOnda Accord Code 420 Need Help!!
I have a 1999 HOnda accord lx. The check engine light came on so I went to autozone to get it checked. The code says the catalyst system efficency for bank 1 is below threshold for the current engine operating conditions (bank 1 identifies the location on cylinder #1 while bank 2 identifies the cylinders on the opposite bank. I took the code to a mechaic and he said that my cat was bad. That all the the stuff in the at had been blown out and the 1st o2 sensor was reading the same as the one behind the cat and the one behind the cat should read diffrent. That is why the check engine light came on. Autozone reset the check engine light and it stayed off for about 40 miles and came back on. I took it to advance where my friend works at and they ran the code again and he said that it was the same. He thinks the back 02 sensor is bad and not the cat. He said that the light should hae come back on realy quick after they reset it is why he doesn't think it;s the cat. Has anyone had this problem? Any advice would be deeply appreciated. Thanks
Old 02-17-2007, 05:08 AM
YeuEmMaiMai's Avatar
Default Re: Check Engine light on 1999 HOnda Accord Code 420 Need Help!! (rickytz7111)
V6 accords have a slightly higher than average catalytic converter replacement rate. they can verify cat failure with a infared heat gun that will read the temp of the converter
Old 02-17-2007, 08:29 AM
Default Re: Check Engine light on 1999 HOnda Accord Code 420 Need Help!! (YeuEmMaiMai)
It's a 4 cyl accord lx. Do you guys think I should take it to a honda place and see what they think? I have a place here that charges $35 to hook it up and tell me whats wrong. I just don't want it to be the same machine that they use at autozone for free.
Old 02-17-2007, 04:39 PM
Has anyone one else had this problem???
Old 02-17-2007, 06:41 PM
Chiovnidca's Avatar
1999 accord with a p0420? Replace the cat.
Old 02-18-2007, 05:19 AM
Default Re: Check Engine light on 1999 HOnda Accord Code 420 Need Help!! (Chiovnidca)
I forgot to metion the car has 165k on it
Old 02-18-2007, 07:04 AM
brads94accord's Avatar
with that many miles, replace the cat, its probably clogged.
JeannieEden
05-12-2018 04:16 AM
fcardenas
Honda Civic (2001 - 2005)
03-16-2018 12:56 PM
Laura Ilkenhans
10-13-2012 06:47 AM
adorek24
01-11-2010 09:26 AM
bma1818
04-19-2006 09:55 PM
Quick Reply: Check Engine light on 1999 HOnda Accord Code 420 Need Help!!
