| Welcome to Honda-Tech! | ||
#1 |
| Garage is empty, add now |
Ok so it finally started getting warm in ohio, I picked this car up to be a daily driver this winter and it ran fine but lately it seems that the car will not start when it is hot. for example I wake up to go to work car starts fine, drive to work turn off and right back on its ok but if i get out and go back to it twenty mins later it wont start it has to sit for an hour plus cool down then it starts. many people said it was the main relay i cant even seem to find this in the car shop manual tells me its a 7 pin connector (nothing found)
Car has an engine start button and to start it has to be on position 2 with the key it seemed that it wasnt getting fuel at that point all the time so we metered it and all seemed fine but hooked up a relay direct to the pump (positive, ground, acc., and to the black/yellow (pos for fuel pump) this still did not work. I don't realy know what else to do when i get in the car hot it just cranks someone help fix this car its such a bad *** daily driver i wanna keep it.
#2 |
could be any number of things
test your ignition module test your fuel pressure regulator and fuel pump It could be main relay but that usually is not a problem on 5th gen cars |
#3 |
year and model ??
yep it could be the main relay ... first off, when it does not start , you need to verify if it is lack of gas or spark,, if lack of gas i would look at the main relay first,,relay located under dash , left side, if lack of spark,, ignitor, coil, |
#4 |
i saw alot of main relays on 94-97 accords and even started seeing them on 98's last summer
1994 ACCORD 4DR EX H22A/1993 CAMARO Z28 |
#5 |
Get the area around the car nice and quiet. sit in the car with the windows up, turn th key to on without starting it. Watch your check engine light, when it goes off you should hear a click. If not your main relay is bad.
The main relay is under the drivers side dash on the outer wall of the car. Someone on here can post apicture of it, or mabye i have one to post. Modified by MooGoCow3 at 5:34 AM 5/1/2006
My signature |
#6 |
It looks something like this.
My signature |
#7 |
thats the problem the car has no main relay I pulled appart the entire dash there were two behind the cd player and one under the dash left side that controls the heater. year make and model is 94 accord wagon with a 95 JDM h22
#8 |
Unless someone hacked up the wire harness during the install it has a main relay.
My signature |
#9 |
i think it was a hacked up harness...unfortunately...
#10 |
first up
sweet *** ride !!! my buddy had a 90 wagon with h22 swap in her cl interior all the bolt ons and was making like 220whp with her in your situation, I would bring it to someone if you did the swap urself, and you hacked up the wiring, it's gonna be a bitch to re-wire but you need to !! pretty sure that u cannot run her without the main relay
95 EX-R V6 5 SPEED ONLY ONE IN CANADA 193WHP Dyno'd Biatch |
#11 | |
relay is under dash, located on the rt side of the steering column,, car will not start at all hot or cold if relay is missing or wiring harness has been cut |
#12 |
Mabye it was relocated for space reasons? I don't know, I just can't mentally justify removing or moving a main relay. If it has been cut out what is replacing it?
It's really buried in the dash your not going to find it for the first time unless your on your back looking up into the dash
My signature |
#13 |
I really dont know how it started before, I pulled the whole dash off and got on my back seats were out and there was no main relay that i could see, i looked hard I want this thing fixed. So i unpluged positive at the fuel pump and ran a relay (pos, neg, acc. and pos to the fuel pump) that way any time car is on accessory the fuel pump is running. So it cant be a problem with the main relay. Also replaced rotor its getting spark.
#14 |
Honestly not knowing about this hack job I really can't help you. I can look at the honda electical manual but that's not going to apply in this case.
My signature |
#15 |
Ok so today I tried to replace the fuel pump with a walbro 255 I had. The car ran worse (too rich) then the problem still occured. I pulled into chick fil a and 20mon later tried to start the car. when car was put on accessorie i could hear the fuel pump kick on but the car just cranked and cranked and cranked. I'm totally out of ideas i dont know what to do someone please help.
Also if anyone wants to purchase car as is I have put 4 new tires on as well as new bumper lenses, new clutch and lightened flywheel, oil was just changed I would ask only 8000 which is what i paid for the car. ![]() ![]() ![]() ![]() ![]() ![]() H22A Accord SiR engine swap auto. to manual swap DC Sports header Injen intake AEM tru-time adjustable cam gears Unorthodox Racing main crank pully Bosch Platinum spark plugs Magnecor spark plug wires STR fuel rail Tsudo front and rear strut tower bars JDM/ true HID headlights Mugen grill Versus carbon fiber hood JDM auto-folding side mirrors Apexi WS coilover kit Brembo big brake kit conversion Skunk2 extended racing wheel studs Brembo cross-drilled rear rotors Suspension Techniques front and rear sway bars 18" custom powder coated Racing Hart C5 wheels w/Nitto Neo Gen tires Imported custom Apexi exhaust Sparco Torino racing seats Sparco steering wheel Sparco shift **** Forbidden Motorsports short shifter (not an adapter) Momo leather shift boot JDM SiR Tach gauge cluster (so the RPM redline is correct for the engine) The speedo. is from a manual Accord so the auto. shift select lights are not there custom molded piller guage pod with air/fuel meter and boost guage Ferrari sounding air horns The car was just repainted, no dings, dents, or rust. This is, in fact, the wagon that was on the cover of speed, style, and sound magazine. |
#16 |
ok heres a question for you. When you turn the key to on what does the check engine light do?
My signature |
#17 |
i work at an iport salvage yard it does have a main relay above left kick panel it a b** to get to get down by kick panel on left side look straight up
#18 |
ur car is nice
#19 |
i say its a faulty ignition control module, ive had same symptoms and it was always the problem...like a $70 dollar part and a 15min job...
#20 |
the check engine light comes on it has been since i bought the car unfortunately its the "JDM" engine and no dealer has the thing to check the codes.
#21 |
dude who did you buy this from ?
bring it to a honda mechanic ( not a dealership ) in your area buy a 12 pack and make a day of it ... don't sell her she's magical !!
#22 |
All you have to do is jump the 2 pin connector at the right side under the dash (if that's still there) And every dealer has the 3 pin adapter to allow the PGm tester or the HDS tablet to communicate with the car.
If you need more instructions the procedure is in one of the stickied threads at the top of the forum.
My signature |
#23 |
ok so heres the deal the car is no longer for sale its a peice of **** but i love it and want to fix and keep it (i feel like a DSM owner) I found the main relay good lookin out to the guy that works at the junkyard. We resoldered it and that did not work. We are in the process of replacing the thermostat but i dont really thing thats it either bc my temp gauge never really goes out of control. I have an SCI-L and the rest of the MSD ignition set up ready to go in the car that fixes the spark problem but I run into another. To run an external coil you have to have a cap that can do that. Prelude's in america come factory with an external coil so MSD doesnt sell a cap to do this for the H series but of course the JDM engine has an internal coil!!! so what cap do i get to do this will a b series fit or can i use an OEM replacement american Hseries? wtf?!? jdm sucks
#24 |
for the cap, use a 99-00 civic si
#25 |
sweet thanks
| Tags |
| 1990, 1993, 1994, 1999, 99, accord, civic, honda, hot, kick, left, location, main, panel, relay, start, wont |
