Replacing the starter 1999 Honda Accord
Old 07-20-2006, 01:40 PM
joenoreason's Avatar
Default Replacing the starter 1999 Honda Accord
I've misplaced my shop manual and need to know how to replace the starter... I can only see one bolt, which i cant really even get to. Can someone give me a basic rundown on this?
Old 07-20-2006, 02:09 PM
philadd's Avatar
Default Re: Replacing the starter 1999 Honda Accord (joenoreason)
1. Remove the battery and battery tray.
2. Remove the lower radiator hose.
3. Remove wiring harness from starter bracket.
4. Label and disconnect the wires from the starter motor solenoid.
5. Remove the 2 bolts that mount the starter to the trans. They are 180 degrees from each other, so the other bolt is on the exact opposite side of the one you see. Once the bolts are removed, you can pull the starter free.
Old 07-20-2006, 02:14 PM
Intense3.2's Avatar
Default Re: Replacing the starter 1999 Honda Accord (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">1. Remove the battery and battery tray.
5. Remove the 2 bolts that mount the starter to the trans. They are 180 degrees from each other, so the other bolt is on the exact opposite side of the one you see. Once the bolts are removed, you can pull the starter free.</TD></TR></TABLE>
Good stuff
Where the hell did all these noobs come from?
Old 07-20-2006, 02:34 PM
Default Re: Replacing the starter 1999 Honda Accord (Intense2.2)
hahah gotta love i<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Intense2.2 &raquo;</TD></TR><TR><TD CLASS="quote">Good stuff
Where the hell did all these noobs come from? </TD></TR></TABLE>
haha... gotta love the guy who pops in just to say something like this. reminds me of highschool... its no wonder you have 918 posts.
Old 07-20-2006, 02:40 PM
i_kick_turtles's Avatar
Also, make sure the mounting surface on the block is clean before you install the new starter.
Old 07-20-2006, 02:46 PM
philadd's Avatar
Default Re: Replacing the starter 1999 Honda Accord (I R Tylor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I R Tylor &raquo;</TD></TR><TR><TD CLASS="quote">Also, make sure the mounting surface on the block is clean before you install the new starter.</TD></TR></TABLE>
Ahh, yeah, forgot to mention that kind of thing. For me I just instinctively clean everything... I swear I'm borderline OCD or something, because everytime I do anything it has to be clean and orderly. It tends to make car repairs and maintenance a bit more time consuming.
Old 07-20-2006, 02:48 PM
Thanks guys. Both of you have been very helpful.
Old 07-20-2006, 07:18 PM
ykwak's Avatar
Hey,
but being neat and orderly can also save you a headache later on...
for example,
i antisieze EVERYTHING, and i torque to spec...if i dont know what to torque it to, i look it up
Doing this to exhaust / turbo parts helps a LOT.
so does zip tying just about every dam thing that's loost
Old 12-24-2010, 08:58 AM
soldierforGod's Avatar
I would like to thank you Philadd and I kick turtles for your posts. You just saved me hundreds of dollars. God bless ya.
Old 09-05-2012, 11:46 AM
sandiegan's Avatar
Will removing the lower radiator hose cause the coolant to drain?
Old 09-06-2012, 02:08 AM
holmesnmanny's Avatar
lol Of course it will. What do you think is inside that hose ?
There is a drain plug on the bottom of the radiator. You just need to loosen it up and drain the coolant out of the radiator into a drain bucket. Don't let it drain on the ground as the coolant is poisonous to animals. Odds are that that hose is going to be old. This would be a good time to replace it. Don't think about putting the same coolant back in. Just get another couple of jugs of coolant from Walmart cheap.
Old 12-20-2013, 08:06 PM
diulay_pkjai's Avatar
My car is having the same issue, does anyone have the diagram or detail pictures of the starter? pilladd's instructions are pretty vague without pictures. Thanks.
miguey310
06-23-2010 06:14 PM
HAV6
10-01-2007 09:32 AM
tlovaj
08-23-2007 04:17 PM
B bOy CrAyOn
08-06-2007 07:24 PM
bacnoonoi
02-04-2007 12:48 PM
Quick Reply: Replacing the starter 1999 Honda Accord
