**Official H2B Discussion thread **
Re: **Official H2B Discussion thread **
It's getting tuned now - although first they are modifying a brand new sump to emulate the Kaisenspeed version. So I'd say in 1week I'll have figures, at last
Thanks! Although I'm going to remake it out of Aluminium. The acrylic just bowed in the heat and started rubbing the crank pulley lol
Originally Posted by YeeJ6
lower timing belt cover looks sick!
I wanna know if this the right radiator for h2b? or do i have to get the civic? im sure this might be the right one.
http://www.mishimoto.com/honda-prelu...nce-92-96.html
Ek Forever y0!
If you're worried about cooling, you can use a double width rad from the 4th gen Lude if you make custom brackets and you can also use the same NAPA hose 8325 (or 8235 I can't remember) FYI
which USDM pan is compatible with an h23a blue top? A friend of mine just cracked her oil pan..
Edit: 8325 for that upper hose
Ek Forever y0!
No, I remember reading somewhere just the other week that there is a USDM replacement for the oil pan on the H23A bluetop.
Lemme see if I can find it.
Edit, Found:
Edit, Found:
Ek Forever y0!
Bolt on or weld on? And it's not bad.
Mine was $275 installed at a shop for 2.5"
VRS exhaust is having a blowout in the marketplace if that's not the one your referring to.
It's a weld on. And not the one I was talkin about. I'll have to take a peak. And I more than not want a weld on. Want to put all v band on it. Thanks
Steve at Heart
https://honda-tech.com/forums/hybrid-engine-swaps-18/h2b-oil-pan-kaizenspeed-kstuned-com-2965242/
is the oil pan dead now? don't see anything on there webpage
Ek Forever y0!
Doh, nevermind. I misread a post in another thread.
They were talking about a header blowout sale:
https://honda-tech.com/forums/performance-45/%2A%2A%2A%2A-rmf-style-narrow-b-series-header-blowout-sale%2A%2A%2A%2A-2899374/
just finished putting in my h2b in my eg hatch and i noticed the throttle cable isnt connecting right onto the h22 braket, whats needed to be done to get it working?
hey, stupid question....are the oil pumps different from us to jdm h22's?
i need one, and found someone selling one cheap online. he says he bought it from honda for a usdm h22 and doesnt fit his jdm h22. has timing issues??
i thought they were the same. anyone know?
thanks
thanks
thanks
thanks
obd2 usdm oil pumps are the same for years (late 1997)1998-01 part number 15100-P5M-A01
Although the mains are different from obd1(50mm) to obd2(55mm) the crank snout is the same size and both oil pumps should interchange.(I've only used a 96' obd2 oil pump on a jdm 94' obd1 engine)
The 1996-1997 obd2 oil pump also used to be cheaper. It looks like that has changed now on a couple of online dealer sites.
