P28 ECU problem... fried?
popped Q31, the IAT and EVAP purge connectors being swapped will cause this.
Depending on your state, if it has strict emissions standards, you may need Q31 functional. If not, you should be fine.
make 100% sure you didn't melt the IAT sensor at the same time (it usually does)
D1780 - http://www.pgmfi.org/twiki/bin...D1780
Re: (Relic1)
so will my ecu work or does it not work with that fried? i dont really kno wat the purge connector is that ur talking about thanks
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">with the IAT fried ur probably going to run rich...get it replaced...</TD></TR></TABLE>
thats true.
when its fried the resistance will be unlimited..... and by the resistance graph of the iat you can see that the higher the resistance the lower the temp. (its an ntc resistor)
this reason will cause it to run rich....
thats true.
Re: (RACEPAK)
so basically can i run my ecu like this and im just going to run rich? or should i email the seller and tell him that i want a refund? only problem is idk if he will give me one and therefore idk if paypal will automatically deduct the money from his account? any suggestions?
Re: (Relic1)
okay so where exaclty should i hook up a meter to it? or should i not even bother and send the ecu back just in case? thanks
Re: (MBlake55)
bump i need some more opinions on this guys, i thought that i would be running really rich and that could def be really bad, but does anyone have this problem and kno if it is true or not? let me kno thanks
pull the connector from the IAT, connect ohm meter to the sensor.
0.4-4.0K ohms is what the manual says. If it's in there connect the connectors correctly and you should be ok.
you may want to remove the burnt part from the ECU, simply rock it back and froth till it snaps out of place then toss it. The ECU will not set a code or run differently due to that.
b16nonoy
02-19-2007 01:10 AM
