ball joint with no cotter pins???
Old 04-26-2006, 02:33 PM
Silent_Destruct's Avatar
Default ball joint with no cotter pins???
i just got a ball joint today and it has no cotter pins, and the nut is different. also the rod that sticks out of the ball joint doesnt have a hole for a cotter pin...
so the only thing stopping it is the nut which has blue plastic on the end...?
confused on to why mine didnt have a cotter pin or the hole for one
Old 04-26-2006, 02:40 PM
sik96teg's Avatar
Default Re: ball joint with no cotter pins??? (Silent_Destruct)
that blue thing basically locks the nut on so theres no need for a cotter pin but ive never seen that if your worried take it back
Old 04-26-2006, 02:42 PM
will it still lock it if ive un done it a couple of times? (replaced pass axle twice in 2 days...didnt know i had antilock, so i got the one without, found out i do, had to replace)
Old 04-26-2006, 02:47 PM
sik96teg's Avatar
Default Re: (Silent_Destruct)
i would just get a few of the locking nuts so when u do take them off u can throw a fresh one on there. So yea replace the nut just to be on the safe side
Old 04-26-2006, 02:48 PM
gotcha im guessing any sears or ace should have em
Old 04-26-2006, 02:52 PM
sik96teg's Avatar
yea probably i usually get all my lil bolts like that from napa
Old 04-26-2006, 02:53 PM
skunked's Avatar
they are called nylock nuts
Old 04-26-2006, 02:54 PM
thanks skunked....good to know!
Old 04-26-2006, 02:55 PM
also which is better? cotter pin or nylock nut?
Old 04-26-2006, 03:01 PM
sik96teg's Avatar
never seen a ball joint not use the cotter pin but if thats how there making some of them now it must be better or just as good. If i had to choose though i would choose cotter pin. Not that i dont doubt the nylock but y change a good thing
Old 04-26-2006, 03:02 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silent_Destruct &raquo;</TD></TR><TR><TD CLASS="quote">also which is better? cotter pin or nylock nut?</TD></TR></TABLE>
I think the cotter pin is safer....
my friend hit a tree at 50mph because he didn't think the cotter pin was important. Not even 10 minutes it lasted on a curvey road.
Old 04-26-2006, 03:25 PM
yea ur friend also had the standard nut though u know?
Old 04-26-2006, 03:47 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silent_Destruct &raquo;</TD></TR><TR><TD CLASS="quote">yea ur friend also had the standard nut though u know?</TD></TR></TABLE>
right, but my point was to tell what can happen if it comes off
Old 04-26-2006, 05:08 PM
ya...that wouldnt be good, im thinking about putting a couple on just to be safe
lowtegsr
03-06-2008 12:49 PM
Ti Rider
10
02-03-2007 04:18 PM
WhiteOnRice
10-24-2006 02:13 PM
f@sth@tch89
03-01-2004 06:04 AM
nugget8000
08-27-2001 09:37 PM
Quick Reply: ball joint with no cotter pins???
