can you bleed brakes through the banjo bolt?
Old 06-12-2006, 05:28 PM
huge230's Avatar
Default can you bleed brakes through the banjo bolt?
My bleeder valves are fucked. They are not coming out period. Do I need new calipars or you bleed through the banjo bolt somehow?
Old 06-12-2006, 05:31 PM
ROOROWNS's Avatar
Default Re: can you bleed brakes through the banjo bolt? (huge230)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huge230 &raquo;</TD></TR><TR><TD CLASS="quote">My bleeder valves are fucked. They are not coming out period. Do I need new calipars or you bleed through the banjo bolt somehow?</TD></TR></TABLE>
Soak the valves with pb blaster or something equivalent and try to break them loose 24 hours later, do this acouple days in a row and it will come lose.
Im talking use half a can if you have to.
Old 06-12-2006, 05:44 PM
huge230's Avatar
Default Re: can you bleed brakes through the banjo bolt? (No_Honda)
well the tops of them already snapped off and i tried to use a srec extractor and it snapped that even with lots of heat. Ill just have to find some used calipars
Old 06-12-2006, 05:57 PM
missionsix43's Avatar
yeah.. looks like your stuck with getting new calipers
Old 06-12-2006, 06:03 PM
ROOROWNS's Avatar
Default Re: can you bleed brakes through the banjo bolt? (missionsix43)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by missionsix43 &raquo;</TD></TR><TR><TD CLASS="quote">yeah.. looks like your stuck with getting new calipers </TD></TR></TABLE>
x2
Old 06-12-2006, 06:56 PM
o5mar1's Avatar
if you have a drill you can drill out the stud that is still in the caliper, and then use a tap and dye kit to tap the caliper. if you dont have these tools, just buy a used caliper.
Old 06-13-2006, 01:55 PM
huge230's Avatar
Default Re: (o5mar1)
I could do that. For the calipar that has the broken screw extractor in, could I drill and tap a hole right beside the bleeder valve? Because trying to drill through the extractor would be pretty tough
Old 06-13-2006, 02:42 PM
lilnuke's Avatar
Those small EZ outs are worthless. They are to brittle and break, as you found out.
Don't drill and tap a new hole, use a carbide drill bit at low RPM and it will go through the EZ out with no trouble. Make sure you use some cutting oil to keep the heat down. Slowly increase the bit size until you remove most of the bleeder. Then use a tap to clean out the threads. If necessary, completly drill out the bleeder, re-tap, and use a Helicoil to repair the hole.
Old 06-13-2006, 03:43 PM
Slamaccord's Avatar
Try gravity bleeding it. Its gonna take a bit longer but its worth a shot.
Make sure to pump the pedal and feel for pedal pressure.
h2b-ubeezy
11
02-16-2009 05:57 AM
guero2craze
10-11-2008 04:43 AM
reed857
10
06-07-2006 06:20 AM
EL Vap133
04-06-2004 11:44 AM
PearlWhiteAccord
12-14-2003 07:17 AM
Quick Reply: can you bleed brakes through the banjo bolt?
