Lug Nut Torque specs!
Old 05-26-2006, 07:32 AM
BoostFrenzy.com's Avatar
Default Lug Nut Torque specs!
do you know Honda Civic Lug nut Torque specs for Gorilla Lugs ?
Old 05-26-2006, 07:40 AM
pingaturbo's Avatar
80lbs
Old 05-27-2006, 05:54 PM
old man neri's Avatar
Default Re: Lug Nut Torque specs! (Mafiozo)
Make sure to retorque a week or something afterwards.
Old 05-28-2006, 04:06 PM
Senor Miembro
ecahatch's Avatar
yep....what they both said
but for me, usually i torque it at 80lbs, drive around for a couple of minutes and then re-torque to dbl check
Old 08-09-2006, 10:52 PM
fxpguy's Avatar
Default Re: (pingaturbo)
Is 80 lb the standard torque for tightening stock bolts on most vehicles? If not, I have a Honda Accord 92 EX sedan. What should I torque the wheel bolts to? What is the size for standard wheel bolts? Thanks.
Old 08-09-2006, 11:01 PM
iam7head's Avatar
Default Re: (fxpguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fxpguy &raquo;</TD></TR><TR><TD CLASS="quote">Is 80 lb the standard torque for tightening stock bolts on most vehicles? If not, I have a Honda Accord 92 EX sedan. What should I torque the wheel bolts to? What is the size for standard wheel bolts? Thanks.</TD></TR></TABLE>
wheel bolt? are you driving a german?
those nuts are 12x1.5mm thread size, 80 foot/lb torque spec, please apply anti-seize on the stud
make sure you retorque it after a week or so, new wheels, new lugs' painted surface will sometime loose the wheel, even if you torque it down.
something you learn at the track
Old 08-09-2006, 11:34 PM
fxpguy's Avatar
Default Re: (iam7head)
Sweet, thanks iam7head for the info!
Going to be taking off my wheels to adjust my coilovers more often, so I figure when I put them back on I have to make sure they are torqued properly.
Are wheel bolts only a term used for german car bolts? What are they called for other cars? heh
Old 08-10-2006, 12:12 AM
iam7head's Avatar
for most japanese car the stud is mounted onto the hub, and you put the wheel in the stud and put the lug nuts to tighten it down
X=wheel
H
U STUD X NUTS(removeable part)
B
VW loves to use bolts, the stud is part of the nut lugs
H
U X BOLT(removeable part)
B
and something about coilover, i always cover the thread with a masking tape, the part right below the perch gets sand blasted all the time, if you put masking tape there, you don't have to dust off and wash the area next time you adjust them.
Old 08-10-2006, 07:22 AM
H-T Order of Merit
nsxtasy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fxpguy &raquo;</TD></TR><TR><TD CLASS="quote">Is 80 lb the standard torque for tightening stock bolts on most vehicles? If not, I have a Honda Accord 92 EX sedan. What should I torque</TD></TR></TABLE>
80 lb-ft is the torque spec for every Honda and Acura car I'm familiar with, including Civics, Accords, Integras, and even the NSX.
Old 08-10-2006, 08:39 AM
Default Re: (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Back when I was with VWs it was, I think, 88 for alloy rims. More for steelies.
eddiebuiltEK.
01-30-2009 10:07 AM
smxcan
Honda Civic (2006 - 2015)
11
01-09-2009 07:11 PM
xbB
11
09-26-2004 12:50 PM
Madracer1
10
12-19-2002 01:49 PM
RedGSR
09-19-2002 07:37 AM
Quick Reply: Lug Nut Torque specs!
