code 8
Old 11-27-2006, 10:01 AM
JdM_RACeR07's Avatar
Default code 8
my rex is throwin code 8 on a dohc zc....the tdc unplugged or defective circuit.....where is that located and how do you fix it
Old 11-27-2006, 10:22 AM
onepoint6i's Avatar
Default Re: code 8 (JdM_RACeR07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM_RACeR07 &raquo;</TD></TR><TR><TD CLASS="quote">my rex is throwin code 8 on a dohc zc....the tdc unplugged or defective circuit.....where is that located and how do you fix it
check continuity at the sensor @ the end of your exhaust cam, theres a plug with two wires, make sure they are plugged into the computer, if theres continuity and are connected to the ecu, the wires are possible switched around..
superslowcrx91
09-30-2013 12:54 PM
drumminforev
25
11-11-2006 09:19 PM
rewerbcrx
04-05-2006 08:09 AM
89HTACH
22
03-20-2004 04:53 PM
Quick Reply: code 8
