Symptoms of a seized caliper?
Old 04-11-2006, 09:56 AM
es_squared's Avatar
Default Symptoms of a seized caliper?
I remember having this issue with the front driver side.. i would see lines around the caliper, and it turned out being a siezed caliper when i took it in. Same thing with the rear now, lines around the brake caliper. Could i just check by taking the pad out and seeing if the piston goes in/out properly?
Old 04-11-2006, 10:59 AM
britishlude's Avatar
Default Re: Symptoms of a seized caliper? (es_squared)
Do you mean lines around the rotor ? The way to check if calipers are sticking is to jack up the rear of the car on level ground, chock the front wheels and car in gear for safety firstly, release the handbrake and turn the rear wheels by hand. They should turn reasonably freely if caliper is not seized, if they are difficult to turn then your calipers are sticking.
Modified by britishlude at 8:09 PM 4/11/2006
Modified by britishlude at 8:15 PM 4/11/2006
Old 04-11-2006, 12:13 PM
ShinobiLude's Avatar
Default Re: Symptoms of a seized caliper? (britishlude)
Dont run it too long with a seized caliper or you will FUG your master cylinder all up.
Old 04-11-2006, 12:54 PM
Hondaen's Avatar
Easy, after a ride, just feel the temperature on each rim.
If one rim is hoter than the rest, you have a brake problem.. worn pads of sticking calipper.
Old 04-11-2006, 05:12 PM
es_squared's Avatar
Default Re: Symptoms of a seized caliper? (Hondaen)
thanks guys, ill check it over
Old 09-25-2006, 05:57 PM
da_33's Avatar
u can also smell something different after getting out of your car if one is seized
Crispypata
Suspension & Brakes
01-15-2017 05:55 AM
lv6l
12-26-2008 12:25 PM
Nisif
20
09-26-2007 07:04 AM
SonicGSR
03-31-2003 05:55 PM
integra97R
02-05-2003 10:44 AM
Quick Reply: Symptoms of a seized caliper?
