> Acura Integra
Old 10-22-2006, 05:38 PM   #1
B20inDCinLBC
B20inDCinLBC's Avatar
Default Bad Spark plugs and spark plug wires makes tapping noise??
If your spark plugs or spark plug wires are bad, would it make a tapping noise. Something that sounds like it needs a valve adjustment?
BUMP IF YOU VIEW
B20inDCinLBC is offline   Reply With Quote
Old 10-22-2006, 07:44 PM   #2
GRAF-FITI
* B A N N E D *
Send a message via AIM to GRAF-FITI
Default Re: Bad Spark plugs and spark plug wires makes tapping noise?? (B20inDCinLBC)
normally faulty wires and plugs will cause a misfire and some arcing...as for the noise i would recommend a valve adjustment as you questioned in your post
GRAF-FITI is offline   Reply With Quote
Old 10-22-2006, 08:06 PM   #3
B20inDCinLBC
valve job was done, and still some tapping
BUMP IF YOU VIEW
Old 10-22-2006, 08:42 PM   #4
ejmatzell
ejmatzell's Avatar
Send a message via AIM to ejmatzell
Default Re: (B20inDCinLBC)
not to steel from your thread... but when you did your valve adjustment, (not to sound like a ricer) did you notice a power gain? i really need to get one done...
[quote=Eg_k20]hey look i have a friend who insists that all gsr integras come with turbo .... i told him my cousin has a gsr and it does not have turbo... he said its not a gsr ... im certain it is..... does the gsr come with turbo out the factory[/quote]
ejmatzell is offline   Reply With Quote
Old 10-22-2006, 08:46 PM   #5
__oversea
__oversea's Avatar
Default Re: (ejmatzell)
lol.
it just make car run smooth like new. should be checked every 40-50k miles. not really sure about mileage
__oversea is offline   Reply With Quote
Old 10-22-2006, 09:54 PM   #6
B20inDCinLBC
no, didn't notice HP gain, just got rid of the annoying tapping sound though. I can't notice any power because right now it's untuned.
BUMP IF YOU VIEW
Old 10-23-2006, 08:28 AM   #7
ejmatzell
ejmatzell's Avatar
^ gotcha, thanks
Old 10-23-2006, 08:31 AM   #8
skunked
skunked's Avatar
Send a message via AIM to skunked
If you have a bad wire it will make a ticking sound as it arc's off whatever it's grounding to. Like others said, it will run very rough as well. At night it will look like Star Wars under your hood if that was the case
Aftermarket header's will also create a louder "ticking" sound from the motor which is normal.
2.2L H2B NA DC2 S/P 12.1@110
http://www.quartersportsdrag.com/
SINISTER RACING
skunked is offline   Reply With Quote
Old 10-23-2006, 05:49 PM   #9
B20inDCinLBC
where would the light show come from though?
BUMP IF YOU VIEW
Old 10-24-2006, 07:36 AM   #10
skunked
skunked's Avatar
from wherever the wires are arching if that's the problem.
SINISTER RACING
bad, caused, causing, make, makes, noise, noises, plug, plugs, sound, spark, sparkplugs, tapping, ticking, wires
